Hello, welcome to our forum.
It looks like you have registered but you have not yet posted and messages. Our requirements are that you must post at least two messages, to allow the moderators to review your registration, before you will be allowed access to the full range of forum areas.
Please make a couple of posts, until then you may see a notice that says you are banned from certain forum areas.
Thank you.
Remove Text Formatting
Loading...
+ Reply to Thread
Results 1 to 6 of 6
    Default PBP3 Code Does not Compile with PBP3.1
    I upgraded to PBP 3.1 recently and while some PIC code compiles just fine the following does not (although it compiles with PBP3 - I just switched my compiler to the old folder and it worked):
    '*  Name    : Nacelle_Steady-On_Lights_12F1840_16Mhz_Int.pbp    *
    '*  Author  : Ross A. Waddell                                   *
    '*  Notice  : Copyright (c) 2016                                *
    '*  Date    : 11/26/2016                                        *
    '*  Version : 9.0                                               *
    '*  Notes   : Steady-on nacelle engine lights (TOS Enterprise)  *
    '*          : with PWM fade-in/brightness control               *
    ' For production version of this code, comment out the line below re:
    ' LCD debugging and also update config fuses to have code protect on
    '#DEFINE USE_LCD_FOR_DEBUG     ; comment out for non-debug use
    ' The PWM/fade works perfectly when **not** connected to a FET
    '   - if using a FET, the LEDs 'pulse' and blink but don't fade in/out
    '   - use a 2N2222A transistor
    ' Pin Connections
    ' VDD    -> pin 1            -> +5V
    ' RA5/Rc -> pin 2            -> EUSART receive
    ' RA2    -> pin 5            -> 1kohm -> 2N2222A transistor -> LEDs
    ' RA1    -> pin 6            -> Trim pot input
    ' RA0/Tx -> pin 7            -> EUSART transmit (LCD)
    ' VSS    -> pin 8            -> GND
    DEFINE OSC 16               ; Set oscillator 16Mhz
    ' EUSART Settings for Tx/Rc (e.g. LCD)
    ' > use Mister E PIC Multi-Calc application to get register/DEFINE settings
    ' > as the values are dependent on the OSC and desired baud rate
    DEFINE HSER_RCSTA 90h      ' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h      ' Enable transmit, BRGH = 1
    DEFINE HSER_CLROERR 1      ' Clear overflow automatically
    DEFINE HSER_SPBRG 160      ' 9600 Baud @ 16MHz, -0.08%
    ' Device Fuses
    ' PIC chip data sheets can be found here: C:\Program Files\Microchip\MPASM Suite
       __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF
       __config _CONFIG2, _PLLEN_OFF & _STVREN_ON & _BORV_LO & _LVP_OFF
    ' Initialization
    OSCCON    = %01111000        ' 16MHz internal osc
    APFCON.2  = 0                ; Tx on RA0 for LCD display
    APFCON.7  = 1                ; Rc on RA5
    APFCON.0  = 0                ; CCP1 on RA2
    ' Some LCD serial modules need inverted data, some do not
    ' Enable the line below if needed, but for SparkFun SerLCD it should be
    ' commented out
    'BAUDCON.4 = 1               ; Transmit inverted data to the Tx pin
    ' From Mister E's Multi-Calc (EUSART):
    SPBRGH    = 1
    BAUDCON.3 = 1               ' Enable 16 bit baudrate generator
    TRISA     = %00100010	     ' Make all pins output except for RA1 (trim pot input)
                                 ' and RA5 (EUSART Rc)
    ANSELA    = %00000010        ; Analog on PORTA.1 (AN1) only
    FVRCON    = 0                ' Fixed Voltage Reference is disabled
    ADCON0    = %00000101        ' ADC (analog-to-digital) is enabled on AN1 (RA1) only
    PAUSEUS 20                   ; wait for the analog switch 'glitch' to die down
    ADCON1    = %00110000        ; Left-justified results in 8-bits; Frc as timer
    #IFDEF USE_LCD_FOR_DEBUG
        LCD_INST   CON 254       ' instruction
        LCD_CLR    CON 1         ' Clear screen
        LCD_L1     CON 128       ' LCD line 1
        LCD_L2     CON 192       ' LCD line 2
        LCD_SP_CMD CON 124       ' special command character (for adjusting backlight brightness or toggling splash screen)
        LCD_BR_LVL CON 140       ' 140==40%
        LCD_SPLASH CON 9         ' toggles splash screen display
    #ENDIF
    ' Includes
    INCLUDE "DT_INTS-14.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas"    ' Include if using PBP interrupts
    INCLUDE "Elapsed_INT.bas"   ' Contains subs for doing elapsed time
                                ' --> copy files to PBP main folder
                                ' (i.e. c:\pbp3)
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
        INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    ' LED Fade Linearization
    ' Increasing the duty cycle by discrete integer amounts leads to a logarithmic
    ' increase in brightness; the LED appears to quickly reach maximum brightness
    ' long before it reaches the max duty cycle value. To make the fade in look more
    ' linear (like an incandescent bulb), the data table below uses 'gamma correction'
     ' to genterate appropriate duty cycle values.
    ' Values generated by C:\Users\Ross\Dropbox\PBP Projects\PBP3 and MCSPX Software\LEDGammaCorrectGenerator.xlsm
    ' Array size = 100
    ' Total PWM steps: 512
    ' Gamma correction: 0.75 (try values in the range of 0.5 - 2.0)
    ' # of values per line: 15
    '-----[The data table]--------------------------------------------------------
    DataWord       VAR WORD
    numSteps       CON 100
    DataTable      CON EXT
    GOTO OverData                ; Make sure data doesn't try to execute
    DataTable
      DW   0,  1,  1,  2,  2,  2,  2,  2,  3,  3,  3,  3,  4,  4,  4
      DW   5,  5,  5,  6,  6,  7,  7,  8,  8,  9,  9, 10, 11, 12, 12
      DW  13, 14, 15, 16, 17, 18, 19, 20, 22, 23, 24, 26, 27, 29, 31
      DW  32, 34, 36, 38, 41, 43, 45, 48, 51, 54, 57, 60, 63, 66, 70
      DW  74, 78, 82, 87, 91, 96,101,107,112,118,124,131,138,145,152
      DW 160,168,177,186,196,205,216,227,238,250,263,276,289,304,319
      DW 334,351,368,386,404,424,445,466,488,511
    endasm
    OverData:
    '-----[Continue with code]----------------------------------------------------
    ' Set up PWM on CCP1
    CCP1CON = %00001100          ; Use CCP1 in PWM mode
    ' Set duty cycle registers initially to 0
    CCP1CON.4 = 0
    CCP1CON.5 = 0
    CCPR1L    = 0
    ' Use Mister E's PICMultiCalc_1.3.1.exe application (Windows only)
    ' to determine prescaler and PR2 values for given OSC frequency (e.g. 16Mhz)
    ' and duty cycle (use 100% to see highest actual value)
    ' CCP1 uses TMR2
    T2CON   = %00000110         ; Timer2 on with 1:16 prescaler
    PR2     = 127               ; For 16Mhz OSC the desired output freq of 1954Hz
                                ; is achieved with this PR2 value (9-bit resolution
                                ; with 1:16 prescaler)
                                ; MAX DUTY = 512; must match max PWM steps from data
                                ; table above
    PWMDuty       VAR WORD      ; Duty cycle variable for PWM
    MaxADCVal     CON 255       ; 255 for 8-bit; 1023 for 10-bit
    ADCInVal      VAR BYTE      ; stores ADCIN result read from trim pot
    compVal       VAR BYTE      ; stores last-changed ADC value
    CounterA      var BYTE		' Just a BYTE Temporary working variable
    DataW         var WORD		' Just a WORD Temporary working variable
    RawData       var BYTE [16] ' Array holding ADC Result
    LEDBrIndx     VAR WORD
    i             VAR WORD
    PulseLimit    VAR WORD
    LEDPulse      VAR BIT       ; 1=fully on; 0= start pulsating effect
    LCDPause      CON 5         ; Pause for LCD display
    FadeInPause   VAR BYTE      ; Pause during LED fade in
        FadeInPause = 12
    #ELSE
        FadeInPause = 40 + LCDPause  ; was 15 + LCDPause
    #ENDIF
    ' Should only need to do this one time to adjust backlight brightness
    '#IFDEF USE_LCD_FOR_DEBUG
    '    HSEROUT [LCD_SP_CMD, LCD_BR_LVL]
    '    PAUSE LCDPause
    '#ENDIF
    ' Should only need to do this one time to disable splash screen
    '    HSEROUT [LCD_SP_CMD, LCD_SPLASH]
    '    PAUSE 1000
    '#ENDIF
        HSEROUT [LCD_INST, LCD_CLR, "LCD Init"]
        pause LCDPause
        HSEROUT [LCD_INST, LCD_L2, "  SerLCD_V2_5"]
        pause 2000
    #ENDIF
    ' Get Vref from ADC to set brightness step index
    GOSUB Do_ADC
    compVal = ADCInVal          ; set initial compare value
    GOSUB Map_ADCInVal_to_PWM_Steps
        HSEROUT [LCD_INST, LCD_CLR]
        pause LCDPause
        HSEROUT ["LEDBrIndx=",DEC LEDBrIndx,"  "]
        pause 750
    #ELSE
        PAUSE 500               ; should match motor spin up
    #ENDIF
    ' Fade in LED to set brightness
    FOR i = 0 to (LEDBrIndx  - 1)      ; max is 'numSteps' from data table above
        ReadCODE  (DataTable + i), DataWord
        PWMDuty = DataWord
        GOSUB ChngLEDBrightness
            pause LCDPause
            HSEROUT ["PWMDuty=",DEC PWMDuty,"  "]
        #ENDIF
        pause FadeInPause       ; should match motor spin up
    NEXT i
    LEDPulse = 1               ' set initial value
    Gosub ResetTime            ' Reset Time to  0d-00:00:00.00
    Gosub StartTimer           ' Start the Elapsed Timer
    '    PulseLimit = 95*(LEDBrIndx/100) ' 95%
    '    PulseLimit = 9*(LEDBrIndx/10) ' 90%
    '    PulseLimit = 4*(LEDBrIndx/5) ' 80%
        PulseLimit = 3*(LEDBrIndx/4) ' 75%
    '    PulseLimit = 6*(LEDBrIndx/10) ' 60%
    '    PulseLimit = LEDBrIndx/2     ' 50%
    '    PulseLimit = LEDBrIndx/4     ' 25%
    '   Check trim pot value
        GOSUB Do_ADC
    '    PAUSE 100
    '   If trim pot value has changed, update LED brightness level
        If (compVal > (ADCInVal + 1)) or (compVal < (ADCInVal - 1)) THEn
            compVal = ADCInVal
            ReadCODE  (DataTable + (LEDBrIndx - 1)), DataWord
            PWMDuty = DataWord
            gosub ChngLEDBrightness
                pause LCDPause
                HSEROUT ["new LEDBrIndx", LCD_INST, LCD_L2, DEC LEDBrIndx, "  "]
            #ENDIF
    '   Pulse LEDs
        if (Seconds = 1) AND (LEDPulse = 1) then
        '   Fade down LEDs to a preset minimum
            FOR i = (LEDBrIndx - 1) to PulseLimit STEP -1
                PWMDuty = DataWord
                    pause LCDPause
                #ENDIF
                'pause 15
                pause 12
            NEXT i
            LEDPulse = 0
        ELSEIF (Ticks = 20) and (LEDPulse = 0) THEN
        '   Fade up LEDs back to trim pot setting
            FOR i = PulseLimit to (LEDBrIndx  - 1)
                PWMDuty = DataWord
                    pause LCDPause
                #ENDIF
                'pause 15
                pause 12
            NEXT i
            LEDPulse = 1
    GOTO Main
    Do_ADC:
    '   Function to 'average out' changing ADC values when the trim pot swiper arm
    '   isn't moving to get a steady value
    '	Stuff 16 Element WORD Array full of ADC values
    	For CounterA = 0 to (16 - 1)
            ADCON0    = %00000101 ' Select Channel, Turn-On A/D
    						      '	7=0 Unused
    						      '	6=0 Unused
    						      '	5=0 )
    						      '	4=0 )
    						      '	3=0 ) selects AN1
    						      '	2=0 )
    						      '	1=0 Go-done Bit
    						      '	0=1 switch-On ADC Module
    		Pauseus 50			     ' Wait for channel to setup
            ADCON0.1 = 1			 ' Start conversion
    		While ADCON0.1=1:Wend	 ' Wait for conversion
    '		DataW.HighByte=ADRESH
    '		DataW.LowByte=ADRESL
            DataW = ADRESH           ' Read variable from ADC and save
    		RawData(CounterA) = DataW
    	Next CounterA
    '	Sort ADC Input
    	CounterA = 0
     GetADCSortLoop:
    	If RawData(CounterA + 1) < RawData(CounterA) then
    		DataW = RawData(CounterA)
    		RawData(CounterA) = RawData(CounterA+1)
    		RawData(CounterA+1) = DataW
    		If CounterA > 0 then CounterA = CounterA - 2
    	CounterA=CounterA+1
    	If CounterA < (16 - 1) then goto GetADCSortLoop
    '	Quanticise, discarding top and bottom FOUR elements
    	DataW = 0
    	For CounterA = 4 to 11
    		DataW = DataW+RawData(CounterA)
    	Next CounterA
        ADCInVal = DataW>>3			' Divide Result by EIGHT
    '*********** Map Vref to PWM step **************************************
    Map_ADCInVal_to_PWM_Steps:
    '   Map ADC value to the range of accetable PWM steps, as the two ranges may
    '   not be the same( e.g. ADC: 0-255, PWM: 50-100)
    '   Arduino Map function to emulate:
    '   map(value, fromLow, fromHigh, toLow, toHigh)
    '   long map(long x, long in_min, long in_max, long out_min, long out_max)
    '     return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
    '   Need to split up the operations to get full value using DIV32
    '   50% PWM step range
        'LEDBrIndx = ((compVal - 0) * (numSteps - numSteps/2))
        'LEDBrIndx = DIV32 (MaxADCVal - 0) + numSteps/2
    '   90% PWM step range
        LEDBrIndx = ((compVal - 0) * (numSteps - numSteps/10))
        LEDBrIndx = DIV32 (MaxADCVal - 0) + numSteps/10
    '*********** Set duty registers ****************************************
    ChngLEDBrightness:
        CCP1CON.4 = PWMDuty.0
        CCP1CON.5 = PWMDuty.1
        CCPR1L    = PWMDuty >> 2
    I get this error:
    [ERROR] nacelle_steady-on_lights_12F1840_16Mhz_int_v9.pbp (74) : Syntax error
    I have copied the 3 INCLUDES to C:\Program Files (x86)\PBP3.1 and made sure MicroCode Studio Plus is set to use the MPASMX assembler. Why won't this work now with PBP 3.1?
    Default Re: PBP3 Code Does not Compile with PBP3.1
    SPBRGH = 1
    Is a syntax error
    needs to be
    SP1BRGH = 1
    imho the pbp3 include file is incorrect
    from PIC12F1840.PBPINC
    SP1BRG VAR WORD EXT ; Joined SFR, BANK3
    SP1BRGL VAR BYTE EXT ; BANK3
    SP1BRGH VAR BYTE EXT ; BANK3
    Is a syntax error
    needs to be
    That's it! Thank you so much Richard. I've got both lines in my code but with comments as to which to use with which compiler.
    Dr. Bob at HidMaker informed me that using PBP3.1 requires MPLABX, which doesn't like .bas extensions. I converted my Include files to .pbp. I don't know if it's absolutely necessary, but everything is working. I see you have 3 .bas Include files. Are they working with the PBP3.1 just fine?
    Mike
    Mike
    All my code projects compiles just fine with .bas INCLUDEs. So far.
    If that's true I'm pretty sure it still "only" applies to when you're actually using MPLABX as your IDE. If your using MicroCodeStudio or another IDE you're not really using MPLABX - but PBP relies on the assembler and its device specific include files that comes with MPLAB(X).
  1. PBP3 Compile Errors
    By hjguitarplayer in forum mel PIC BASIC Pro
    Last Post: - 26th August 2015, 23:34
  2. Replies: 1
    Last Post: - 4th April 2013, 01:31
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 16:05
  4. Pbp3
    By rcbandwidth in forum mel PIC BASIC Pro
    Last Post: - 18th September 2011, 14:13
  5. What's with PBP3?
    Last Post: - 10th August 2011, 17:09
Members who have read this thread : 27
