PBP registration does not stick, still unregistered
Results 1 to 4 of 4
    Oct 2009
    Utah, USA
    Default PBP registration does not stick, still unregistered
    Hey group,
    Sent an email to MELABS regarding this problem, but I thought I'd check here as well as I won't hear back from MELABS till tomorrow or later.
    I recently moved to a newer computer (windows 10) and when I run microcode studio MCSX it tells me that my registration is not complete and gives me a popup window do to the registration (showing minus one (-1) day left)
    When I fill in my name, email, and registration code and choose on-line registration it tells me the registration is good.
    But then when I try and compile a program it pops up again with the reg popup.
    A few weeks ago when I first did the install I must have been running on the trial period but I assume that has run out.
    Can anyone tell me how to make the reg permanent?
    thanks in advance
    dwight
    Dwight
    Default Re: PBP registration does not stick, still unregistered
    You may have let your "install window" lapse... I'd ask them for a new regcode, as long as you have proof of purchase. Let us know how that goes, because I may be in the same boat someday.
    Oct 2009
    Utah, USA
    This did the trick... Thanks to MeLabs!
    dwight
    Try running the PBP Activation Manager directly from the PBP3 program group and run as administrator.
    Start > PBP 3.1 from ME Labs > PBP Activation Manager
    Or
    Start > PBP3 from melabs > PBP Activation Manager
    Right click on the Activation Manager and select "Run As Administrator".
    Charles Leo
    ME Labs, Inc.
    2845 Ore Mill Road STE 4
    Colorado Springs, CO 80904
    719-520-5323
    fax: 719-520-1867
    http://melabs.com
    Dwight
    Oct 2009
    Utah, USA
    Easy Fix!!...
    Thanks Charles
    Or
    Charles Leo
    ME Labs, Inc.
    719-520-5323
    Dwight
  1. Registration Problems.
    By fanman in forum mel PIC BASIC
    Last Post: - 12th December 2011, 12:15
  2. Registration
    By lester in forum PBP & Amicus18
    Last Post: - 8th May 2011, 11:13
  3. PBPL and MPLAB ... registration ?
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2007, 17:17
  4. USB memory stick
    By Demon in forum mel PIC BASIC Pro
    Last Post: - 12th July 2005, 20:57
