MPLABX shows PBP Plugin Update; Won't Install
Results 1 to 6 of 6
    Default MPLABX shows PBP Plugin Update; Won't Install
    Hi - I have MPLABX 3.55 with PBP Plugin 3.1.0.1 installed.
    Every time I open MPLABX it announces that an update to the PBP Plugin is available.
    It says: "The following plugins will be updated: PBP Tool Chain [3.1.0.1 -> 3.1.0.2]"
    When I click "Next" it downloads and installs and tells me to restart MPLABX to complete the installation.
    But when MPLABX restarts, it once again tells me that the update is available. It did not successfully install but gives no error message.
    Anybody else have this issue?
    Default Re: MPLABX shows PBP Plugin Update; Won't Install
    Nevermind...
    Researching this issue, I discovered that there was a later version of MPLABX (3.61).
    Updating MPLABX allowed the PBP Plugin to install.
    Sep 2009
    Does syntax highlighting work?
    I'm stuck with 2.35. I tried few newer versions but lot of thing's doesn't work, so I just give up from updates, and stuck with what I can use...
    Quote Originally Posted by chicowoodhill View Post
    Ooops...I was wrong.
    Given a bit of time, the latest version of MPLABX still won't update the plugin to 3.1.0.2. Darn.
    The PBP project compiles and runs in MPLABX v3.61. I can set breakpoints and step. Interestingly, I don't see syntax highlighting in the .pbp file but I see it in the included .inc file.
    That's not a deal breaker for me...I wonder if changing the .pbp extension to .bas would enable syntax highlighting? Or does Netbeans provide a way to see a .pbp file as a source file for highlighting purposes?
    Still can't get MPLABX to install the 3.1.0.2 plugin, even though it tells me it's available and seems to install it....????
    mine does the same thing, I thought it may be because I uninstalled pbp3.1 trial
  1. To install PBP in MPLAB X 1.95
    By pedja089 in forum Documentation
    Last Post: - 5th September 2016, 18:04
  2. File won't compile in PBP 2.6
    By mikejp56 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2016, 21:29
  3. Can't install PBP v2.46 on Windows 10
    By Demon in forum General
    Last Post: - 15th April 2016, 05:59
  4. PBP update ??
    Last Post: - 18th January 2011, 15:56
  5. Can't find "Install MPLAB Plugin"
    Last Post: - 20th March 2010, 04:22
