Loading EEPROM
Results 1 to 7 of 7
Thread: Loading EEPROM
    Default Loading EEPROM
    How to enter the initial starting value into eeprom for a word
    variable?
    For example, suppose the variable is:
    VITtime var word
    it will be read from eeprom in 2 bytes, say:
    read 0, VITtime.byte0
    read 1, VITtime.byte1
    Suppose I want the initially programmed numerical value in eeprom to be 365 (a word size number)
    I usually use the EEPROM statement to enter initial numbers. Should it be:
    EEPROM [5,36,....... .....]
    or
    EEPROM [65,3,.............]
    or
    EEPROM [365,.............]
    or what?
    To load 365 in an eeprom location at programming time it would be:
    data 109, 1
    or
    data %1101101,%1
    This comes from breaking down the bits in the bytes of the word variable
    decimal 365 = 0000 0001 0110 1101 binary
    Since there are 8 bits to a byte, we now know that byte0 is 0110 1101b and byte1 is 0000 0001b. Convert these to decimal and you get 109 and 1 respectively. Both commands will accomplish the same thing.
    You can also use:
    write address, variable.Byte1
    write address, variable.Byte0
    and
    read address, variable.Byte1
    read address, variable.Byte0
    This way can be done anywhere in the program. The DATA command is used to pre-load the eeprom location at time of programming.
    OR, if you didn't feel like breaking down every word sized number manualy, you can let the compiler help you out.
    Days   CON    365
    Dogs   CON   1024
    Mice   CON  10000
    EEPROM [Days&$FF, Days>>8, Dogs&$FF, Dogs>>8, Mice&$FF, Mice>>8]
    Which would load ...
    109, 1, 0, 4, 16, 39
    It may seem a little awkward, but it's easier to make changes later on.
    <br>
    Thanks guys .... it works.
    And, I completely forgot about the WORD modifier for the DATA statement.
    DATA WORD 365
    This would also store it as ...
    109, 1
    <br>
    I hope Bruce and Melanie weren't watching
    Now that is something I didn't know! Man that really makes things a lot easier. I'll have to try that when I get back in to office.
    Quote Originally Posted by Darrel Taylor
    I'm not one of the above but... i saw you
    KISS programming, is the best way. We often forget the base of it.
    Last Post: - 18th February 2010, 15:46
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 05:07
  3. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    By TONIGALEA in forum mel PIC BASIC Pro
    Last Post: - 6th July 2004, 20:59
