Fuses issue on 16f884.... Locked out ??
Results 1 to 8 of 8
    May 2012
    Merseyside, UK
    Angry Fuses issue on 16f884.... Locked out ??
    Hi Wonder if anyone can help.... I have locked myself out of 3 x 16f884's I think with fuses in the configuration ??
    I am using MPASM.... The fuse details look like this:-
    ;*  16F884.INC                                                  *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2009 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 07/02/09                                        *
    ;*  Version   : 2.60                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            include 'M16F88x.INC'	; PM header
            device  pic16F884, intrc_osc_noclkout, wdt_on, mclr_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F884, r = dec, w = -302
            INCLUDE "P16F884.INC"	; MPASM  Header
            __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    	__config _CONFIG2, _WRT_OFF
            NOLIST
            LIST
    When I go to reprogram I get :-
    Device is data protected! Data memory may be invalid.
    Device is code protected! Program memory may be invalid.
    Can anybody help ?? Can I clear the protection so I dont loose the chips :-)
    Thank you for reading
    BR
    Andy
    Default Re: Fuses issue on 16f884.... Locked out ??
    Code protection does not (should not) prevent the device from being erased and when it's erased the code protection bits are erased. Besides, your config says CP_OFF so I would THINK the device is NOT actually code protected.
    I see you're using internal oscillator and you have MCLR off, I wonder if this may be related to the issue in the other thread with the bricked 12F675 part.
    Do you need to have MCLR off or can you possibly try another PIC with MCLR on and see if that makes it better?
    What programmer are you using?
    May 2012
    Merseyside, UK
    Hi Thank you for reply....
    I can turn MCLR on see if makes a difference later .....
    But does mean sacrificing an other chip... Got through 5 so far :-)
    programmer is a PicKit 2 I think... Not in office at moment ... It is the default one in MPLAB ?
    BR
    Andy
    May 2012
    Merseyside, UK
    Hi Henrik
    Programmer is a "Picstart Plus"...... But also does exactly same thing with a "Dataman 48-Pro"
    Then turned the MCLR on in the config....programmed up my last 884.... changed some code..... programmed again and now working.
    You are a star..... Thank you. Easy for me to change h/w to put a little RC on the reset
    But why is this a problem ?????
    Thank you again
    Andy
    Wow, PICStartPlus, there's a blast from the past, haven't used mine for probably 10 years.
    Did you read the other thread I linked to?
    The problem occurs when you're using internal MCLR AND internal oscillator. But there's plenty to read on the subject so I won't go into details here.
    If you can use external MCLR that's the easiest way to get around the problem, it's not recommended to use R/C network on the MCLR pin, a simple pullup is enough in 99% of the cases.
    May 2012
    Merseyside, UK
    Well thank you Henrik
    Yes I have just had a look see at the link .......Have saved it for reference .
    Not sure if I can get my 6chips back though.....Be. Good as land fill !!
    Thank you again
    Andy
    Andy, I keep all my old ICs and components in a jar. When I have enough, I put them in a plastic container (margarine or whatever from recycling bin), and throw in any scrap circuits then take everything to local recycling center. Whenever I get a new dude on the job, I just tell them to process these with televisions and computers.
    They can get a surprising amount of gold and other metals back from these garbage parts now.
    May 2012
    Merseyside, UK
    I may just try that :-)
    BR
    Andy
  1. Phase Locked Loop
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 10th May 2011, 16:45
  2. PIC18F1220 locked up
    By eggman in forum mel PIC BASIC Pro
    Last Post: - 8th April 2011, 15:11
  3. 18f series chip locked up
    By glkosec in forum mel PIC BASIC Pro
    Last Post: - 11th August 2009, 07:27
  4. sht75 code locked up
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 13th June 2006, 10:40
