Hello, welcome to our forum.
It looks like you have registered but you have not yet posted and messages. Our requirements are that you must post at least two messages, to allow the moderators to review your registration, before you will be allowed access to the full range of forum areas.
Please make a couple of posts, until then you may see a notice that says you are banned from certain forum areas.
Thank you.
Remove Text Formatting
Loading...
+ Reply to Thread
Results 1 to 9 of 9
    Mar 2017
    Default PIC Basic and Firewing Development Board
    Will a Firewing board work with PIC Basic Experimenter's/Student version?
    Will it work with Chuck Hellebuyck Demo version?
    If no. There is a Chipino development board at Chuck's site that works
    mostly the same.
    Thanks!
    Default Re: PIC Basic and Firewing Development Board
    This might be of interest to you.
    Built in programmer, works with the free PBP student addition
    http://store.melabs.com/prod/DSTICK/DS1.html
    Mar 2017
    MELabs D-Stick is a very well made product.
    All MELabs hardware that includes programmers and boards is 'Professional Grade'.
    The prices are the stumbling block for us.
    The programmers make sense FOR professionals that are billing out a couple grand a day
    when they go to customers site.
    We're lowly little hobbyists.
    Mar 2017
    Back to the Firewing.
    If it works with Experimenters and Chuck versions that will fit in with our plans.
    Then we can compare PIC Basic Firewing language Swordfish and Proton.
    Firewing says it works with MPLAB so that opens door to CCS compiler and
    Byte Craft so that would be welcome.
    We're not to keen on Microchip XC8 compiler mostly because of Microchip unintelligible documentation.
    Yes we're busy beavers.
    Aug 2011
    As far as I know, the Chipino uses a PIC16F886 , so anything that can compile code for that chip should work.
    The PIC18 version of the Firewing board comes with an 18F26K22.
    Firewing and Swordfish only work with the 18F series, and the free Firewing compiler only supports a few devices in the K22 series.
    As with the Chipino, anything that can compile code for an 18F26K22 can be used with the Firewing pic18 board... PBP, Proton, Swordfish, CCS, XC8, etc.
    Getting boards that have a bootloader to interface to anything other than their intended IDE can be a problem.
    If I were you I'd quit trying to mix and match so many different systems.
    Mar 2017
    Let me sort out what you're saying. Firewing first.
    "anything that can compile code for an 18F26K22 can be used with the Firewing pic18 board"
    So. If it is programmed will that wipe out bootloader?
    Leads to: Then it is unusable as one click programmable in Firewing and Swordfish compiler?
    " bootloader to interface to anything other than their intended IDE can be a problem"
    Okay. That's what post is about. How is that problem solved?
    One way it looks like is to just wipeout boot loader and program Firewing as PIC that's on it.
    We can live with that.
    Mar 2017
    About the Chjipino.
    Actually it was a mistake mentioning it in Firewing post.
    " Don't forget, this board will also work with ny Microchip 8 bit compiler. Some examples include the Microchip "C" Compiler, Swordfish, PICBASIC PRO or the PROTON Development Suite. "
    This is from Firewing page.
    A person could just go "Okay. I'll buy it. He says it will work."
    See where it says Gold on PIC Basic.
    That's what's bothering me.
    Does Firewing work with Chuck Hellebuyck and Experimenter's PIC Basic?
    Mar 2017
    Decided to go ahead and get a Firewing 8 bit.
    Can use it with PIC Basic Great Cow Proton Firewing compiler and Swordfish.
    Compile with PICKit3 and blank PIC or bootloaded PIC it comes with.
    Use it with C compilers too.
    It's an Arduino Uno type so can see what that's about.
    Now it's a good investment!
    Mar 2017
    Default 16F88 Supported in Free PBP Student and Free Chuck Hellebuyck Demo Versions
    Listed supported devices for both versions in Notepad file.
    Compared the two.
    That is the one and only device that is supported in both.
    Buy one device and test drive both versions.
  1. RF development board
    By Bruce in forum Adverts
    Last Post: - 26th January 2011, 20:57
  2. Pic Development Board
    Last Post: - 9th September 2010, 17:14
  3. Olimex PIC-LCD development board for sale
    By ScaleRobotics in forum General
    Last Post: - 26th April 2010, 23:32
  4. Development Board Recomendations ???
    By tico in forum mel PIC BASIC Pro
    Last Post: - 27th March 2007, 01:27
  5. Development Board
    By carl_schell in forum Adverts
    Last Post: - 21st July 2004, 08:39
Members who have read this thread : 22
