Is it possible To change baud rate at runtime?
+ Reply to Thread
Results 1 to 3 of 3
    Jun 2016
    Default Is it possible To change baud rate at runtime?
    I need to change The baud rate from 9600 to 115200 and then back to 9600. I did try with define but PBP3 does'nt like it and gives error at compiling. Is there a way To do the baud Switching from 9600 To 115200 and back To 9600? How?
    Thank you for any help.
    Alberto
    Default Re: Is it possible To change baud rate at runtime?
    Absolutely. But you can't use DEFINE because it's a compile time thing.
    You can skip the DEFINE altogether and do it manually all the way, what to set the registers to depends on the oscillator speed. For example, setting 9600 baud when running at 8MHz:
    RCSTA = $90
    TXSTA = $20
    SPBRG = 51
    SPBRGH = 0
    BAUDCON.3 = 1
    Jun 2016
    Thank you Henrik, very kind of you.
    Alberto
  1. How to change baud rate with HSEROUT?
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 17th November 2011, 03:48
  2. Change baud rate on SerLCD
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2010, 19:19
  3. Rf module baud rate
    By tazntex in forum Serial
    Last Post: - 5th August 2008, 18:47
  4. pic18f4520 baud rate change to 115200
    By caltex88 in forum mel PIC BASIC Pro
    Last Post: - 30th September 2007, 08:41
  5. Baud rate calculation
    By Demon in forum Serial
    Last Post: - 21st July 2006, 22:02
