Port Digital Output Not Changing Properly
Results 1 to 6 of 6
    Miami, Florida USA
    Default Port Digital Output Not Changing Properly
    I'm using a 18F4550 PIC code that's running on PBP2.50. I'm pulling my hair out trying to figure out why this code won't work.
    DUMMYVAR VAR BYTE
    TRISB = %00000000        'SET ALL B PORTS AS OUTPUTS
    ADCON1 = %00001111     'SET ALL PORTS TO DIGITAL
    MAIN:
    PORTA.0 = 1
    PORTA.1 = 1
    DO SOME STUFF......
    GOTO MAIN
    PORTA.0 stays low and never changes to high. However, if I do the following, then the code works and I get both ports high.
    DUMMYVAR VAR BYTE
    MAIN:
    DUMMYVAR = 3
    PORTA.0 = DUMMYVAR.0 : PORTA.1 = DUMMYVAR.1
    DO SOME STUFF......
    GOTO MAIN
    So, why does the second code works and the first one doesn't? Do you need a pause or delay when changing individual port settings in the same port bank? Does the commands HIGH and LOW resolve this issue?
    Anonymous
    Default Re: Port Digital Output Not Changing Properly
    classic RMW read modify write
    watch this
    http://www.microchip.com/webinars.mi...cName=en556253
    click on
    View streaming media version:
    Miami, Florida USA
    Richard, wow I wasn't aware of this issue. Check out the following article. It explains in detail exactly what happened in my code.
    https://download.mikroe.com/document...c/help/rmw.htm
    Anonymous
    Miami, Florida USA
    Also, is it possible to use LATCH instead or PORTx.x in PBP? How would you use the LATCH register?
    Anonymous
    yes it's not the most thrilling video but it does explain the issue in easy to understand terms.
    pretty easy for chips with LAT regs
    in your case
    LATA.0 =1
    LATA.1 =1
    note LAT(X) cannot be used with compound commands THAT auto set TRIS regs like SERIN,I2CIN,TOGGLE etc
    Miami, Florida USA
    Thanks Richard. That helps a lot.
    Anonymous
  1. Can't properly configure RA3,Ra4 as digital out (PIC16F876A)
    By luxornet in forum mel PIC BASIC Pro
    Last Post: - 6th July 2014, 16:10
  2. Changing output state after 2 minutes
    By carljbrooks in forum mel PIC BASIC Pro
    Last Post: - 21st February 2014, 05:28
  3. Replies: 11
    Last Post: - 13th January 2013, 10:25
  4. 18F2520 - problem configuring fuse for port B as digital port.
    By hwhisperer in forum mel PIC BASIC Pro
    Last Post: - 11th October 2010, 11:41
  5. open drain output as digital output?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 10th November 2006, 03:11
