+ Reply to Thread
Results 1 to 10 of 10
    Oct 2012
    Default Bootloaders and configs
    Hello everyone,
    I just started collecting documentation on bootloaders and I remember reading somewhere that certain configs must be included in the bootloader.
    Below is my set of configs and defines. I would like to match the bootloaders communication speed with my future Debug communication.
    My question is which of them must go in the bootloader and which can be part of the new .HEX file to be loaded.
    @__config_device_pic16f819
    @__config_wdt_off
    @__config_hs_osc
    @__config_pwrt_on
    @__config_mclr_off
    @__config_lvp_off
    @__config_protect_on
    @__config_CCP1_RB2
    DEFINE OSC 8
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUGIN_REG PORTB
    DEFINE DEBUG_BIT 6
    DEFINE DEBUGIN_BIT 7
    DEFINE DEBUG_MODE 1
    DEFINE DEBUG_BAUD 38400
    DEFINE  ADC_BITS        8
    DEFINE  ADC_CLOCK       3
    DEFINE  ADC_SAMPLEUS    50
    ADCON1=%01001110
    CCP1CON = %00001100
    PR2 = 15
    CCPR1L = 0
    CCP1CON.5 = 0
    CCP1CON.4 =0
    Any input on that will be greatly appreciated.
    Nick
    Default Re: Bootloaders and configs
    Put them all in the bootloader.
    I'd be very leery of letting your bootloader reprogram config settings. If you get them wrong or things hiccup you can end up with a board that won't boot.
    Oct 2012
    Thanks, Tumleweed.
    Are we are talking all configs only?
    The defines can and will be programmed by the new .HEX file. True?
    Nick
    Yeah, I'm talking only about the CONFIG settings.
    Everything else is either a program or register setting that gets done at run-time, so you can always change these.
    Oct 2012
    Thanks again.
    This makes it clear even for a beginner like me.
    Nick
    The CONFIGs definitely needs to be in the bootloader code that gets programmed to the chip using a real device programmer.
    You should not allow the downloaded "application" to change the CONFIG (besides it's not even possible on all PICs) because it might brick it. For example, if the bootloader is written for a board using a HSPLL oscillator running at 32MHz and the user, by mistake or unknowingly, downloads a piece of code that changes the oscillator CONFIG to INTOSC. This bricks the device and you need to reprogram it with a device programmer.
    Oct 2012
    Thank you Henrik for the extra information.
    In my case it should be simple since Iím using an old fashion chip (PIC16F819).
    Iím stuck with quite a few of them in my inventory and I would like to make use of them.
    I will include all the configs in the bootloader and I will make sure the new HEX will have none.
    Thanks again,
    Nick
    Sep 2009
    Hex isn't problem. You can have configs in hex, but application that parse hex file should ignore configs and send only program and eeprom to bootloader. I post simple bootloader code somewhere on forum.
    The 16F series isn't even capable of reprogramming their own CONFIG word(s). For example, on the 16F819, the CONFIG word is at address 2007h and the datasheet says
    It is important to note that address 2007h is beyond the
    user program memory space which can be accessed
    only during programming.
    It also says
    Accessing a location above the
    physically implemented address will cause a
    wraparound.
    So if you TRIED to write to the CONFIG word you'd actually write to another location possibly corrupting the program.
    So yeah, you need to be carefull of what you're doing. I'm curious, the 16F819 doesn't have an UART, are you planning to use bitbanged serial for the download or are you going to inject the new firmware image in some other way (SPI, I2C)?
    Oct 2012
    Hi Team,
    Pedja089 I will search for your post, thank you.
    Henrik, I will have a friend of mine, who knows more assembly than I do, helping with this project.
    We are trying to make small changes, to fit our needs, to this project I found in my research:
    http://pygmy.utoh.org/pikme/
    Right now we are collecting as much information as we can to make sure we are taking the right path.
    Thank you for your advices and interest.
    Nick
  1. Replies: 7
    Last Post: - 24th September 2014, 17:27
  2. recommendations for secure bootloaders
    Last Post: - 29th August 2014, 00:31
  3. 18F6310 configs
    Last Post: - 10th January 2012, 06:47
  4. 18F4520 Configs
    Last Post: - 10th June 2010, 22:18
  5. Getting Configs straight
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 24th January 2007, 04:16
