microcode studio error compile with google drive or dropbox folder sync
Results 1 to 5 of 5
    Feb 2018
    Default microcode studio error compile with google drive or dropbox folder sync
    hello everyone,
    I have a problem when compiling a pbp file inside a folder synchronized with dropbox or google drive using microcode studio plus it gives me the following error: "FOLDER IS READ ONLY, Unable to compile test.pbp.The source is read only" I don't think it's a folder read-only error because I use various files without reading problems
    Thank you very much
    OK
    Default Re: microcode studio error compile with google drive or dropbox folder sync
    Do you have your PBP files (normally found in C://Program Files (x86)/PBP3_1) in the Cloud? If so, do they NEED to be there? Or are the project files (like MyProject.pbp) located in the Cloud (connected folder) and PBP just can't deal with that?
    Feb 2018
    sorry I didn't understand the pbp folder is on the main root of c: and is not synchronized on the cloud C:\PBP3_1 while the folder with the projects is in another example folder of google drive C: \ Users \ mx \ Google Drive \ PB3_PROTEUS_Sync. I didn't understand much. Maybe you mean that pbp3 folder must be in the same folder as google drive?
    OK
    I don't use Cloud based services in that manner, so I never experienced your issue. You may have to create a folder in your Documents while working on the project, then copy/paste it into your Could connected folder. Pain in the X@$$? Yes, probably. That's the best advice I can offer.
    I do use the Project folder inside Dropbox folder where my programs are stored. That way I can work on every computer that is connected to Dropbox.
    I think OneDrive may be better because Dropbox has a limit of 3 PCs I think.
    Anyway, for me it works OK most of the time. Sporadically the files that compilers tries to alter in following compilation fail to update with an error message but an immediate compilation succeeds OK. I can take it that much.
  1. Microcode studio will not compile
    By Alexey in forum mel PIC BASIC Pro
    Last Post: - 6th November 2015, 22:48
  2. Microcode Studio lost feedback on compile
    By tasmod in forum General
    Last Post: - 22nd July 2012, 09:38
  3. compile problem microcode studio plus 3
    By mkydj73 in forum mel PIC BASIC Pro
    Last Post: - 17th August 2011, 10:38
  4. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 19:35
  5. Microcode Studio Plus compile/assmebly errors
    By mikehagans in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 21:31
