Terminal Program for TCP
Results 1 to 2 of 2
    Default Terminal Program for TCP
    Unless, as in the past, I am behind in technology and this is readily available,
    In the interest of easier communications with PIC over IP network, and ultimately a SSE.... server side events type protocol so PIC data can be easily viewed on a web page, I have a (pretty good so far) windows terminal program made in vb.net.
    Any interest in that functioning to work on this task.
    Basically, I use a wifi module in serial pass-through mode. My terminal allows viewing of data, sending( continuous or on-button press) and differing views of data, hex, ascii, dec and later filtering..... so far you can connect to it from a web page and test your response's back so ultimately you can place your responses in PIC memory for sending.
    Default Re: Terminal Program for TCP
    Very nice.
    George
  1. PBPL and TCP/IP
    By edtp in forum Ethernet
    Last Post: - 4th March 2011, 20:35
  2. PBPL and TCP/IP
    By edtp in forum Code Examples
  3. PIC and TCP/IP
    By jscoulter in forum mel PIC BASIC Pro
    Last Post: - 17th September 2009, 12:21
  4. Replies: 1
    Last Post: - 16th September 2008, 17:27
