Is it allowed to change pin reference within a subroutine?
Results 1 to 19 of 19
    Jun 2016
    Default Is it allowed to change pin reference within a subroutine?
    I am using three temperature sensors wired to three different pins (portB.5 - portB.6 and portB.7)
    Now I am using three different sub-routine to read the sensors value, but since all the routine have the same code, I would like to have one single routine for all the three sensors, just changing the alias reference within the sub-routine. In other words, something like this:
    Read_Sensors:
    If index = 0 then return
    If index > 3 then return
    If index = 1 then use_pin = portB.5
    If index = 2 then use_pin = portB.6
    If index = 3 then use_pin = portB.7
    Read sensor using "use_pin"
    Load variable[index]
    The above code could it work?
    If the answer is yes, how do I declare the alias "use_pin"? (Byte or Word)
    Alberto
    Default Re: Is it allowed to change pin reference within a subroutine?
    bit indexing
    inx var byte [in pbp a bit index cannot exceed 255]
    PORTB.0[inx]
    if inx = 5 then it references portb.5
    if inx = 7 then it references portb.7
    Won't do what you want. use_pin will be be assigned the value of PortB.5 (1 or 0), you can't change aliases at runtime.
    Do it the way Richard shows.
    Jun 2016
    Thank you Richard & Henrik for the tips!
    I did try the code below without success. It display 00.00 for all sensors. Did I mistake something?
    Dindex var byte
    CIndex var byte
    if CIndex = 1 Then Dindex = 5
    if CIndex = 2 Then Dindex = 6
    if CIndex = 3 Then Dindex = 7
    owout PortB.0[Dindex],1,[$CC,$44]
    owout PortB.0[Dindex],1,[$CC,$BE]
    owin PortB.0[Dindex],0,[STR Dta\9]
    Alberto
    won't fly
    OWOUT Pin, Mode,[Item...]{,Label}
    Pin may be a constant, 0 - 15, or a variable that contains a number 0 15 (e.g. B0) or a pin name (e.g. PORTA.0).
    pin mapping is a bit vague in tne book
    pin 0 is maybe porta.0 pin 15 might be portb.7 I think it can vary from chip to chip too
    there is reference to it somewhere in the basic_stamp compatability notes , but I can no longer find it
    so
    mypin=13
    owin mypin,[STR Dta\9] is a legal construct
    from the book
    7.6.5 Applying Offsets to Bits within a Variable or Register
    The array mechanism in PBP offers a solution. An offset enclosed in brackets may
    be written after the bit number:
    PORTB.0[x] = 1 ' Set RBx high
    The actual effect of this is to add the value of x to the numeric bit number.
    x = 2
    PORTB.4[x] = 1 ' Set bit(4+x) high. In this case, bit-6 is set.
    NOTE THAT
    PBP COMMANDS WON'T ACCEPT THIS SYNTAX for command parameters. This method can only be used in expressions and with direct register
    access. You CANNOT write:
    HIGH PORTB.0[x] ' COMPILE ERROR
    COUNT PORTB.0[x], 100, y ' COMPILE ERROR
    found the pin map in my old pbp2.60c notes'
    8       pin  chips   0-7 gpio   8-15  gpio
    14/20   pin  chips   0-7 porta  8-15 portc
    18      pin  chips   0-7 portb  8-15 porta
    28      pin  chips   0-7 portb  8-15 portc
    40      pin  chips   0-7 portb  8-15 portc
    Jun 2016
    PBP manual states that in 28 pins mcu portB = 0-7!
    I did try:
    Use_pin = 5
    Owin use_pin,0,[strDta\9]
    But it doesn't work.
    How can I verify If the numbers (5/6/7) I am using are correct or no?
    Many Thanks for the help.
    Alberto
    small steps like this is how I would try it
    what chip ?
    Owin portB.5 ,0,[strDta\9]
    does this work?
    Owin 5 ,0,[strDta\9]
    does this work?
    mypin var byte
    mypin=5
    Owin mypin ,0,[strDta\9]
    Jun 2016
    pic 18F2620
    Owin portB.5 ,0,[strDta\9] (works!)
    Owin 5 ,0,[strDta\9] (works!)
    mypin var byte
    mypin=5
    Owin mypin ,0,[strDta\9] (doesn't work!)
    Not very elegant but this way it works!
        One_W1  var PortB.5
        One_W2  var PortB.6
        One_W3  var PortB.7
        if CIndex = 1 Then
        owout One_W1,1,[$CC,$44]
        owout One_W1,1,[$CC,$BE]
        owin One_W1,0,[STR Dta\9]
        if CIndex = 2 Then
        owout One_W2,1,[$CC,$44]
        owout One_W2,1,[$CC,$BE]
        owin One_W2,0,[STR Dta\9]
        if CIndex = 3 Then
        owout One_W3,1,[$CC,$44]
        owout One_W3,1,[$CC,$BE]
        owin One_W3,0,[STR Dta\9]
    Alberto
    well that should have worked. i don't have one of those chips handy to try any thing.
    maybe the manual is incorrect and pin must be a constant not a var.
    but it says everywhere (or a variable that contains a number 0 15 ) not just that command
    you can always stick them all on the one wire and use the
    MATCH ROM [55h] command rather than skip rom [CCh]
    if CIndex = 1 Then
    you realise of course the ow device takes 750mS or so to complete the conversion
    before the read scratch pad can occur or you can poll the busy state
    In following this thread I have to ask, Why are you not using 1 wire? Why are all of the devices on separate pins? It would make your code so much easier.
    EN82fn
    Jun 2016
    No! I didn't realise the convertion was such a slow process!
    Well I need to modify the code to cope with this necessary delay.
    Thank you Richard to have brought to my attention this problem.
    Alberto
    Edited: Dave, the reason for not using a single pin for all 3 devices using match rom comand is simple: I did try but I failed! But now that I am aware of this long delay necessary for the convertion time, I am happy to have choosen the three separate pins, becouse in this way I can split the delay of 750 milliseconds and get all three values in 750. - 800 milliseconds.
    Alberto, If you operate the sensors off local VDD instead of Parasitic power you can start each conversion and then check for each to be finished while the others are doing there conversions. That is the problem with Parasitic power in that you can only communicate with 1 device on the bus.
    EN82fn
    Jun 2016
    Dave, I am not using "parasitic power" and I understand the convenience to use a single bus for all three devices. But the failure in using "search rom" and "match rom" command, along with my strong desire to see the project working and so many unused pins on my mcu brought me to the conclusion to choose the simpler way and get the project working.
    Now that everything seems working as per my need, I could try to modify the way of reading the DS18B20, but need some help. I need a code snippet that shows How to use properly the search rom and the match rom comand.
    So If anybody can help me in understanding, How to use these two commands I will be gratefull, since I got sick for the number of Times I have read the device data sheet.
    So again thank you for any help given.
    Alberto
    Jun 2016
    WHOA! What a great gift I have received! Thank you Richard for the link, the code is over any expectation of mine!
    I should learn how to search the forum properly, because the link didn't show up during my search.
    Alberto
    Alberto, Here is a routine I wrote some years ago. I hope it helps.
    ' PROGRAM: 1_WIRE_SEARCH.bas
    ' WRITTEN BY DAVID PUROLA 9/18/2003
    ' WRITTEN FOR PIC18F452-I/L MICROPROCESSOR
    ' Declare Variables
    SCRATCH VAR WORD 'SCRATCH VARIABLE
    SCRATCH1 VAR BYTE 'SCRATCH VARIABLE
    CRCData VAR Byte 'CRC CUMULATIVE DATA BYTE
    CRC VAR Byte 'CRC ENDING BYTE
    ONEWIRE VAR BYTE 'ONE WIRE RECEIVED DATA
    ID_BIT VAR BIT 'ID BIT STATE
    CMP_ID_BIT VAR BIT 'ID BIT COMPLEMENT
    ID_BIT_NO VAR BYTE 'ID BIT COUNTER
    LASTDEVFLG VAR BIT 'LAST DEVICE HISTORY BIT
    LASTDESC VAR BYTE 'LAST DEVICE DESCRIPTION
    LASTFAMDESC VAR BYTE 'LAST DEVICE FAMILY DESCRIPTION
    LAST_ZERO VAR BYTE 'LAST ZERO COUNTER
    ROM_NO VAR BYTE(8) 'STORAGE AREA FOR CURRENT ROM SERIAL NUMBER
    SEARCHDIR VAR BIT 'SEARCH DIRECTION BIT
    OK VAR BIT 'VALID DATA FLAG
    DALLAS_NO VAR BYTE 'DEVICE FOUND NUMBER
    DEVICES VAR BYTE(80) 'STORAGE LOCATIONS FOR 10 DEVICE SERIAL NUMBERS
    CLEAR
    'MAIN LOOP FOR PROGRAM
    MODE1: 'DO ROM SEARCH FOR ANY DEVICES
    FOR SCRATCH = 0 TO 7 'clear rom number for first search
    ROM_NO[SCRATCH] = 0
    NEXT
    DALLAS_NO = 255
    LASTDEVFLG= 0
    OK = 1
    WHILE LASTDEVFLG = 0
    GOSUB ONEWIRE_SEARCH
    IF OK = 1 THEN
    DALLAS_NO = DALLAS_NO + 1
    LCDOUT $fe,$80,"TOTAL ROM NUMBERS FOUND= ",DEC2 DALLAS_NO + 1
    DEVICES[(DALLAS_NO * 8) + SCRATCH] = ROM_NO[SCRATCH]
    NEXT
    WEND
    'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    ' DISPLAY ANY DEVICES FOUND
    FOR SCRATCH1 = 0 TO DALLAS_NO
    LCDOUT $fe,$C0,"SEARCH= "
    FOR SCRATCH = 7 TO 0 STEP -1
    LCDOUT HEX2 DEVICES[(SCRATCH1 * 8) + SCRATCH]
    NEXT
    LCDOUT " ",DEC2 SCRATCH1 + 1
    PAUSE 1000
    NEXT
    GOTO MODE1
    ' Subroutines
    ONEWIRE_SEARCH:
    OWOUT SDA,1,[$F0] 'SEND RESET & SEARCH ROM COMMAND
    IF LASTDEVFLG = 1 THEN
    GOTO TWO
    ID_BIT_NO = 1
    LAST_ZERO = 0
    RESEARCH:
    OWIN SDA,4,[ID_BIT]
    OWIN SDA,4,[CMP_ID_BIT]
    IF ID_BIT = 1 AND CMP_ID_BIT = 1 THEN
    GOTO TWO
    IF ID_BIT = 0 AND CMP_ID_BIT = 0 THEN
    IF ID_BIT_NO = LASTDESC THEN
    SEARCHDIR = 1
    IF ID_BIT_NO > LASTDESC THEN
    SEARCHDIR = 0
    SEARCHDIR = ROM_NO.0[ID_BIT_NO - 1]
    IF SEARCHDIR = 0 THEN
    LAST_ZERO = ID_BIT_NO
    IF LAST_ZERO < 9 THEN
    LASTFAMDESC = LAST_ZERO
    SEARCHDIR = ID_BIT
    ROM_NO.0[ID_BIT_NO - 1] = SEARCHDIR
    OWOUT SDA,4,[SEARCHDIR]
    ID_BIT_NO = ID_BIT_NO + 1
    IF ID_BIT_NO > 64 THEN
    LASTDESC = LAST_ZERO
    IF LASTDESC = 0 THEN
    LASTDEVFLG= 1
    GOTO THREE
    GOTO RESEARCH
    THREE:
    CRC = 0
    CRCData = ROM_NO[SCRATCH]
    GOSUB CRC8LU
    NEXT
    IF CRC = 0 THEN 'GOOD ROM READBACK ADDRESS
    OK = 1 'SET FLAG TO STORE ADDRESS
    TWO:
    LASTDEVFLG = 0
    LASTDESC = 0
    LASTFAMDESC = 0
    OK = 0
    ' ********** Subroutine CRC8LU **********
    ' Expects CRC at some starting value with data to CRC
    ' passed in CRCData.
    ' Gives ending CRC value and destroys CRCData
    ' Uses CRCData-Byte, CRC-Byte
    CRC8LU:
    CRCData = CRCData ^ CRC
    Lookup CRCData,[0,94,188,226,97,63,221,131,194,156,126,32,163,253, 31,65,_
    157,195,33,127,252,162,64,30,95,1,227,189,62,96,13 0,220,_
    35,125,159,193,66,28,154,160,225,191,93,3,128,222, 60,98,_
    190,224,2,92,223,129,99,61,124,34,192,158,29,67,16 1,255,_
    70,24,250,164,39,121,155,197,132,218,56,102,229,18 7,89,7,_
    219,133,103,57,186,228,6,88,25,71,165,251,120,38,1 96,154,_
    101,59,217,135,4,90,184,230,167,249,27,69,198,152, 122,36,_
    248,166,68,26,153,199,37,123,58,100,134,216,91,5,2 31,185,_
    140,210,48,110,237,179,81,15,78,16,242,172,47,113, 147,205,_
    17,79,173,243,112,46,204,146,211,141,111,49,178,23 6,14,80,_
    175,241,19,77,206,144,114,44,109,51,209,143,12,82, 176,238,_
    50,108,142,208,83,13,239,177,140,174,76,18,145,207 ,45,115,_
    202,148,118,40,171,245,23,73,8,86,180,234,105,55,2 13,139,_
    87,9,235,181,54,104,138,212,149,203,41,119,244,170 ,72,22,_
    233,183,85,11,136,214,52,106,43,117,151,201,74,20, 246,168,_
    116,42,200,150,21,75,169,247,182,232,10,84,215,137 ,107], CRC
    ' PBP only handles 255 constants in the list (256 for 18Cxxx). Since table is
    ' indexed starting at zero, special case for $FF (256th element).
    If CRCData = $FF Then
    CRC = 53
    EndIF
    EN82fn
    Jun 2016
    Thank you Dave for the code posted.
    At the late, I should start playing with the code next Friday. I am sure I will came back with more question on this subject!
    By now thank you again for your kindness.
    Alberto
  1. Replies: 8
    Last Post: - 21st March 2015, 17:21
  2. 10F222 Wake on pin change
    By AvionicsMaster1 in forum PBP3
    Last Post: - 9th January 2014, 19:14
  3. Reference a port pin from a variable
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 15th February 2012, 20:18
  4. Interrupt-on-Change-pin!
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 11th February 2009, 20:22
  5. HELP !!! How change the voltage of a pin ????
    By stormdacta in forum mel PIC BASIC Pro
    Last Post: - 21st August 2007, 20:55
