Ebay HC-12 wireless transceivers
Results 1 to 10 of 10
    Mar 2008
    Default Ebay HC-12 wireless transceivers
    Has anyone used the HC-12 wireless RS-232 modules on ebay? My modules seem to work fine with Arduino but I am having no luck using a 16F628A/16f616. Very simple code below returns
    4
    8
    2
    96
    128
    32
    16
    32
    32
    32
    16
    128
    96
    4
    16
    64
    128
    128
    Transmitter Code 16F616:
    Tx:
    SEROUT PORTC.5,6,[2] 'sends 2 to the HC-12 every 3 seconds
    PAUSE 3000
    GOTO TX
    Receiver Code 16F628A:
    OVER:
    SERIN2 PORTB.2,16468,3000,OVER,[V1]
    IF V1 = 0 THEN GOTO OVER
    SEROUT PORTB.5,6,[#V1,10] 'Output to serial Monitor
    GOTO OVER
    Dec 2010
    Default Re: Ebay HC-12 wireless transceivers
    Break down the problem - connect the 16F616 pin C.5 to the 16F628A pin B.2 with a piece of wire and make that work first.
    GND on both devices should be tied together too.
    Mar 2008
    Quote Originally Posted by Charlie View Post
    It works as expected when wired direct.
    which would be not at all
    tx true level @38400 baud
    rx inverted @9600 baud
    Mar 2008
    It works for sure when wired direct.
    If you take a look at the third 9600bps mode " http://melabs.com/resources/ser2modes.htm " you will find that 16468 is indeed 9600 inverted when using serin2 as is mode 6 when using serout. I am running inverted since I am wired direct and not thru a set of MAX232 ics.
    ok [I was thinking serout2]
    are you sure the signal needs to be inverted , I have not used these modules but the code here is using true levels
    http://www.picbasic.co.uk/forum/showthread.php?t=20869
    there is also mention of setting the module correctly re baud rate and fu_x
  1. Reflow Oven in Ebay
    By rsocor01 in forum Off Topic
    Last Post: - 20th December 2013, 10:37
  2. eBay Auction (no reserve)
    By T.Jackson in forum Adverts
    Last Post: - 13th June 2008, 15:06
  3. PicBasic Pro Ebay Auction
    By tonyfelloni in forum Adverts
    Last Post: - 10th January 2008, 11:09
  4. has anyone used chipcon transceivers?
    By grahamwebb2000 in forum General
    Last Post: - 28th June 2006, 20:29
  5. Transceivers with 2 different PICs.
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2006, 09:31
