DIV32 calculation with PBP3 version 3.0.6.0
Results 1 to 6 of 6
    Feb 2009
    Default DIV32 calculation with PBP3 version 3.0.6.0
    Hallo All Forum participants,
    Forgive me please for battling with the previous messages. At last here is my question.
    I am using a 12F683, Periperal interupt register flag and Timer1, to accumalate OSC ticks (4MHZ/4) in uSec's and then trying to converting the ticks to a new value. The number of uSec ticks is taken in a 1 mSec period. (1000). All my variables are word sized.
    Using the number of ticks, mutiplied with 1000, my calculation with DIV32 does not give the wanted result.
    I then tried the DIV32 sample from the manual.: 500 * 1000 = 500000, DIV32 100 should be 5000.
    With the above values from the manual the result is 65535.
    Is there perhaps some-one that can guide me in the right direction please.
    Default Re: DIV32 calculation with PBP3 version 3.0.6.0
    works for me , why not post you code
    Feb 2009
    Hi Richard,
    Thanks for replying to my question.
    I use MPLAB IDE version 8.90.
    In my version of MPLAB IDE I could not find reference to PBPW
    Could the problem be related to PBPW ?
    Thanks again
    The code:
    '* Name : BALLISTIC SPEED INDICATOR *
    '* Author : Danie Joubert George South Africa *
    '* adaptation from existing program in Forum *
    '* Target : 12F683 with 4Mhz Internal Osc. *
    '* ALGORYTHM for measuring pulse width using CCP
    '* 1. Configure CCP to capture on rising edge
    '* 2. Enable ccp capture
    '* 3. Start TIMER1
    '* 4. Reconfigure CCP to capture on falling edge
    '* 5. Read and save timer values
    '* 6. Display timer value on Serial LCD
    ' Pin 1 = Pos 5V with 0.1uF cap to Gnd
    ' Pin 2 GPIO.5 = N/C - output
    ' Pin 3 GPIO.4 = N/C - output
    ' Pin 4 GPIO.3 = 10k resistor MCLR
    ' Pin 5 GPIO.2 = CCP1 Pulse input from Set/Reset NAND
    ' Pin 6 GPIO.1 = Serial out to display
    ' Pin 7 GPIO.0 = N/C - output
    ' Pin 8 = 0/Volt
    include "modedefs.bas" ';;; Include file for comms
    ';;; Configs for PBP3
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF
    GPIO = %00000000 ';;; All inputs low
    CMCON0 = %00000111 ';;;' Value "7" Turn comparators off
    TRISIO = %00000100 ';;; GPIO.2/CCP1 = Input rest output
    OSCCON = %01100000 ';;; 4 M/Hz Osc
    ANSEL = %00000000 ';;; Set all digital
    define OSC 4
    DEFINE CHAR_PACING 10
    capture_int_flag VAR PIR1.5 ';;; Periperal interupt register flag - bit 5 (Input=GPIO.2)
    serial_out_pin var GPIO.0 ';;; Pin 7
    capture VAR WORD ';;; capture value
    pulse_width var word
    calc1 var word
    timer_high var word
    timer_low var word
    INTCON = 0 ';;; Interrupts off
    pause 1500 ';;; Give SERLCD a chance to start up
    SEROUT serial_out_pin,T9600,[$FE,$01] ';;; Set Baud rate and clear Display
    pause 50
    SEROUT serial_out_pin,T9600,[$FE,$80, " BALISTIC "] ';;; Text on first line of display
    pause 50
    SEROUT serial_out_pin,T9600,[$FE,$C0, " CHRONOGRAPH "] ';;; Text on second line of display
    pause 50
    measure:
    CCP1CON = %00000101 ';;; Configure capture mode for rising edge
    T1CON = %00000000 ';;; TIMER1 = OFF, prescale = 1, clock = Fosc/4,
    TMR1H = 0 ';;; Clear high byte of TMR1
    TMR1L = 0 ';;; Clear low byte of TMR1
    capture_int_flag = 0 ';;; Clear capture int flag bit
    calc1 = 0
    pulse_width = 0
    While ! capture_int_flag ';;; Wait here for capture on rising edge
    Wend
    T1CON = %00000001 ';;; TIMER = ON, prescale = 1, clock = Fosc/4
    capture_int_flag = 0 ';;; Clear capture interrupt flag bit
    CCP1CON = %00000100 ';;; Configure capture mode for falling edge
    While ! capture_int_flag ';;; Wait here until capture on falling edge
    Wend
    ' Falling edge detected
    capture.HighByte = CCPR1H
    capture.LowByte = CCPR1L ';;; works fine up to here
    calc1 = 500 * 1000 ';;; My own values just for testing first
    pulse_width = div32 100 ';;; this results is 65535
    SEROUT serial_out_pin,T9600,[$FE,$01] ';; Set Baud rate and clear Display
    pause 50
    SEROUT serial_out_pin,T9600,[$FE,$80, # capture] ';;; Display tick count on first line
    SEROUT serial_out_pin,T9600,[$FE,$C0, # pulse_width] ';;; test calculated pulse width on second line
    GOTO measure
    at least one of the values in the calculation must be a var.
    eg
     capture=500
     calc1 =  capture * 1000 ';;; My own values just for testing first
     pulse_width = div32 100 ';;; this results is correct
    ps when you post code use the code tags , the forum will mess things up format wise without them
    Feb 2009
    Richard,
    Thanks for reply. I will immediately try your suggestion and will report back.
    Feb 2009
    Richard, I used variables in the calculation as per your reply. The result now 100%. Thanks again, much appreciared
  1. PBP3 version history?
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 6th November 2012, 17:33
  2. New PBP version - Gold version - Is it really worth it?
    By financecatalyst in forum General
    Last Post: - 8th October 2011, 02:34
  3. DIV32 Questions ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 10th November 2007, 01:49
  4. Div32
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2007, 21:26
  5. DIV32 confusion
    By dmairspotter in forum mel PIC BASIC Pro
    Last Post: - 7th October 2005, 22:24
