* Analog and Digital
Results 1 to 6 of 6
    Aug 2008
    Default * Analog and Digital
    Hello
    And you need to set up 2 analog ports and 4 digital ports
    Analog ports work well the buttons do not work
    I am in doubt about the configuration of adc
    Can anybody help me
    About this
    Here the schematic of pic18f2550
    clear
    DEFINE OSC 48
    define LOADER_USED 1 'USB carregador de inicialização
    define RESET_ORG 1000h
    '--- Setup ADC -------------------------------------------------------------
    TRISA=%11111111:PORTA=%00000000
    TRISB=%00000011:PORTB=%00000000
    TRISC=%11000010:PORTC=%00000000
    ADCON1= %00001100
    ADCON2.7 = 1 'Right-justify result in ADRESH:ADRESL
    Define ADC_BITS 10 'Set number of bits in result
    Define ADC_CLOCK 3 'Set clock source (3=rc)
    Define ADC_SAMPLEUS 50 'Set sampling time in uS
    Thank you
    Default Re: * Analog and Digital
    What value are you reading on A0 and A1?
    George
    Aug 2008
    Hello, how are you
    The port AO and A1 will read 2 battery
    And it will show on the LCD that it is not in the scheme there.
    I'm not getting the input and output port configuration
    thank you
    So what value do you actually read on A0 and A1 ( a number somewhere between 0 and 1023)?
    George
    Aug 2008
    Yes
    I already have the channel reading AO and AI
    My problem and the buttons that do not work on other channels
    I have not eaten them two buttons
    OK
    Sorry I didn't read your original post correctly, show more code.
    George
  1. Analog Digital Conversion ??
    By gunayburak in forum General
    Last Post: - 28th December 2012, 17:52
  2. analog and digital
    Last Post: - 10th June 2008, 03:40
  3. digital to analog conversor
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 21:46
  4. PortA analog and digital IO
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 30th November 2007, 03:25
  5. Digital to Analog Converter
    By kutsi in forum mel PIC BASIC Pro
    Last Post: - 27th June 2007, 20:17
