Programming RFM radio modules in Basic - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 41 to 54 of 54
  1. #41
    Default Re: Programming RFM radio modules in Basic
    Regarding the comments on the program, i leave them there for me. Sorry for disturbing your reading by using those comments. Because of i use them for my children project GPS, i try to keep those to remind me what i have done.
    there is a big difference between comments that impart some information and visual white noise that masks the very few bits of data that are crucially different
    and worthy of notation
  2. #42
    My knowledge and time not helping my self to quickly develop a simple LED to light from one end of RFM69hcw to the other.
    But i will keep reading and studding all the information needed to achieve my goal.
  3. #43
    Now a small step, in the code is to add the DIO0 pin from RFM69HCW to PIC18F26K22.
    As i read from the net, that pin is the:
    Received data ready interrupt signal from RFM69HCW to microcontroller
    TRIS register must also be configured as input at that pin i guess as the RFM69HCW is the one sending data to PIC.
    That i believe will complete the connections between the PIC and the RFM.
    '*  Name    : 18F26K22.BAS                                            *
    '*  Author  : [Leonardo Bilalis]                                      *
    '*  Notice  : Copyright (c) 2018 [Leonardo Bilalis]                   *
    '*          : All Rights Reserved                                     *
    '*  Date    : 30/Jun/2018                                             *
    '*  Version : 1.0                                                     *
    '*  Notes   : This is a GPS Tracker based on the following components *
    '*          : PIC18F26K22 or PIC18F46K22 @ 64Mhz                      *
    '*          : MKT 3333 or 3339 GPS MODULE                             *
    '*          : 4D Systems ULCD Goldelox or Picasso Graphic Processor   *
    '*          : RFM69HCW the range will be approximatelly 1000 meters   *
      #CONFIG   ;
         CONFIG FOSC     = HSHP	        ; HS oscillator (high power > 16 MHz)
        CONFIG PLLCFG    = ON	        ;Oscillator multiplied by 4
        CONFIG PRICLKEN  = ON	        ;Primary clock enabled
        CONFIG FCMEN     = OFF	        ;Fail-Safe Clock Monitor disabled
        CONFIG IESO      = OFF	        ;Oscillator Switchover mode disabled
        CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect                     ;|
        CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale;|
        CONFIG  PWRTEN   = ON
        CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
        CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
        CONFIG  DEBUG    = OFF          ; Disabled
        CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    define  OSC 64
    OSCCON    = %01110000   ; 64Mhz
    OSCTUNE.6 = 1           ; Enable 4x PLL
    while ! osccon2.7 :WEND ; to make sure the pll has stabilised before you run any other code
    initialize:
    CLEAR
    TRISA = %11011111
    TRISC = %11010111
    SSPCON1 = %00100010 ' in here we se the 5th bit of the SSPCON1 register and the last 4 bits for the clock speed at 64Mhz.
    SSP1STAT = %11000000  ' in here i need a help to understand what bits must be configured
    CS1      VAR           LATA.5  ' chip select (SS) from PIC18F26K22 to RFM69HCW
    DIO0     VAR           PORTC.2 ' Received data ready interrupt signal from RFM69HCW to microcontroller
    SCK1     VAR           PORTC.3 ' clock from PIC18F26K22 to RFM69HCW
    SDI1     VAR           PORTC.4 ' data IN , MISO from PIC18F26K22 to RFM69HCW
    SDO1     VAR           PORTC.5 ' data OUT, MOSI from PIC18F26K22 to RFM69HCW
    SSPIF   VAR     PIR1.3          ' SPI interrupt flag
    SMP     VAR     SSP1STAT.7      ' Data input sample phase
    CKE     VAR     SSP1STAT.6      ' Clock Edge Select bit
    SSPEN   VAR     SSP1CON1.5      ' SSP Enable bit
    CKP     VAR     SSP1CON1.4      ' Clock Polarity Select
    CS1    = 1
  4. #44
    not really, in rx mode its PayloadReady in tx mode its PacketSent
    that's 1% of the job done
    cannot see any point to creating these vars , they will never be used
  5. #45
    That is what i meant
  6. #46
    I will try to help myself and understand how to establish a connection between two RFM69HCW.
    Thanks to all of you trying to help me. I will upload a circuit diagram tomorrow afternoon for all of the people are interested to the same example.
    Here is a code in a really very early stage only trying to understand and configure the hardware ports.
    #IF __PROCESSOR__ = "18F26K22"
      #CONFIG   ;  The PBP configuration for the PIC18F26K22 is:
    ;    CONFIG FOSC     = RCIO6	    ; External RC oscillator
    ;*---------------------------------4x PLL ENABLE--------------------------------------*|
    ;*  4X PLL Enable        *|
    ;*    CONFIG PLLCFG  = OFF	        ;Oscillator used directly                         *|
        CONFIG PLLCFG    = ON	        ;Oscillator multiplied by 4                       *|
    ;  Primary clock enable bit
    ;    CONFIG PRICLKEN = OFF	        ;Primary clock can be disabled by software
    ;  Fail-Safe Clock Monitor Enable bit
    ;    CONFIG FCMEN    = ON	        ;Fail-Safe Clock Monitor enabled
    ;  Internal/External Oscillator Switchover bit
    ;    CONFIG IESO     = ON	        ;Oscillator Switchover mode enabled
        CONFIG  PWRTEN   = ON
    #ELSE
        #MSG "Wrong Processor selected!"
    #ENDIF
    define  OSC 64
            INCLUDE "modedefs.bas"
            INCLUDE "ALLDIGITAL.pbp"
            'INCLUDE "DT_INTS-18.bas"        ; Base Interrupt System
            'INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    '                            INITIALIZE RAM                                    |
    initialize:
    	CLEAR
    TRISA = %00000000   'use TRISA to specify which pin is (1 = input) and which (0 = output)
    TRISB = %00000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)
    TRISC = %00010000
    PORTA = 0            'make low all ports at A range                      |
    PORTB = 0            'make low all ports at B range                      |
    PORTC = 0            'make low all ports at C range                      |
    PORTE = 0            'make low all ports at E range
    '-------------------------- COMPARATORS OFF -----------------------------|
    CM1CON0.7 = 0 'Disable comparator1                                       |
    CM2CON0.7 = 0 'Disable comparator2                                       |
    SSP1CON1 = %00100010 ' in here we se the 5th bit of the SSPCON1 register and the last 4 bits for the clock speed at 64Mhz.
    RFM_CS      VAR     LATA.5      ' chip select (SS) from PIC18F26K22 to RFM69HCW
    RFM_DIO0    var     PORTC.1     ' Received data ready interrupt signal from RFM69HCW G0 to microcontroller pin 12 PORTC.1
    RFM_CS = 1
    '                          IMPORTANT SETTINGS                            *
    Define NETWORKID 10         'this must be the same on all nodes that talk to each other  (0 to 255)
    DEFINE SENDER    1          'in here we could have multiple senders (0 to 255)
    Define RECEIVER  2          'unique ID of the gateway/receiver (0 to 254, 255 = broadcast)
    define NODEID    sender     'if this is sender, we define the node
    Define FREQUENCY   ...............
    DEFINE ENCRYPTKEY  ...............
    I would like to setup first the basics as you see on the code above. So please let me know if that is ok at the moment.
    The frequency im using is the 433Mhz
    I guess the encrypted key can be anything.
  7. #47
    i'm not liking what i see already
    CONFIG FOSC = HSHP ; HS oscillator (high power > 16 MHz) why use a crystal ? it just wastes pins in this case
    ;* 4X PLL Enable *|
    CONFIG PWRTEN = ON
    CONFIG CPD = OFF ; Data EEPROM not code-protected
    CONFIG WRTD = OFF ; Data EEPROM not write-protected
    #ELSE
    #ENDIF
    define OSC 64
    lets not get too complicated to start with leave this out
    ' INITIALIZE RAM |
    initialize:
    CLEAR
    i fully disagree with making pins outputs unless they will be used as outputs when bread boarding
    portc.1 needs to be an input
    TRISC = %00010010
    lets no do this but set pins that matter in the initialisation code
    missing entirely set ports digital
    ANSELB=0
    anselc =0
    ANSELa=0
    totally pointless they are already off
    totally pointless the rfm init code will set up the mssp module
    no need they will never be used
    RFM_CS = 1
    all these setting are hard coded into the rfm69 init routine and cannot be changed in the code as it stands
  8. #48
    the basic shell to work with
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = ON
      CONFIG  BORV = 190
      CONFIG  WDTEN = OFF
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  T3CMX = PORTC0
      CONFIG  HFOFST = ON
      CONFIG  P2BMX = PORTB5
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    DEFINE OSC 64
    ;some vars the engine needs
    sdata  var byte
    tmpa   var word
    tmpb   var word
    tmp    var word
    rxflg  var byte
    i      var byte
    dest   var byte
    rfbuff var byte[17]
    rfm_int    var portc.1    ;dio0
    rfm_cs     var lata.5      ;nss
    button     var portc.0
    led          var portc.2
    goto overrfm  ; this is the rfm69 engine there is nothing here for users ,make no changes
    rfm:
    asm
     dw 0x0104,0x0200,0x0306,0x0483,0x0503,0x06d7,0x076c,0x08c0
     dw 0x0900,0x131a,0x1942,0x2540,0x29dc,0x2c00,0x2d05,0x2e90
     dw 0x2fde,0x30ad,0x3163,0x3734,0x3811,0x3904,0x3a01,0x3C8c
     dw 0x6F30
    GLetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
        movlw High Label         ; get high byte
        movwf Wout + 1
        BANKSEL 0
     endasm
    sendFrame:       ;tx to dest
        tmpb = $0104
        gosub writeReg
        pauseus 800
        TMPB=$2810
        GOSUB WRITEREG
        TMPB=$2800
        GOSUB WRITEREG
        TMPB=$2500
        GOSUB WRITEREG
        RFM_CS=0
        sdata=$80
        gosub xspi
        sdata=dest
        gosub xspi
        for i = 0 to 15
            sdata=rfbuff[i]
            gosub xspi
        next
        RFM_CS=1
        tmpb = $010c
        GOSUB WRITEREG
        while  rfm_int == 0  : wend
        tmpb = $0104
        gosub writeReg
        pauseus 800
        TMPB=$2540
        GOSUB WRITEREG
    xspi:             ;spi xfer
        SSP1CON1.7 = 0
        SSP1BUF = sdata
        while(SSP1STAT.0 ==0) :wend
        sdata = SSP1BUF
    writeReg:
        RFM_CS=0
        sdata=tmpb.highbyte|$80     ;reg
        gosub xspi
        sdata=tmpb                   ;data
        gosub xspi
        RFM_CS=1
    readReg:
        RFM_CS=0
        sdata=tmpb.highbyte&$7f    ;reg
        gosub xspi
        sdata=0
        gosub xspi
        RFM_CS=1
        tmpb=sdata             ;reply
    r69Init:
        @ GLetAddress _rfm ,_tmpa
        SSPCON1=$21
        SSPSTAT=$c0
        for tmp=0 to 24
        READCODE tmpa,tmpb
        tmpa=tmpa+2   ; +1 for pic16 +2 for pic18
        gosub writeReg
        next
        gosub rfm_set_highpower      ; "h" modules only
    rfm_set_highpower:      ; "h" modules only   turns on power amp
        tmpb=$130F
        gosub writeReg
        tmpb=$1200
        gosub readReg
        tmpb=tmpb&$1f
        tmpb=tmpb|$1160
        gosub writeReg
        tmpb=$5a5d
        gosub writeReg
        tmpb=$5c7c
        gosub writeReg
    overrfm:
    ;setup osc
    OSCCON=$70
    OSCTUNE.6=1
    while ! osccon2.7 :WEND    ;wait for pll
    ;setup pins
    trisa=%11011111
    trisc=%11010011
    ANSELB=0
    anselc =0
    ANSELa=0
    rxflg =0
    gosub r69Init ;program module
    tmpb = $0110      ;set listen mode
    gosub writeReg
    pauseus 800
    loopy:
        if rfm_int then     ; poll for pkt recieved
            tmpb = $0104     ;standby
            gosub writeReg
            pauseus 800
            tmpb=0
            gosub readreg
            if tmpb = 4 then rxflg =1   ;a pkt for me ?
            i=0 ;
            while (i<16)
                tmpb=0
                gosub readreg
                rfbuff[i] = tmpb
                i=i+1
            wend
            gosub writeReg
            pauseus 800
        if  rxflg then
        ;insert your code here to parse packet and act on it
         rxflg=0
       ;insert your code here to run in this loop
    goto loopy
  9. #49
    Hi Richard, just came back from a long day.
    Thanks for the comments on the code.
    You are right, there is no need to use external components and reserve ports. I will use the internal OSC at 64Mhz.
    CONFIG FOSC = HSHP ; HS oscillator (high power &gt; 16 MHz) why use a crystal ? it just wastes pins in this case
    sure i can leave them aside at the moment.
    Ok, but what should i give as a state if not output? for the PORTC.1 it is clear to me as it will behave as an input.
    TRISC = %00010010
    Is there any problem when we set the ports at the very beggining of the program not to funtions at all and set the low? Then in the program we could assign any pin to be low or high
    That's is why we include at the beggining the: INCLUDE "ALLDIGITAL.pbp"
    but sure as we leave them on a side somehow here we have to tell that all ports are digital thanks.
    ANSELB=0
    anselc =0
    ANSELa=0
    I though that it is not off unless we configure them to be off.
    really didnt know. maybe i need to read better the datasheets.
    OK
    I though that we need to set those as somehow we need from those ports to send and receive data.
    I understand. In order to use the following statement someone need to create an include file. Then those configurations can be easily updated.
    As i see some of the ports are included in your code as the button and the LED. Let me fix the breadboard and i will come back with lots of questions based on your code starting with the first
    what is this for?
    asm
     dw 0x6F30
    of course i dont understand the asm you have written so if you could find time to make things easier for all of us, would be really helpfull.
    Will come back soon with lots of questions based on your code.
  10. #50
    I also have plenty of questions regarding some of the Configs.
    not that i understand some of the other configs but those really cant figure out why we set them and what is the operation for each of them.
    CONFIG CCP2MX = PORTC1 ; CCP2 input/output is multiplexed with RC1
    CONFIG PBADEN = OFF ; PORTB<5:0> pins are configured as digital I/O on Reset
    CONFIG CCP3MX = PORTB5 ; P3A/CCP3 input/output is multiplexed with RB5
    CONFIG T3CMX = PORTC0 ; T3CKI is on RC0
  11. #51
    tris can have only two values for each bit , 0 or 1 . if bit =0 the pin is an output , it its not 0 its a 1 and thefore an input
    you do not give pins a "state " you clear the revejent bit to make apin an output
    since dt died who is keeping it uptodate ?
    we never drive any of these pins directly , the mssp module is in charge of them . we use control and use the mssp module
    good luck with that , as i stated all these setting are hard coded into the rfm69 init routine and cannot be changed in the code as it stands
    what is this for?
    asm
    dw 0x0104,0x0200,0x0306,0x0483,0x0503,0x06d7,0x076c,0 x08c0
    dw 0x0900,0x131a,0x1942,0x2540,0x29dc,0x2c00,0x2d05,0 x2e90
    dw 0x2fde,0x30ad,0x3163,0x3734,0x3811,0x3904,0x3a01,0 x3C8c
    dw 0x6F30
    that is the data to load into the rfm module's registes to make it behave in the manner we need
    these set the alternative pin options for the indicated module outputs [whether we use them or not a choice must be made]
    this set portb digital at boot up [technically anselb=0 is not required when this option used]
  12. #52
    I'm trying to figure out a way to understand this code. I guess all those coming from the datasheet?
    asm
    dw 0x6F30
    So the first marked with blue is the register conrresponds to the following?
    0x01 RegOpMode 0x04 Operating modes of the transceiver
    Then i will try to make notes for each of these registers. Richard it is the only way i could understand things and then to help my self in order not to waste your time.
  13. #53
    i'm not prepared to support the code to that level of detail yet , remember the car analogy you are wanting to discuss engine fine tuning when it is yet to be proven that you can even drive it or even get it started . small steps . those settings are the result years of experience not to mention many months of trial and effort, not forgetting many hours studying the hope rf docs and sample code . don't lose sight that this a pbp forum not a hope rf forum . you are yet to in any way indicate how you expect to use the module ,what data you will send or anything . i have grave reservations that you have any idea how to use a simplex packet radio system for data transmission at all. a simple no frills lib was asked for i cannot make it any simpler.
    usage is quite simple , after the module is initialised it has two modes listen or standby ,when listening you need to monitor the rfm_int pin to see if a packet has been received , if it has then there is example code to demonstrate how to extract the data packet, at any time you can load up the data buffer and transmit a packet . thats it . [thats how these thing work]
    you keep quibbling around the edges, to me there is no point discussing the fine detail until you can prove that you can actually get somewhere with it.
  14. #54
    Hi Richard,
    thanks for the comments. Everything you said is totally rihgt, I know i have a long road until i fully understand how to use this module.
  1. basic pic programming
    By sshanmugapriya in forum mel PIC BASIC
    Last Post: - 25th February 2010, 06:02
  2. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 19:41
  3. Smart Radio RF620A and RF620RA modules
    By Colin612 in forum Serial
    Last Post: - 8th May 2008, 15:47
  4. LPRS/miniature radio modules
    By fowardbias in forum Off Topic
    Last Post: - 20th September 2005, 01:03
  5. Help With Easy Radio Modules
    By hughgoodbody in forum General
    Last Post: - 25th May 2005, 09:14
Members who have read this thread : 36
