UART communication problem
Results 1 to 4 of 4
    May 2016
    Default UART communication problem
    Hello,
    I am trying to use following code in a PIC18F14K50 to change configuration of a rn42 Bluetooth Module and it goes to command mode but then it gets stuck:
    As an example I want to change name of bluetooth module and then reboot it.
    DEFINE LOADER_USED 1
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 115200
    DEFINE HSER_SPBRG 12
    DEFINE HSER_CLOERR 1
    DEFINE OSC 24
    ADCON0 = 011100
    ADCON1 = 000000
    ADCON2 = 110101
    ANSEL = 001000
    ANSELH = 000011
    TRISC.4 = 0
    TRISC.0 = 0
    TRISC.1 = 1
    TRISB.5 = 1
    TRISB.7 = 0
    tx1 VAR PORTB.7
    rx1 VAR PORTB.5
    LED VAR PORTC.4
    Mybutton VAR PORTC.1
    mainloop:
       If Mybutton = 0 Then
          HIGH LED      ' Turn on LED
                Hserout ["$$$"]                             'enter command mode
                Pause 100
                Hserout ["SN,MyBT"]                       'Change name to MyBT
                Pause 100
                Hserout ["R,1"]                               'Reboot
          Pause 500
       Else
          LOW LED     ' Turn off LED
          Pause 500
       Endif
       Goto mainloop   ' Do it forever
    I receive the data on serial monitor when I use a UART-USB converter so I know the strings are being sent.
    However,the module starts blinking after $$$ but it doesn't perform the rest of commands.The similar Arduino code works without any problem.
    Any idea why it doesn't work?
    Default Re: UART communication problem
    Never used the RN42 but shouldn't there be some sort of line termination characters after each command, like a LF or CR?
    How else would it distinguish between for example MyBT and R, perhaps you wanted to change the name to MyBTR....
    EDIT: Yeah, the command reference seems to indicate CR is what it expects.
    You also have a typo, you have DEFINE HSER_CLOERR 1 it should be DEFINE HSER_CLROERR 1
    May 2016
    AWESOME! That was the problem and it's working now.
  1. Replies: 9
    Last Post: - 1st June 2016, 06:04
  2. uart problem
    By OYMYAKON in forum mel PIC BASIC Pro
    Last Post: - 25th March 2011, 11:52
  3. Problem using Microloader and Uart Comm at the same time
    By guanerrr in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2007, 09:31
  4. Problem with UART... here is a real challenge
    By matias in forum mel PIC BASIC Pro
    Last Post: - 5th May 2007, 08:30
  5. Replies: 8
    Last Post: - 11th November 2004, 20:08
