COUNT never counts properly! (16F870)
Results 1 to 10 of 10
    Default COUNT never counts properly! (16F870)
    Hello, I have simple code:
    CIKLI:
    count portc.3,15, batvolt
    if batvolt<>0 then
    lcdout $FE, $C0,#BATVOLT, "   "
    GOTO CIKLI
    The input sequence consists of series of pulses, which look like this:
    First pulse lasts for 10ms then pause 1.8ms then 2nd pulse 0.8ms then pause 0.6ms and then again pulse 0.8ms
    it takes about 15ms all this together
    Hardware is 16F870, 4mhz clock. The "COUNT" statements returns any value, from 7 to 33, on each run. Any idea, how to fix?
    Default Re: COUNT never counts properly! (16F870)
    For starters, There is too much variance between pulses and there is nothing in your code to SYNC the 10 Ms. start pulse with. You are only counting the pulses for 15 Ms. and with no SYNC 1 of the pulses is taking as much as 10 Ms. of the timing gate. I am not understanding the pulse pattern you are trying to decode. If the pulse train only lasts for 15 Ms. before it repeats then you will only ever count approx.9 counts. Am I correct? What in the data stream is changing? The number of pulses or the pulse width?
    EN82fn
    This is fixed sequence, and I want PBP to return "3", since in 15ms period it gets 3 pulses.
    How often is this pattern repeating? Constantly?
    Count will start counting immediately and then continue to count for 15ms. It won't sit there waiting for the first pulse and THEN count for 15ms.
    What if the start of the command occurs in the middle of your 3 pulse sequence? Or in between two of those 3 pulse patterns?
    The fact that always seem to get MORE than 3 counts indicates that your pin isn't driven to both states. Verify that you have well defined logic states for both '1' and '0' on the input.
    Above code is launched, when signal on input pin arrives, I just missed that line here.
    I discarded the COUNT statement, and wrote software substitute, which accurately counts amount of pulses:
     UIDEDA:
     if pulsi=1 then
     FOR N=0 TO 300 'this is length of capture period, 300 for 16F870 @ 4mhz means approx 15ms.
     IF PULSI=1 THEN
     A=A+c
     c=0
     d=1
     B=B+d
     d=0
     c=1
     NEXT
     IF A<>0 AND B<>0 THEN
     lcdout $FE,2, "A=",#A, "    "
     lcdout $FE,$C0,"B=",#B, "    "
     A=0
     B=0
     GOTO UIDEDA
    I'm interested, why count never works as it should.
    Sounds like noise to me.... Try a schmidt trigger between what you are counting and the pic.
    EN82fn
    If it was noise issue, why my code works perfectly?
    Aug 2003
    The manual says with a 4MHz oscillator as you have, the pin is sampled every 20us which is way too slow for the fractional pulse durations you stated.
    The different results can easily be explained since any low or high period could be entirely missed.
    Your code is still pretty slow.
    The fastest I can think of right now in PBP is this:
    newbitstate var bit
    oldbitstate var bit
    counter var word
    count var word
    duration var word
    newbitstate = 0
    oldbitstate = 0
    duration = 9000 ‘ set duration to sample the input
    count = 0 ‘ reset count
    for counter = 0 to duration
    newbitstate = portb.0
    if newbitstate != oldbitstate then
    count = count + 1
    oldbitstate = newbitstate
    next duration
    Then Count will be the number of pin changes.
    To get the pulse count, rather than check in the routine and slow it down,
    just divide Count by 2 at the end, to get the number of rising edges,
    and if the remainder is 1, the duration ended while the port pin was high.
    0.8ms=800us, so it fits very well
    Aug 2003
    lol I was reading ms as microseconds.
    If your code works better than Count then use it I’d sure like to see a disassembly of Count in your loop though, which I don’t have the tools to do handy at the moment.
  1. Can't access Port A with PBP on 16F870.
    Last Post: - 16th April 2013, 11:28
  2. Replies: 23
    Last Post: - 16th September 2010, 16:52
  3. Replies: 1
    Last Post: - 7th December 2009, 16:35
  4. Saving COUNTs?
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 19th April 2009, 17:55
  5. Help needed with 16F870 ADC
    By srob in forum mel PIC BASIC
    Last Post: - 10th May 2008, 13:14
