Write and read to memory of PIC18F14k50
+ Reply to Thread
Results 1 to 2 of 2
    May 2016
    Default Write and read to memory of PIC18F14k50
    Hello all,
    I am trying to write and read from memory of PIC18F14k50.I have following code to write to memory location $500:
    DEFINE OSC 24
    X var byte
    Y var word
    Value var byte
    mainloop:
    Pause 4000
    Y = $500
    Value=2
    erasecode Y
    for X = 1 to 16
    writecode Y, Value
    Y = Y + 1
    next X
       Goto mainloop
    I am trying to read from same location and turn LED on if 2 is stored at address $500.
    DEFINE OSC 24
    TRISC.4 = 0
    LED VAR PORTC.4
    X var byte
    Y var word
    Value var byte
    mainloop:
    readcode $500, Value
       If Value = 2 Then
          HIGH LED
          goto  ledout
          Pause 50
       Else
          LOW LED
          Pause 50
       Endif
       Goto mainloop
    However It doesn't turn on the LED.Any thoughts?
    Sep 2009
    Default Re: Write and read to memory of PIC18F14k50
    You delete content of entire FLASH memory when you erase FLASH before programming PIC.
    Try this:
    DEFINE OSC 24
    X var byte
    Y var word
    Value var byte
    Pause 4000
    Y = $500
    Value=2
    erasecode Y
    for X = 1 to 16
    writecode Y, Value
    Y = Y + 1
    next X
    Blink:
       If Value = 2 Then
          Toggle LED
          Pause 500
       Else
          LOW LED
       Endif
       GOTO Blink
  1. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 19:19
  2. A help with Write/Read a I2C memory
    Last Post: - 28th March 2008, 13:53
  3. Write and Read from internal Memory
    By joseph Degorio in forum Serial
    Last Post: - 2nd December 2007, 11:03
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. cannot read/write to 16F690 data memory after CPD_ON
    By awdsas in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2006, 11:46
