How to set HPWM to generate 38khz signal? (16F870)
Results 1 to 11 of 11
    Default How to set HPWM to generate 38khz signal? (16F870)
    Hello.
    I'm building custom IR control, I already wrote the code for ir command generation, but I want to use built in hardwre pwm of 16F870 chip to generate 38khz carrier. PBP supports up to 32khz. Also, I'd be very grateful, if some gives me ASM code insert which simply enables and disables hpwm with already set frequency and duty cycle. The PBP command HPWM does too many things together, like switching port and so on, so it is slow.
    Default Re: How to set HPWM to generate 38khz signal? (16F870)
    Thanks, so I need this part of code, right?
    _Pulse38
       bcf IRTX,PIN         ; 1uS, LED=on
       goto $+1             ; + 2uS = 3uS
       goto $+1             ; + 2uS = 5uS
       goto $+1             ; + 2uS = 7uS
       goto $+1             ; + 2uS = 9uS
       goto $+1             ; + 2uS = 11uS
       goto $+1             ; + 2uS = 13uS
       bsf IRTX,PIN         ; 1uS, LED=on
       nop                  ; + 1uS = 10uS
       decfsz _Cycles,f     ; + 1uS = 11S
       goto _Pulse38        ; + 2uS = 13uS
       return               ; Return to caller
    and by the way, this code does nothing to built-in HPWM, right?
    No need for assembly code.
    You want a PWM period of 1/38000 = 26.315us. Assuming 20MHz operating frequency your instruction cycle time is 200ns so you want a PWM period of 131-132 instruction cycles. Then you simply follow the instructions in the datasheet:
    8.4.3 SETUP FOR PWM OPERATION
    The following steps should be taken when configuring
    the CCP module for PWM operation:
    1. Set the PWM period by writing to the PR2 register.
    2. Set the PWM duty cycle by writing to the CCPR1L register and CCP1CON<5:4> bits.
    3. Make the CCP1 pin an output by clearing the TRISC<2> bit.
    4. Set the TMR2 prescale value and enable Timer2 by writing to T2CON.
    5. Configure the CCP1 module for PWM operation.
    PR2 = 130                      ' 1) PWM period of 131 instruction cycles assuming 1:1 prescaler
    CCPR1L = 65                  ' 2) Dutycycle of ~50%, no need to write 2 LSB for this.
    TRISC.2 = 0                   ' 3) Pin is output
    T2CON = %00000100      ' 4) 1:1 Prescaler, TMR2 ON
    CCP1CON = %00001100    ' 5) PWM mode enabled
    This sets up the carrier and enables it. To disable the carrier:
    CCP1CON = 0
    Enable it again:
    CCP1CON = 15
    I'm not 100% sure what the note in the datasheet says
    Note: Clearing the CCP1CON register will force
    the CCP1 PWM output latch to the default
    low level. This is not the PORTC I/O data
    latch.
    It either says that as long as you set PortC.2 to 0 the output pin will revert to 0 as soon as the CCP module is disabled (which is good in this case) OR it says that actual output pin is left in the state it was at the time the CCP module was disabled which means that it can be high or low and that you need to force it back down by doing PortC.2 = 0 after turning off the CCP module.
    (Untested, please verify against datasheet)
    Thanks Henrik. Is it possible to do with 4mhz oscillator? I'm testing on breadboard, and with 20mhz oscillator it behaves badly.
    Short answer is:
    Yes.
    Question is:
    Have you tried yourself with 4MHz? What did you change and why? What did it do, why do you think it didn't work?
    Long answer is:
    First, PWM period:
    * TMR2 "drives" the CCP module.
    * TMR2 starts at 0 and counts upwards.
    * When the content of TMR2 equals that of PR2, TMR2 starts over from 0 and on it goes. The time it takes for TMR2 to count from 0 to PR2 is the PWM period.
    As before, if you want a PWM perdiod of 26.315us you need to set the PR2 register so that TMR2 resets and starts over after 26.315us. At 4MHz the fastest you increment TMR2 (on that devices) is 1MHz, ie it'll "tick" every 1us. So the closest you're going to get is a flat 26us (38.461Hz) and you do this by setting PR2 to 25, right? Because TMR2 will then Count from 0 to 25 (26us) before it starts over and does it again and again and again......
    Second, the dutycycle:
    This can be a little trickier to understand but basically the dutycycle value as a whole can be though of the value you put into PR2 times 4. That is, when PR2 is 25 as in this case the dutycycle value can go from 0 to 100 (for 0-100% dutycycle). In the previous example with 20MHz Clock and a PR2 value of 130 the dutycycle value, again for 0-100% would go from 0 to 520.
    Now, the dutycycle value since it can theoretically be 10bits wide (0-1023) are spread across two registers, CCPR1L contains the 8 high bits and CCP1CON.5 and 4 (from memory) contains the two low bits,
    If you want "roughly" 50% dutycycle with a PR2 value of 25 you simply write either 12 or 13 (half of 25) to CCPR1L and that's it. If you want better resolution I'm sure you can figure out what to do with the two least significant bits.
    Hello. A while back I used this routine to generate 38KHZ with a 12F675 running at 4MHZ.
    STARTBIT:
    High GPIO.4 'GETTING 38KHZ WITH THIS SUBROUTINE
    High GPIO.4
    Low GPIO.4
    Low GPIO.4
    LET X = X + 001
    IF X < 125 Then STARTBIT '125 = 3MS PULSE, 83 = 2MS pulse, 33 = 1MS pulse
    Maybe you can do something with this.
    Knocked this up when the remote for my aircon died , never really finished it . got a clone remote on ebay for $10 (delivered)
    why bother.
    this can work for any osc >= 8 MHz
    '*  Name    : ir38khz.BAS                                       *
    '*  Author  : RICHARD                                           *
    '*  Notice  :                                                   *
    '*  Date    : 6/30/2016                                         *
    '*  Notes   : REPL BRA WITH GOTO  FOR NASTY OLD CHIPS           *
    '*          : OSC MUST BE AT LEAST 8 MHZ                        *
    DEFINE OSC 16       ; MIN=8     TESTED  OK 8,16,32
    DEFINE IRPORT  LATC
    DEFINE IRPIN  4
    define IR_1   2000     ; 1 TIME IN uS   MAX 6500 ISH
    define IR_0   900      ; 0 TIME IN uS
    cycnt       var byte  bank0       ;set to numbr of 38k cycles req then call irout  RANGE 1-255
    dly         var byte  bank0      ;system
    goto overasm
     asm
    _irout1                 ;entry point FOR 1 pulse
            movlw   (IR_1/26)
            movwf   _cycnt
            BRA     _irout    ;GOTO
    _irout0 movlw   (IR_0/26) ;entry point FOR 0 pulse
            movwf   _cycnt
    _irout                 ;entry point for cycnt cycles
    nxbt    CHK?RP IRPORT
            BSF IRPORT ,IRPIN
            CALL dly13
            CHK?RP IRPORT
            BCF  IRPORT ,IRPIN
            CALL dly13
            RST?RP
            DECFSZ _cycnt,F
            BRA nxbt             ;GOTO
    dly13   movlw   (OSC-(16/OSC))
            RST?RP
            movwf   _dly
    d13
            DECFSZ _dly,F
            BRA d13           ;GOTO
     endasm
    overasm:
       OSCCON=$78
       ANSELA=0
       ANSELC=0
       TRISA = %111110
       TRISC = %11000011         ' set PORTC I/O
        cycnt = 100
        call irout
        pauseus 250
        call irout1
        pauseus 250
        call irout0
        pause 50
    Thanks, will have look.
  1. How can I stop HPWM and then manually set the pin level?
    By gavinthacker in forum mel PIC BASIC Pro
    Last Post: - 8th March 2016, 16:55
  2. 6 HPWM signal generation with PIC18F4431
    By pxidr84 in forum mel PIC BASIC Pro
    Last Post: - 6th March 2013, 05:00
  3. 38Khz Modulator
    By Gord11 in forum mel PIC BASIC Pro
    Last Post: - 28th September 2011, 08:14
  4. HPWM signal transfered to an other pin!
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2010, 19:25
  5. Generate a 120Khz signal using the pic16F877a
    By texas5 in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 21:59
