How to include a .DLL?
Results 1 to 15 of 15
    May 2016
    Default How to include a .DLL?
    Hello all,
    I would like to encrypt part of my code by turning it to a .DLL.
    I am trying to turn part of my code to assembly and trun that to a DLL.
    Now I am a bit confused on how to include a DLL in Basic code? Should I use EASYHID and C++? Would appreciate simple instruction.
    BTW I am using PIC18F.
    Sep 2009
    Default Re: How to include a .DLL?
    There is no easy way to include Dynamic-link library, it could be done, but...
    There is easy way to include static-link library. Just look up for my bootloader posts, and explanation how to pass variables between main app and bootloader.
    May 2016
    There is no easy way to include Dynamic-link library, it could be done, but... There is easy way to include static-link library. Just look up for my bootloader posts, and explanation how to pass variables between main app and bootloader.
    Seems like there are lots of bootloader posts that you are involved.But I think bootloader is the way to go. Is there any example for reading data/including code from bootloader to main code?
    Sep 2009
    There is. I can't remember topic name. In that topic I explained how variables can be shared between main app and bootloader.
    Sep 2009
    Sep 2009
    Can I ask you what you are trying to accomplish?
    ditto the last post. Why would you want to include pre-compiled code when its so much easier to include the source and compile the whole thing.
    DLL's are commonly used to implement third party functions. The operating system controls initialization and there is a mutually understood way of defining and passing parameters. Non of these thing apply in this case.
    I'm sure it's possible but the real question is why?
    George
    May 2016
    The purpose is to have an open source code that part of it is encrypted. So I don't want to release part of it.Either using an object file,DLL, or code in bootloader and then call it from main code.
    If you don't want to provide the source, how can it be open source?
    George
    May 2016
    Quote Originally Posted by towlerg View Post
    Most of it will be open source but I don't want to open source small part of it dealing with USB.So basically I want to release the source code but not one of include files.
    Sep 2009
    Forget about that...
    First you can easily dissemble hex file, and get that ASM code. Second, how PIC will execute commands if they are encrypted. Any way you must write original source code to FLASH if you want to execute it.
    So even if code is loaded in flash encrypted, and then decrypt in pic and wrote to FLASH again, just run your code in some simulator, and look FLASH content...
    I don't want to be rude, but open source with hidden source is plain stupid...
    I don't want to be rude either but pedja089 realy does have a point. It's either open sorce or its not (like being a little bit dead)
    George
    May 2016
    I don't mind if they dissemble the hex.I just don't want it to be too easy to simply read the code.As far as I can call a function in Bootloader then I am fine.I am a bit new to bootloader but can I upload two hex files to MCU? or second hex should be done through bootloader?
    Sep 2009
    There is some programmers that would you probably allow you to load two hex...
    I always put precompiled bootloader at end of main app and every thing i need for production is in one HEX.
    Aug 2016
    You can create C++ app that references the DLL file.
  1. SSD1306 Include example
    By timc in forum Code Examples
    Last Post: - 28th November 2017, 08:53
  2. Use of INCLUDE
    By Alexey in forum mel PIC BASIC
    Last Post: - 25th December 2013, 13:51
  3. where to put include files
    By queenidog in forum mel PIC BASIC Pro
    Last Post: - 21st February 2013, 19:10
  4. Where are all the INCLUDE files??
    By Heckler in forum General
    Last Post: - 13th September 2011, 08:27
  5. Need to download Include files
    By laflam_p in forum Off Topic
    Last Post: - 2nd September 2009, 13:39
