File won't compile in PBP 2.6
Results 1 to 12 of 12
    Sep 2015
    Default File won't compile in PBP 2.6
    Hi All,
    I am very new to PIC programming. I started out with the 12F683 and played with it for a while until I was comfortable with it. I then bought several types to experiment with. I decided to make a template file for each type of PIC that I have. The template file would be a "skeleton" PBP file with all of the configuration settings listed. All but one would be commented out so I could see what config options are available.
    After listing all of the settings and options, I would save and compile this file. If it compiled then I know that my spelling and syntax are correct. If not, then I corrected spelling and syntax, and then recompiled.
    This worked great for 12F683 and various 16F PICs (887,88, 688.628A) However when compiling for the 16F1827 I get the following error messages (see attached).
    Syntax appears to be good; the values are from meConfig. I am using PBP 2.6. I am completely stumped as to why this file will not compile.
    Any help would be greatly appreciated.
    mikejp56
    Default Re: File won't compile in PBP 2.6
    On the 16F1827 there is no PortC and therefor no TrisC either which would explain the first two errors. The others seems to indicate that the program is too big, which I doubt if it's what you say it is so it might just be a problem due to the first error. If they don't go away you're going to have to post the code so we can see it.
    EDIT: Hmm, it says Program word too large.... So it's probably NOT the "length" of the program it's complaining about after all. But again, if it doesn't go away we (or I at least) need to see the code.
    Oct 2009
    Without showing the code you are trying to compile it's going to be difficult for people to try and diagnose what the cause may be. Paste up the full code you are trying to compile and I'm sure you will get a more definitive answer
    Sep 2015
    Sorry guys,
    It was almost midnight last night when I posted this.
    Here is the code:
    '* Name : 16F1827 Template.BAS *
    '* Notice : Copyright (c) 2016 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 5/29/2016 *
    '* Version : 1.0 *
    '* Notes : *
    ;----[16F1827 Hardware Configuration]-------------------------------------------
    cfg1 = _FOSC_ECH ; ECH, External Clock, High Power Mode (4-32 MHz): device clock supplied to CLKIN pin
    ;cfg1 = _FOSC_ECM ; ECM, External Clock, Medium Power Mode (0.5-4 MHz): device clock supplied to CLKIN pin
    ;cfg1 = _FOSC_ECL ; ECL, External Clock, Low Power Mode (0-0.5 MHz): device clock supplied to CLKIN pin
    ;cfg1 = _FOSC_INTOSC ; INTOSC oscillator: I/O function on CLKIN pin
    ;cfg1 = _FOSC_EXTRC ; EXTRC oscillator: External RC circuit connected to CLKIN pin
    ;cfg1 = _FOSC_HS ; HS Oscillator, High-speed crystal/resonator connected between OSC1 and OSC2 pins
    ;cfg1 = _FOSC_XT ; XT Oscillator, Crystal/resonator connected between OSC1 and OSC2 pins
    ;cfg1 = _FOSC_LP ; LP Oscillator, Low-power crystal connected between OSC1 and OSC2 pins
    cfg1&= _WDTE_ON ; WDT enabled
    ;cfg1&= _WDTE_NSLEEP ; WDT enabled while running and disabled in Sleep
    ;cfg1&= _WDTE_SWDTEN ; WDT controlled by the SWDTEN bit in the WDTCON register
    ;cfg1&= _WDTE_OFF ; WDT disabled
    cfg1&= _PWRTE_ON ; PWRT enabled
    ;cfg1&= _PWRTE_OFF ; PWRT disabled
    cfg1&= _MCLRE_ON ; MCLR/VPP pin function is MCLR
    ;cfg1&= _MCLRE_OFF ; MCLR/VPP pin function is digital input
    cfg1&= _CP_ON ; Program memory code protection is enabled
    ;cfg1&= _CP_OFF ; Program memory code protection is disabled
    cfg1&= _CPD_ON ; Data memory code protection is enabled
    ;cfg1&= _CPD_OFF ; Data memory code protection is disabled
    cfg1&= _BOREN_ON ; Brown-out Reset enabled
    ;cfg1&= _BOREN_NSLEEP ; Brown-out Reset enabled while running and disabled in Sleep
    ;cfg1&= _BOREN_SBODEN ; Brown-out Reset controlled by the SBOREN bit in the BORCON register
    ;cfg1&= _BOREN_OFF ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_ON ; CLKOUT function is enabled on the CLKOUT pin
    ;cfg1&= _CLKOUTEN_OFF ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_ON ; Internal/External Switchover mode is enabled
    ;cfg1&= _IESO_OFF ; Internal/External Switchover mode is disabled
    cfg1&= _FCMEN_ON ; Fail-Safe Clock Monitor is enabled
    ;cfg1&= _FCMEN_OFF ; Fail-Safe Clock Monitor is disabled
    __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF ; Write protection off
    ;cfg2 = _WRT_BOOT ; 000h to 1FFh write protected, 200h to FFFh may be modified by EECON control
    ;cfg2 = _WRT_HALF ; 000h to 7FFh write protected, 800h to FFFh may be modified by EECON control
    ;cfg2 = _WRT_ALL ; 000h to FFFh write protected, no addresses may be modified by EECON control
    cfg2&= _PLLEN_ON ; 4x PLL enabled
    ;cfg2&= _PLLEN_OFF ; 4x PLL disabled
    cfg2&= _STVREN_ON ; Stack Overflow or Underflow will cause a Reset
    ;cfg2&= _STVREN_OFF ; Stack Overflow or Underflow will not cause a Reset
    cfg2&= _BORV_19 ; Brown-out Reset Voltage (Vbor), low trip point selected
    ;cfg2&= _BORV_HI ; Brown-out Reset Voltage (Vbor), high trip point selected
    cfg2&= _LVP_OFF ; High-voltage on MCLR/VPP must be used for programming
    ;cfg2&= _LVP_ON ; Low-voltage programming enabled
    __CONFIG _CONFIG2, cfg2
    ;----------Main Program---------------------------------------------------------
    There are no references to any ports or tris registers, just config words.
    And like I said, this is all from meConfig and done in Micro Code Studio.
    Thanks for your help.
    mikejp56
    What did you expect? Meconfig is only to help produce the configuration register settings. After it is done, you are to copy them into your oun program.
    EN82fn
    SWITZERLAND (french speaking)
    Default config fuses using MPASM
    If you use Microchip's (MPASM) Assembler, config fuses must be set like:
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _LVP_OFF & _CP_ALL & _DATA_CP_ON
    Roger
    Sep 2015
    Hi Dave,
    That's the point. I have done these templates for about 6 or so PICs without any problems. They are only to set the config bits. Yet for the '1827 they think that I am referring to ports and tris registers. All I'm referring to are config bits.
    Hi flotulopex,
    I might try that next.
  1. Darryl's MIBAM code: won't compile for me!
    By Experimenter in forum mel PIC BASIC Pro
    Last Post: - 10th April 2014, 19:54
  2. Replies: 6
    Last Post: - 21st April 2013, 15:47
  3. Finally trying to do some serial- Won't compile :(
    By cncmachineguy in forum mel PIC BASIC Pro
    Last Post: - 26th January 2011, 16:25
  4. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 19:35
  5. Replies: 2
    Last Post: - 10th July 2006, 01:05
