How to set pin to digital by default? PIC18F24J50
THE BOOK of DT's INTERRUPTS is an organization of interrupt service routines and other works written by Darrel Taylor, RIP.
Interrupt routines are arranged per Darrel's original list. Darrel Taylor's Instant Interrupts are an extension of the work of Tim Box whom in October of 2002 wrote INT_CTRL.pbp
Many of the forum members felt this is a long overdue project.
will be a valuable resource and a tribute to Darrel Taylor the "Fanatical Contributor".
THE BOOK of DT's INTERRUPTS is located at http://dt.picbasic.co.uk/
+ Reply to Thread
Results 1 to 3 of 3
    May 2016
    Default How to set pin to digital by default? PIC18F24J50
    Hello there,
    I have a PIC18F24J50 and I want to set pin 0 of port A to digital pin inorder to have a push button turn an led on and off.
    I have a C code that is working and sets pin 0 of port B to digital using
    ANCON1bits.PCFG12 = 1;
    All the C code:
    void main(void) {
     ANCON1bits.PCFG12 = 1;          //RB0
      TRISB=1;
      TRISC=0;
      RC0=0;
      do
        if(RB0 == 0)
          __delay_ms(10);
          if(RB0 == 0)
            RC0 = 1;
            __delay_ms(10);
            RC0 = 0;
      }while(1);
    I am trying to do the same but I get error regarding PCFG12 that it doesn't exist!
    All basic code:
    PCFG12=1
    TRISC.0 = 0
    TRISB = 001111
    button1 VAR PORTB.0
    LED VAR PORTC.0
    PortB = 0
    mainloop:
       If button1 = 0 Then
          Low LED
          Pause 600
       Else
          High LED
          Pause 600
       Endif
       Goto mainloop
    I appreciate if you help me get i working in Basic! Thanks
    Default Re: How to set pin to digital by default? PIC18F24J50
    PCFG12 is bit 4 in ANCON1 so
    ANCON1.4 = 1
    should do it, but that's for AN12 which is RB0 while you're talking about RA0 which is AN0 so
    ANCON0.0 = 1
    May 2016
    ANCON1.4 = 1 worked thanks!
  1. How to set ports to digital (ALLDIGITAL.PBP)
    By RayL113 in forum FAQ - Frequently Asked Questions
    Last Post: - 30th November 2013, 02:59
  2. SPI, SCK Pin set up
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2012, 06:23
  3. How to set a pin high an keep it there?
    By ShortBus in forum mel PIC BASIC Pro
    Last Post: - 1st October 2009, 16:01
  4. How do I get 18f452 pin 10 set as digital input?
    Last Post: - 26th May 2007, 18:32
  5. Replies: 2
    Last Post: - 14th April 2006, 09:42
