PCA9685 turning all outputs on / off
Results 1 to 3 of 3
    Oct 2009
    Default PCA9685 turning all outputs on / off
    I'm working on a project that uses the PCA9685 chip. The chip is set up using the following code, which I confess was provided for me by a friend, but I get the gist of things in that it resets the chip and sets a pre-scaler or something !
    'Initialize the PCA9685
    i2cControl      var BYTE                'Used for PCA chip control
    i2cReadAddress  var BYTE
    i2cWriteAddress var BYTE
    pcaAddress      var BYTE
    oldMode         var BYTE
    newMode         var BYTE
    pcaChannel      var BYTE
    i2cReadAddress = pcaAddress << 1
    i2cWriteAddress = i2cReadAddress | 1
    i2cControl = $0                                                     ;Reset
    I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[$0]              ;PCA9685_MODE1 $0
    i2cControl = $0                                                     'PCA9685_MODE1 $0
    I2CREAD SDApin,SCLpin,i2cReadAddress,i2cControl,[oldMode]           ;Get old mode
    newMode = (oldMode & $7F) | $10                                     ;MODE1 Sleep
    i2cControl = $0
    I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[newMode]         ;PCA9685_MODE1 $0
    i2cControl = $FE                                                    ;PCA9685_PRESCALE $FE
    I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[6]               ;Prescaler is now 6 was 11
    i2cControl = $0                                                     ;PCA9685_MODE1 $0
    I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[oldMode]         ;Set old mode
    I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[oldMode | $A1 ]   ;Set MODE1 AutoIncrementOn | $A1
    Using word variables (CH1_PWM, CH2_PWN etc) for the 0 to 4095 PWM levels the following code performs the setting of channel brightness, (the value for pcaChannel runs through from 0 to 15 for the 16 channels with each increment of CHx_PWM variable if that makes sense ?)
    pcaChannel = 0
    i2cControl = $6 + 4*pcaChannel
    I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[0,0,CH1_PWM.lowbyte,CH1_PWM.highbyte]
    The above code is called when a time condition is matched, so each channel is has its own on/off time in a 24 hour period. But I want to have a manual over-ride so that if a button is pressed it jumps to a gosub routine which makes all the outputs of the PCA chip turn on. Looking at the datasheet https://cdn-shop.adafruit.com/datasheets/PCA9685.pdf there is register setting to turn all the LEDs on or off (FA, FB, FC and FD) but I don't know how to implement this in the code, so wondered if anyone has some suggestions ?
    Oct 2009
    Default Re: PCA9685 turning all outputs on / off
    Well I got a work around
    override:
    LCDOUT $FE,$D4,"All On "
    A=4095
    For B = 0 to 15
    pcaChannel = B
     I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[0,0,A.lowbyte,A.highbyte]
    next B
    If IncButton=0 then
    A=0
    For B = 0 to 15
    pcaChannel = B
    next B
    	Gosub SetButtonRelease
    	n=0
    LCDOUT $FE,$D4,"       "
    table 4 p 13 ...
    registers 250 to 255 ...
    What else ??? (Nespresso ? )
  1. PCA9685 control
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 11th April 2016, 20:36
  2. Turning a smoke machine on/off with a triac
    Last Post: - 9th January 2011, 14:16
  3. Replies: 2
    Last Post: - 6th May 2010, 09:06
  4. turning leds on and off
    By mertkon in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 04:20
  5. Turning on & off multiple interrupts
    Last Post: - 30th June 2005, 17:50
