Help Needed with DT Instant Interrupts
Results 1 to 5 of 5
    Feb 2003
    Default Help Needed with DT Instant Interrupts
    Hi All.
    Between 2001 and 2009 I did an awful lot of PBP programming and wrote many programs however one thing I didnt use was DT Instant Interrupts.
    I returned to Pic Basic programming in late 2014. At that time I upgraded to PBP3 as I needed support for newer more powerful processors. The other day I tried to add Instant Interrupts to a fairly complex program I am working on and it just likked it dead. I decided to go for the basic principles first and have tried to do the Hello World, Blinky and Elapsed Timer demos to no avail.
    I have tried using DT-INTS-18 with an 18F452 and DT-INTS-14 with a 16F877.
    With the 18F452 I can get the program below to compile and my LED2 in the main loop will toggle every second (just as a heartbeat so that I know the program is running) but ONLY if I comment out the line @ INT_ENABLE TMR1_INT. If that line is uncommented it just seems to crash, I dont get my LED2 flashing once a second and the LED1 that is supposed to be toggled by the timer interrupt does nothing either.
    '*  Name    : Instant Interrupts Test.BAS                                      *
    '*  Author  : Keith Doxey                                       *
    '*  Notice  : Copyright (c) 2016 Indigo Electronics             *
    '*  Date    : 05/05/2016                                       *
    '*  Version : 1.0   18F452                                      *
    ;----[18F452 Hardware Configuration]--------------------------------------------
    #IF __PROCESSOR__ = "18F452"
      #DEFINE MCU_FOUND 1
      CONFIG  OSC = HS           ; HS oscillator
      CONFIG  OSCS = OFF         ; Oscillator system clock switch option is disabled (main oscillator is source)
      CONFIG  PWRT = OFF         ; PWRT disabled
      CONFIG  BOR = ON           ; Brown-out Reset enabled
      CONFIG  BORV = 20          ; VBOR set to 2.0V
      CONFIG  WDT = ON           ; WDT enabled
      CONFIG  WDTPS = 128        ; 1:128
      CONFIG  CCP2MUX = ON       ; CCP2 input/output is multiplexed with RC1
      CONFIG  STVR = ON          ; Stack Full/Underflow will cause RESET
      CONFIG  LVP = OFF          ; Low Voltage ICSP disabled
      CONFIG  DEBUG = OFF        ; Background Debugger disabled. RB6 and RB7 configured as general purpose I/O pins.
      CONFIG  CP0 = OFF          ; Block 0 (000200-001FFFh) not code protected
      CONFIG  CP1 = OFF          ; Block 1 (002000-003FFFh) not code protected
      CONFIG  CP2 = OFF          ; Block 2 (004000-005FFFh) not code protected
      CONFIG  CP3 = OFF          ; Block 3 (006000-007FFFh) not code protected
      CONFIG  CPB = OFF          ; Boot Block (000000-0001FFh) not code protected
      CONFIG  CPD = OFF          ; Data EEPROM not code protected
      CONFIG  WRT0 = OFF         ; Block 0 (000200-001FFFh) not write protected
      CONFIG  WRT1 = OFF         ; Block 1 (002000-003FFFh) not write protected
      CONFIG  WRT2 = OFF         ; Block 2 (004000-005FFFh) not write protected
      CONFIG  WRT3 = OFF         ; Block 3 (006000-007FFFh) not write protected
      CONFIG  WRTC = OFF         ; Configuration registers (300000-3000FFh) not write protected
      CONFIG  WRTB = OFF         ; Boot Block (000000-0001FFh) not write protected
      CONFIG  WRTD = OFF         ; Data EEPROM not write protected
      CONFIG  EBTR0 = OFF        ; Block 0 (000200-001FFFh) not protected from Table Reads executed in other blocks
      CONFIG  EBTR1 = OFF        ; Block 1 (002000-003FFFh) not protected from Table Reads executed in other blocks
      CONFIG  EBTR2 = OFF        ; Block 2 (004000-005FFFh) not protected from Table Reads executed in other blocks
      CONFIG  EBTR3 = OFF        ; Block 3 (006000-007FFFh) not protected from Table Reads executed in other blocks
      CONFIG  EBTRB = OFF        ; Boot Block (000000-0001FFh) not protected from Table Reads executed in other blocks
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    DEFINE  OSC 40             ' 40MHZ crystal (10MHz + 4*PLL)
    LED1   VAR  PORTB.1
    LED2   var  PORTD.0
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ' Include if using PBP interrupts
    T1CON = $31                ; Prescaler = 8, TMR1ON
      PAUSE 1000
      toggle LED2
    GOTO Main
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    I dont know if its because I havent set some things up first or if I have things in the wrong order but I am starting to tear my hair out.
    The DT-INTS-14 version with the 16F877 wont even compile. I get the following errors....
    ASM Error - Symbol not previously defined (wsave)
    ASM Error - Symbol not previously defined (INT_ENTRY)
    followed by a whole load more.
    I have searched this forum and read many threads and also googled but still cant get it to work
    What are the latest version of the DT INT files as all the ones I have found predate the launch of PBP. The 14 files are from a zip file V1.1 and the 18 files I have V3.3 and 3.4 both of which I have tried with the same unsuccessful results.
    Sadly Darrel is no longer with us for me to pick his brains so I would be extremely grateful if someone could point me in the correct direction so that I can get everything working. The more I read about Instant Interrupts the more I want to use them.
    Thanks in advance
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Default Re: Help Needed with DT Instant Interrupts
    CONFIG OSC = HS ; HS oscillator ??? CONFIG OSC = HSPLL
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    if you did manage to get a @ 40mHz lock then that's a 20 Hz flash rate , bit hard to see by eye
    other than that it should be ok except for possible rmw issues
    to eliminate the possibility of rmw
    led1 var latb.1
    trisb.1=0
    ToggleLED1:
         LED1 = ! LED1
    @ INT_RETURN
    Hi, Keith
    looks your DT Ints files are not correctly installed in the folder where the .bas programs are...
    the errors reported show the compiler/assembler didn't find them ...
    the listing you provided compiles fine with MCSPX IDE ... so, the problem is in your PC.
    EDIT ...
    DT Ints here in V3.4 ...
    30 mins to edit posts is a pain !!!
    Feb 2003
    Thanks for the help guys.
    I have sussed out the two issues that I had.
    For the INTS-14 version on the 16F877 that wouldnt compile, the problem was highlighted in DT_INTS-14 itself. I should have read through the comments rather than just blindly following the examples on the web. I missed this very important bit of information......
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    The problem with the DT_INTS-18 version was also self inflicted. When I first tried to use them I got a compiler error saying that INTHAND wasnt defined.
    I looked at the include file and saw the following.....
    DEFINE  INTHAND       INT_ENTRY_H  ' Context saving for High Priority Ints
    DEFINE  INTLHAND      INT_ENTRY_L  ' Context saving for Low Priority Ints
    I saw that one was for low priority and one for high priority and assumed the first one should be INTHHAND so I edited the file. I didnt get the error anymore but it also crashed the whole program !!!
    Anyway, putting that behind me, thanks to you guys for pointing me in the right direction. If I ever stop looking at these pretty toggling LEDs I will be attempting amazing feats with interrupts to make my programs run faster and smoother.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. DT's Instant Interrupts
    By andywpg in forum mel PIC BASIC Pro
    Last Post: - 1st June 2014, 18:01
  2. instant Interrupts
    By Timmoore in forum mel PIC BASIC Pro
    Last Post: - 27th October 2009, 06:07
  3. V 2.60 and DT Instant Interrupts?
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 06:48
  4. DT Instant Interrupts
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 25th February 2009, 15:33
  5. DT Instant Interrupts help
    By perides in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 18:41
