Multi-Button CSM with Pic16LF722A
Results 1 to 32 of 32
    Apr 2016
    Mi, USA
    Default Multi-Button CSM with Pic16LF722A
    Hi!
    Well, I started a new thread, as not to confuse it with another previously posted thread concerning a PIC12F1822 and CSM application.
    I have an application that I want to use 3 capacitive touch buttons for brightness up, brightness down, and a firmware 1/0 "on/off" button for full on and full off.
    I have attached my code thus far. It works fairly well, although I would like the on off function to be latching, where the up/down can be held to step up and down in each direction. Currently the on/off function toggles at the same rate I am repeating the up/down function.
    '****************************************************************'*  Notes   : Copyright (c) 2016                                *
    '*          : Editor MicroCode Studio Plus PBP 3.0.6.0          *
    '*          : MUST BUILD PROJECT WITH MPASM ASSEMBLER           *
    '*          : Device = 16LF722A-I/SO                            *
    '*  Date    : 1/18/2016                                         *
    '*  Version : 1z                                                *
    '*  Name    : LS1236_1Z.BAS                                     *
    '*  Author  : R. WRIGHT                                         *
    'SET CONFIGURATION FOR INTERNAL OSCILLATOR WITH PLL MULTIPLIER ON
             __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDTE_OFF & _BOR_OFF & _PLLEN_ON
    define OSC 4
    INCLUDE "DT_INTS-14.bas"     ' PBP interrupt routines (MUST BE IN SAME FOLDER)
    INCLUDE "ReEnterPBP.bas"     ' Included for use of CPS module interrupt
                                 ' Courtesy of Derrel Taylor, PBP Wizard!
    Include "modedefs.bas"
    OSCCON = %00010000      'SETS INT OSC TO 4Mhz
    WPUB = %00000000        'DISABLES WEAK PULL-UP BITS
    ANSELB = %00111111      'SETS INPUTS B0-B5 AS ANALOG
    TRISB = %00111111       'SETS INPUTS B0-B5 AS INPUTS
    OPTION_REG = %10000111
                            '1 = All weak pull-ups are disabled (except MCLR, if it is enabled)
                            ' 0 = Interrupt on falling edge of RB0/INT pin
                            '  0 = Timer0 clock is internal cycle clock (Fosc/4)
                            '   0 = Increment on low-to-high transition on RA4/T0CKI pin
                            '    0 = Prescaler is assigned to the Timer0 module
                            '     111 = 1:256 Timer0 prescaler rate
    T1CON = %11000001       'enable timer 1 (bit 0) & source the clock from the CPS module (bit 6 & 7 =11)
                            'set the CPS module highest frequency availabe (for vcc mode)
                            '+ timer0 clock sourced from CPS module. (BIT 1)
    CPSCON0 = %10001100     '1 = CPS module is enabled
                            ' 000 = unused
                            '    11 = Oscillator is in High Range. Charge/Discharge Current is nominally 18 µA
                            '      0 = Capacitive Sensing Oscillator Status bit (only readable)
                            '       0 = Timer0 clock source is controlled by the core/Timer0 module and is FOSC/4
    CPSCON1 = %00000001     '0001 = channel 1, (CPS1)
    '       Software variables
    CPSX_PRESENT    var WORD   'VARIABLE FOR BUTTON CURRENT VALUE
    CPSX_THRESHOLD  var WORD   'VARIABLE FOR BUTTON THRESHOLD VALUE
    CPSX_LAST       var WORD   'VARIABLE FOR PREVIOUS BUTTON VALUE
    Duty            VAR WORD   'VARIABLE FOR DUTY CYCLE
    stepp           var byte   'VARIABLE FOR BRIGHTNESS LEVEL
    incnt           var byte   'BUTTON PUSH INCRIMENT
    '      variables used by interrupt handler, comment out as per assembler
    wsave   VAR BYTE    $20     SYSTEM       ' location for W if in bank0
    'wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM       ' location for W if in bank1
    'wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    'wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    '        SET DEVICE I/O PINS
    LED1    VAR PORTA.1          ' SET LED LEVEL INDICATORS
    LED2    VAR PORTA.2
    LED3    VAR PORTA.3
    LED4    VAR PORTA.4
    LED5    VAR PORTA.5
    ' Software/Hardware initialization
    PAUSE 50                    ' OSC settle delay
    Duty = 255                  ' SET INITIAL BRIGHTNESS TO FULL ON
    stepp = 5                   ' SET INITIAL LOOKUP TABLE TO 5
    incnt = 1                   ' set input counter to input 1
    hpwm 1,DUTY,1000            ' INITIALIZE HARDWARE PWM TO SELECTED LEVELS
    pause 1000                  ' LET EVERYTHING SETTLE
    HIGH LED5                   ' TURN ON OUTPUT FOR LED 5
    INT_LIST  macro             ; IntSource,  Label,  Type, ResetFlag?
            INT_Handler   TMR0_INT,  _Timer0_Int,   pbp,  yes
        INT_CREATE              ; Creates the interrupt processor
    TMR0 = 0                    'clear  TIMER0
    @ INT_ENABLE  TMR0_INT      ;enable timer0 interrupts
    PAUSE 100
    '------------------------------< Main program >--------------------------------
    'SCAN THE THREE INPUTS UNTIL FINGER DEPRESSION IS DETECTED VIA TIMER0 INTERRUPT
        incnt = 2
        cpscon1 = %00000001          ' 0001 = channel 1, (CPS1), DOWN BUTTON
        ANSELB =  %00000010          ' SETS INPUT B1 AS ANALOG
        TRISB =   %00000010          ' SETS INPUTS B1 AS INPUTS
        pause 5
        INcnt = 3
        cpscon1 = %00000010          ' 0010 = channel 2, (CPS2), UP BUTTON
        ANSELB =  %00000100          ' SETS INPUT B2 AS ANALOG
        TRISB =   %00000100          ' SETS INPUT B2 AS INPUT
        PAuse 5
        incnt = 1
        cpscon1 = %00000000          ' 0000 = channel 0, (CPS0), 1/0 BUTTON
        ANSELB =  %00000001          ' SETS INPUT B0 AS ANALOG
        TRISB =   %00000001          ' SETS INPUT B0 AS INPUT
        Pause 5                      ' KEEP CYCLING UNTIL INTERRUPT OCCURS
        Goto Main
    '--------------------------<INTERRRUPT ROUTINE>--------------------------------
    Timer0_Int:
    @ INT_DISABLE  TMR0_INT                             ; stop timer0 interrupts when TMR0 overflow occurs
    pause 100                                           ; PAUSE TO GET TIMER 1 COUNT
    ' store away the present timer1 count for the next time we come into the interrupt routine
    CPSX_PRESENT = TMR1                                 ' get Timer1's present count.
    CPSX_THRESHOLD = CPSX_PRESENT - ((CPSX_LAST/10)*6)  ' this sets the 'trigger' up for a 60% diversion (finger press)
    CPSX_LAST = CPSX_PRESENT
    'DETERMINES WHICH BUTTON HAS BEEN PRESSED
    IF CPSX_PRESENT < CPSX_THRESHOLD THEN
        if (incnt = 3) AND (STEPP > 1) then            ' down button pressed so decriment stepp
        stepp = stepp - 1
        GOTO SKIP1
        If (incnt = 2) AND (STEPP < 5) then            ' up button pressed so incriment stepp
        stepp = stepp + 1
        GOTO SKIP1
        IF (INCNT = 1) AND (stepp > 0) THEN            ' 1/0 button pressed for off
        STEPP = 0
        GOTO SKIP1
        IF (INCNT = 1) AND (stepp = 0) THEN            ' 1/0 button pressed for on
        STEPP = 5
    ' lights appropriate level indicator leds according to the current lookup table value
    SKIP1:
        IF STEPP = 5 THEN
        HIGH LED5
        IF STEPP = 4 THEN
        HIGH LED4
        IF STEPP = 3 THEN
        HIGH LED3
        IF STEPP = 2 THEN
        HIGH LED2
        IF STEPP = 1 THEN
        HIGH LED1
        if stepp = 0 THEN
        LOW LED1
    ' SETS HARDWARE PWM OUTPUT 1 TO DESIRED LEVEL at a frequency of 1Khz
        lookup stepp, [0,16,32,64,128,255],duty        ' choose level, 5 levels plus OFF
        hpwm 1,duty,1000                               ' set new level, frequency
        IF INCNT = 1 THEN                              ' extra delay for press of
        PAUSE 200                                      ' I/O button
    pause 10                                          ' settle time
    TMR0 = 0                                           ' clear TIMER0
    TMR1 = 0                                           ' clear TIMER1
    @ INT_ENABLE  TMR0_INT                             ; re-enable timer0 interrupt
    @ INT_RETURN
    Default Re: Multi-Button CSM with Pic16LF722A
    to answer your questions from the other thread
    Okay. But if the timer0 source works for Heckler, why won't it work in mine?
    different chip different osc speed @4mHz the tmr0 int is every 65mS the tmr1 conter may overflow , the actual free run count needs to be established and the timebase adjusted to suit
    I thought the 100mS pause was the period that the count from timer 1 is occurring?
    no the count occurs during gate interval produced by tmr0
    What is happening with CPSCON1 =CPSCON1 ^ 1?
    i had used chs 2 and 3 2^1=3 3^1=2 an easy way to toggle between chs
    Is the THRESH a fixed value predetermined? Just wondering where the THRESH CON 4000 comes from. Thanks.
    yes its derived by experiment and measurement ,don't you just love magic numbers
    It does appear to be simpler when you know what you are doing! What is happening in the ccp1con=12|((PW&3)<<4) statement?
    using 10 bit pwm thats how to set the 2 low order bits
    Another one...in your example (PIC12F1822) with the LATA and LATA.0 references, is there a way that I can implement the same function, still using the PIC16F722A device, uisng the B port instead?
    PIC16F722A has no latch registers so just use portb
    try something like this
    '*  Name    : CAPSENSE.BAS                                      *
    '*  Author  : RICHARD                                           *
    '*  Notice  : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 10/20/2011                                        *
    '*          :     16LF722A                                     *
    '#DEFINE DBUG 1
    define OSC 4
    include "dt_ints-14.bas"
    include "REENTERPBP.bas"
    asm
    INT_LIST macro
          INT_HANDLER T1GATE_INT, _TB1, PBP,YES
          INT_CREATE
     THRESH CON 8000   'needs to be established
     FLG     VAR BYTE    'GOT A KEY
     KP      VAR BYTE     'WHICH KEY  pressed
     key_inx var byte     ;key index
     PW      VAR WORD   ; PULSEWIDTH
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 7         ;pgd
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
       OSCCON = %00010000
       CPSCON0 = %10001100      'high range
       CPSCON1 = 0 'cps ch 0
       ANSELB = %00000111      'SETS INPUTS B0-B2 AS ANALOG
       TRISB = %01111111       'SETS INPUTS B0-B5 AS INPUTS  b7 output
       TRISC = %11111011        'ccp1 output portc.2
       OPTION_REG=$86      'edge int. prescale 1:128
       PIE1.7=1   'timer1 gate interrupt
       T1GCON=$f9    ' single shot timer0 overflow as input
       T1CON=%11000101   'capsense as input no prescale no sync
       INTCON= $C0       'peripheral interrupts
       PW=512
       t2con=7
       LED VAR portc.2
       ;up                down              off
       ;key0=portb.0=ch0, key1=portb.1=ch1, key2=portb.2=ch2
    #IFDEF  DBUG
        portb.7=1
        LED=1
        pause 2000
        Debug "Start",13 ,10
        LED=0
    #ENDIF
       ccp1con=12
       CCPR1L=128
       FLG=0
       key_inx=0
    MAIN:
        IF FLG=1 THEN
            IF KP = 0 THEN
               PW= (PW+64)  MIN 1023
            ELSEif  KP = 1 THEN
               PW = PW-64
               IF PW.15 THEN PW=0
             else  'MUST BE THE OTHER ONE
                ccp1con=0       ;kill it
                led=0
            CCPR1L = PW>>2;
            ccp1con=12|((PW&3)<<4);
            #IFDEF  DBUG
                debug "KEY ",#KP,13,10
                debug #PW,13,10
            #ENDIF
            PAUSE 300
            FLG=0       'clr    key pressed flag
    GOTO MAIN
    TB1:
     #IFDEF  DBUG
      debug #TMR1,13,10
     #ENDIF
     IF TMR1 <  THRESH  THEN    '   KEY DETECTED
      if !flg then
       KP=key_inx
       FLG=1         'set key pressed flag
     key_inx=key_inx+1   ;check next key
     if key_inx > 2 then key_inx=0
     CPSCON1  = key_inx
     TMR1=0
     T1GCON.3= 1 ;single shot reset
    @ INT_RETURN
    Apr 2016
    Mi, USA
    Wow! Thanks alot for all of that great info, much appreciated. Gives me something to learn from, too. I'm kind of new to this, so I haven't gotten that advanced, yet. First time I've had to use
    the capacitive touch module. Again, much appreciated!
    Apr 2016
    Mi, USA
    Hello again!
    If I want to change the order of the keys so that key0 = 1/0 (RB2), key1 = down(RB1), and key2 = up(RB0) do I need to un-remark the
    ;key0=portb.0=ch0, key1=portb.1=ch1, key2=portb.2=ch2 statement and change it, or do I need to change the code in the main portion of the program?
    Is there any way I can get the 1/0 button to toggle between off and full pwm, right now I am only getting a momentary break in the pwm when it is touched.
    In the debug setup, all I need to do is monitor the pin specified with Serial Communicator or Hyperterminal?
    I still can't believe how simple you made this look compared to my listing posted above. Thanks again!
    comments are just that ,they only serve to show what it is that the programmer decides need an explanation . they don't get compiled or participate in the execution of the code in any way. to change the way the keys are interpreted requires a change the code .
    my mistake the pw var should also be set to zero too when killing the light
    I use a pickit2 to pgm/debug with ,the debug statements suit my setup . if you use a real rs232 port to debug then a rs232/ttl level converter needs to be used and the logic level may need to be inverted [rtfm]
    should be easy , hint "FINITE STATE MACHINE"
    what did your "threshold" count need to be ?
    why not explore a "limited slew rate filter" to automatically track and adjust the threshold value . or more reliable yet, automatically track and adjust the threshold value for each individual key
    Apr 2016
    Mi, USA
    Thanks for the info. Right now I am using 16000 as a threshold, and it seems to be working well. I have a pickit2, maybe I'll try that. I also have a usb to serial in both 3v and 5v versions. I've been looking at the Microchip application notes concerning touch applications and ran across what you are talking about concerning the threshold value for each key. Maybe once I get into the debugging, I can determine if I will need to do more than a fixed threshold. Thanks again!
    Apr 2016
    Mi, USA
    Hello again,
    Okay I got the buttons to work as i wished, and I changed to 4 pwm levels. However, I have added code to indicate which of the 4 levels I am currently at.
    There is a "pause 300" that you have in the MAIN program area that delays the led indicator change from the time that the button is pressed. I tried to move the code for the led indicators to a point before the "pause 300", but then the program quits working. Is this pause what determines the time between steps if a[ button is continuously pressed, or does it serve another purpose? Another dumb thing, if I want 5 levels plus off, as shown in my previously posted example, how do I do it? Currently I am using a value of 256 from the original 16 as you had to get 4 steps, but that works out pretty evenly.
    What is "if PW.15 then PW=0" doing? Is it checking bit 15 of PW to be high? Please see cod attached.
    Thanks.
    [CODE'********************************************* *******************
    '* : All Rights Reserved *
    '* Version : 1.0 *
    '* Notes : *
    '* : 16LF722A *
    '#DEFINE DBUG 1
    define OSC 4
    ' Comment them out to fix the problem ----
    asm
    INT_LIST macro
    INT_CREATE
    THRESH CON 16000 'needs to be established
    PW VAR WORD ;PULSEWIDTH
    DEFINE DEBUG_MODE 0
    OSCCON = %00010000 '4 mhz
    T1GCON=$f9 'single shot timer0 overflow as input
    PW=1023
    t2con=7
    LED2 VAR PORTA.2
    LED3 VAR PORTA.3
    LED4 VAR PORTA.4
    LED5 VAR PORTA.5
    LED VAR portc.2
    ;up down off
    #IFDEF DBUG
    portb.7=1
    LED=1
    pause 2000
    LED=0
    #ENDIF
    ccp1con=12
    CCPR1L=255 'SET TO MAX BRIGHTNESS
    FLG=0
    key_inx=0
    MAIN:
    IF FLG=1 THEN
    IF KP = 0 THEN '1/0 BUTTON PRESSED
    ccp1con=0 ;kill it
    led=0
    PW=0
    ELSEif KP = 1 THEN 'UP BUTTON PRESSED
    PW= (PW+256) MIN 1023
    else 'DOWN BUTTON PRESSED
    PW = PW-256
    IF PW.15 THEN PW=0
    CCPR1L = PW>>2;
    #IFDEF DBUG
    debug #PW,13,10
    #ENDIF
    PAUSE 300
    IF pw = 1023 THEN
    HIGH LED5
    IF pw = 768 or PW = 767 THEN
    HIGH LED4
    IF pw = 512 or PW = 511 THEN
    HIGH LED3
    IF pw = 256 or PW = 255 THEN
    HIGH LED2
    if pw = 0 THEN
    high LED1
    GOTO MAIN
    TB1:
    #IFDEF DBUG
    debug #TMR1,13,10
    #ENDIF
    if !flg then
    KP=key_inx
    CPSCON1 = key_inx
    TMR1=0
    @ INT_RETURN][/CODE]
    the pause is there to slow the key action to human speeds ,the indicator leds can go in the key pressed loop ok as far as I can see
    with any subtraction if the result is negative (ie overflowed) then the highest order bit of the result is always set.
    ps can porta.3 be an output ?
    have a try like this
    '#DEFINE DBUG 1
     define OSC 4
     asm
     INT_LIST macro
     INT_CREATE
     p_level var byte
     DEFINE DEBUG_MODE 0
     PW=1023
     p_level=5
     t2con=7
     LED2 VAR PORTA.2
     LED3 VAR PORTA.3  ;?????????????????????????????????
     LED4 VAR PORTA.4
     LED5 VAR PORTA.5
     LED VAR portc.2
     ;up down off
     #IFDEF DBUG
     portb.7=1
     LED=1
     pause 2000
     LED=0
     #ENDIF
     ccp1con=12
     FLG=0
     key_inx=0
     MAIN:
     IF FLG=1 THEN
     ccp1con=0 ;kill it
     led=0
     p_level=0
     p_level= (p_level+1) min 5
     ;PW= (PW+256) MIN 1023
     p_level= p_level-1
     ;PW = PW-256
     IF p_level.7 THEN p_level=0
     ;IF PW.15 THEN PW=0
     lookup p_level, [0,12,48,218,586,1023],pw  'gamma 1.35,5 levels plus OFF
     CCPR1L = PW>>2;
     #IFDEF DBUG
     debug #PW,13,10
     #ENDIF
     PAUSE 300
     porta=0  ;all leds off
     IF p_level= 5 THEN
     HIGH LED5
     IF p_level=4 THEN
     HIGH LED4
     IF p_level=3 THEN
     HIGH LED3
     IF p_level=2 THEN
     HIGH LED2
     if p_level=1 THEN
     high LED1
     GOTO MAIN
     TB1:
     #IFDEF DBUG
     debug #TMR1,13,10
     #ENDIF
     if !flg then
     KP=key_inx
     CPSCON1 = key_inx
     TMR1=0
     @ INT_RETURN
    Apr 2016
    Mi, USA
    Hello,
    Wow, I can't believe how fast you can do this stuff. I tried to compile the code above, but I keep getting an [ASM WARNING] Argument out of range. Least significant bits used. (0) : Warning[202] error. Could it be because lookup only works with 8-bit Constants? Usually I can tell where the problem is by the line number given, but I can't figure this one out. Any idea? Thanks again! Sorry about the code above not being in the Window. I think I lost something when I inserted it.
    QUOTE]Could it be because lookup only works with 8-bit Constants? [/QUOTE]
    probably , I seldom use lookup(2) , try lookup2
    my preferred method is to do it this way on chips that can read their own flash memory
     pw var word ;   pulse width
     pl var byte  ;  power level  0-9
     paddress       var word   ; power level array address
    goto overpwm
    my_pwm:
    ;10 step 0.85 gamma curve
    @ dW 3,6,13,26,50,95,177,328,600,1023
    overpwm:
    @ GetAddress _my_pwm,_paddress  ;get address macro is part of dt_ints-14/18.bas
     readcode paddress+pl ,pw  ;  address + offset
    Jan 2011
    Sydney, Australia
    Hi Richard,
    Would you please explain in a little more detail as to how the "GetAddress" section of code works?
    Cheers
    Barry
    VK2XBP
    the get address macro is part of dt-ints . it places the address of a label in a pbp word var.
    this is the actual macro , its already there so why not use it.
    ;---[Returns the Address of a Label as a Word]------------------------------
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
    ;    movlw High Label         ; get high byte  MPLAB 8.53 killed high
        movlw Label >> 8         ; get high byte
        movwf Wout + 1
    endasm
    so
    gets the address of my_pwm: and places it in var paddress
    the data
    my_pwm:
    @ DW 3,6,13,26,50,95,177,328,600,1023 [data stored as an array of 14 bit values]
    each flash memory address can hold a maximum 14 bit piece of data
    i'm using that address plus an offset to index the array
    [note pw is a word var]
    so if pl= 3
    readcode paddress+3, and returns the value 26
    hope that's understandable
    ps I might add that in my setup that saves 44 words of code space compared to using lookup2
    Jan 2011
    Sydney, Australia
    Hi Richard,
    Thank you for your very clear and concise explanation.
    When you store the data, what does "DW" refer to?
    In the example you use "@ DW" however in previous code snippets you use "@ dW"
    Can you clarify please?
    Cheers
    Barry
    Any line beginning with @ is a statement for the assembler to process [just a shorthand way of ASM--DO STUFF ---ENDASM]
    the assembler is usually case sensitive CARE NEEDS TO TAKEN
    but for Data Directives like da db dw etc it seems to have no problem with the case . I only fix typing if I have to , mpasm doesn't care about the case here so nether do i
    dW == DW == Dw == [ dw – DECLARE DATA OF ONE WORD]
    for more info google mpasm assembler directives
    or
    http://ww1.microchip.com/downloads/e...Doc/33014L.pdf
    in this example I use indirect addressing to retrieve the data ,but due to the 12f1822 architecture only the low 8 bits are retrievable .wastes a bit of space but its heaps quicker
    '*  Name    : ws2812.BAS        *
    '*  Author  : richard        *
    '*  Notice  :        *
    '*  Date    : 1/11/2016        *
    '*  Version : 1.0        *
    '*  Notes   : pic12f1822  @32 mhz 3v3                                                           *
    '*          : porta.5 >>>> ws2821 Din                                                             *
    cfg1 = _FOSC_INTOSC
    cfg1&= _WDTE_ON
    cfg1&= _PWRTE_OFF
    cfg1&= _MCLRE_ON
    cfg1&= _CP_OFF
    cfg1&= _CPD_OFF
    cfg1&= _BOREN_ON
    cfg1&= _CLKOUTEN_OFF
    cfg1&= _IESO_ON
    cfg1&= _FCMEN_ON
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF
    cfg2&= _PLLEN_ON
    cfg2&= _STVREN_ON
    cfg2&= _BORV_19
    cfg2&= _LVP_OFF
      __CONFIG _CONFIG2, cfg2
     bt VAR byte  bank0
     px VAR byte  bank0
     pc var byte bank0   ; number of rgb led to write x3
     pixels  var byte[3]    ;  rgb led  x3
     DURATION  var byte
     palette var word    ;address of pallet
     TEMP VAR WORD
     OFFSET VAR WORD     ;pallet index
     goto overpalette   ; green,red,blue data
     my_palette:     ;  note !!!  inde read can only access the low byte of each  stored  word
     @ dw 100,120,0  ;
     @ dW 0,100,0  ; RED
     @ dW 0,80,0  ;
     @ dW 0,60,0  ;
     @ dW 0,20,0  ;
     @ dW 200,200,0  ;OR
     @ dW 160,160,0  ;
     @ dW 100,100,0  ;
     @ dW 80,80,0  ;
     @ dW 2,5,0  ;
     @ dW 200,150,0  ;YEL
     @ dW 160,120,0  ;
     @ dW 100,75,0  ;
     @ dW 80,60,0  ;
     @ dW 40,30,0  ;
     @ dW 150,200,0  ; ?
     @ dW 120,160,0  ;
     @ dW 75,100,0  ;
     @ dW 60,80,0  ;
     @ dW 30,40,0  ;
     @ dW 120,100,0  ;
     @ dW 160,160,160  ; WH
     @ dW 100,100,100  ;
     @ dW 80,80,80  ;
     @ dW 30,30,30  ;
        CHK?RP Wout
        movwf Wout
        movwf Wout + 1
    endasm
    overpalette :
     goto overasm
       asm
    _pram                     ;entry point to read from sram
            movlw   low _pixels
            movwf   FSR0L
            movlw   high _pixels
            movwf   FSR0H
            goto _nxby
    _prom                     ;entry point to read from flash
            CHK?RP _OFFSET
            MOVE?WW   _OFFSET , FSR0
            BSF FSR0H ,7
    _nxby   MOVIW  FSR0 ++
            movwf _px
            MOVLW 8
            movwf _bt
            RLF _px,F
    _nxbt   BSF LATA ,5
            BTFSS STATUS,C
            GOTO XX
            NOP
            NOP
            NOP
    XX      BCF  LATA ,5
            NOP
            RLF _px,F
            DECFSZ _bt,F
            GOTO _nxbt
            DECFSZ _pc,F
            GOTO _nxby
    endasm
    overasm:
     CLEAR
     define OSC 32
     osccon=$f0
     trisa=%011110
     @ GetAddress _my_palette,_palette  ;set pallet address
    loopy:
     GOSUB FLICKER
     PC=3    ; value is  number of rgb leds X 3
     call prom
     pause DURATION
     goto loopy
    FLICKER:
     RANDOM TEMP
     DURATION=TEMP&$7F
     RANDOM TEMP
    ' temp=0
     OFFSET =(TEMP //25)*3 + palette
    Apr 2016
    Mi, USA
    Hello,
    Well after changing some pause timing and sharing it before and after the indicator LED routine, It seems to be working pretty good now. However, I still need to be able to use the 1/0 button as a single shot
    button where pressing once shuts it down, as you have it, and pressing it again turns it back on with full pwm and level 5 selected, without the 1/0 button looping. You mentioned a finite machine, but I'm not sure as to how that
    applies. Also, is there a quick way that I can change the pwm frequency to 1Khz, instead of 256? Thanks.
    '****************************************************************'*  Name    : CAPSENSE.BAS                                      *
    '*          :     16LF722A                                      *
    '#DEFINE DBUG 1
    define OSC 4
    asm
    INT_LIST macro
         INT_CREATE
        p_level var byte
    DEFINE DEBUG_MODE 0
        OSCCON = 010000 '4 mhz
        CPSCON0 = 001100 'high range
        ANSELB = 000111 'SETS INPUTS B0-B2 AS ANALOG
        TRISB = 111111 'SETS INPUTS B0-B5 AS INPUTS b7 output
        WPUB = 000000 'DISABLES WEAK PULL-UP BITS
        TRISC = 111011 'ccp1 output portc.2
        T1CON=000101 'capsense as input no prescale no sync
        PW=1023
        p_level=5
        t2con=7
        LED2 VAR PORTA.2
        LED3 VAR PORTA.3
        LED4 VAR PORTA.4
        LED5 VAR PORTA.5
        LED VAR portc.2
        'up                  down               off
        'key0=portb.0=ch0, key1=portb.1=ch1, key2=portb.2=ch2
    #IFDEF DBUG
        portb.7=1
        LED=1
        pause 2000
        LED=0
    #ENDIF
        ccp1con=12
        FLG=0
        key_inx=0
    MAIN:
        IF FLG=1 THEN
        ccp1con=0 ;kill it
        led=0
        p_level=0
        'PW= (PW+256) MIN 1023
        p_level= p_level-1
        'PW = PW-256
        'IF PW.15 THEN PW=0
        lookup2 p_level, [0,12,48,218,586,1023],pw  'gamma 1.35,5 levels plus OFF
        CCPR1L = PW>>2;
    #IFDEF DBUG
    debug #PW,13,10
    #ENDIF
        PAUSE 50
        'SET DISPLAY LEDS ACCORDING TO THE BRIGHTNESS LEVEL
        IF p_level= 5 THEN
        HIGH LED5
        IF p_level=4 THEN
        HIGH LED4
        IF p_level=3 THEN
        HIGH LED3
        IF p_level=2 THEN
        HIGH LED2
        if p_level=1 THEN
        high LED1
        if p_level=0 then
        porta = 0
        PAUSE 250
        GOTO MAIN
    TB1:
    #IFDEF DBUG
    debug #TMR1,13,10
    #ENDIF
        if !flg then
        KP=key_inx
        CPSCON1 = key_inx
        TMR1=0
    @ INT_RETURN
    change t2con=7 to t2con=5
    I cannot interpret that request at all
    do you mean
    a single shot , turns it off and it stays off until reset [the real meaning of a single shot]
    or
    a toggle , turns it off if its on and turns it fully on if its off [ like an on/off .. 0/1 switch]
    no a finite STATE machine , google it (p_level could be the state )
    Apr 2016
    Mi, USA
    Yes, sorry, I guess single-shot wouldn't be a good description. I do mean a toggle , but without any auto-repeat function, as my earlier version had been.
    I meant finite STATE machine. Been a long day. Thanks for your patience. Thanks for the info on the pwm speed. I have only used the hpwm command under
    PBP to set my pwm frequencies and duty cycles in the past, I haven't got down into the nitty-gritty as much as I probably should have to get a better understanding of what's actually happening.
    you can toggle on/off like this
    ;use p_level to see what state machine is in 0=off ,non zero = on
    if p_level then
    ccp1con=0 ;must be on kill it
    led=0
    p_level= 0
    else ;must be off power to max
    p_level= 5
    stoping it repeating too quickly is a bit trickier
    a pause that's long enough to allow reaction time would do , its a bit klunky.
    the best way is to wait for the key to be released before acting (or repeating the action)
    maybe counting three passes through main loop with flg=0 after an I/O key press would indicate key is released
    and its safe to re-enable the key
    since the isr TB1 is an accurate timebase you can
    make a new var
     kio_inhibit var byte
    modify the I/o key routine
            if kio_inhibit==0 then
               kio_inhibit=152    ;152*32mS = about 5 seconds
            if  p_level then
                led=0
                p_level= 0
                p_level= 5
    and add this to the isr
    if kio_inhibit then
        kio_inhibit =  kio_inhibit -1
    now the I/O key is inhibited for 5 sec after being acted on
    I like ART's quote and its so true
    PBP is very well documented, however you’ll notice all examples of command use are also examples of exactly how not to write a cyclic program.
    you need to adjust your way of thinking to loops , states and flags . it opens up a whole new vista
    Apr 2016
    Mi, USA
    Wow, you are awesome. I'll have to try it out to see what it does. Thanks!
    Apr 2016
    Mi, USA
    Hello again,
    Was that timestamp of 3:12 as in 3:12AM?! I did the modification as above. It works like you explained. It doesn't cycle now, but the 5-second delay is way too long to be able to
    power it up again. If I change the kio_inhibit value to a shorter value, will it just end up cycling again? Is there a means that if the 1/0 button is released it resets the counter to zero so that the button can be used immediately again? The long delay is fine for when the button is being held for an extended period of time. Thanks!
    Apr 2016
    Mi, USA
    Hello again!
    Just curious as to why there isn't any reference to the PR2 register in the program, for setting up the PWM? If I wanted to increase the pwm frequency to 25Khz, I take it I would have to go to a higher oscillator frequency and use different prescaler values?! Thanks.
    flicker is virtually invisible to the human eye for switching frequencies above 50 Hz, switching losses increase with frequency , other than that the frequency is irrelevant .
    fine control of the pwm frequency is possible using pr2 at the expense of resolution . since the frequency is largely irrelevant why not have maximum resolution
    depends on required resolution, @4mHz 25kHz is possible with 1:1 prescale and pr2=39 , however maximum duty occurs @ pwm_duty_reg = 160 , ie pw range is 0 to 160 (instead of 0 to 1023 steps as before)
    Jan 2011
    Sydney, Australia
    Hi All,
    Has anyone had any experience with a 2 channel CSM slide switch?
    I would like to implement a slide switch rather than an up / down button arrangement to select the PWM output for a LED string.
    In my case, the granularity is quite coarse - only eight steps of PWM selection.
    Any input would be greatly appreciated.
    Cheers
    Barry
    Apr 2016
    Mi, USA
    Hello,
    Regarding the flicker, you know this and I know this, however, we are trying to match an existing product that is set at 25khz. It appears at lower frequencies
    it is causing their power supply to make audible noise at the PWM frequency. And sure enough, at 1khz, at certain pwm levels, we can hear it in the power supply. I don't have to keep the oscillator at 4khz, but I assume making any changes to the main Oscillator will also affect the touch circuit, as well. I did see in the pwm section of the datasheet that the resolution drops depending on the oscillator frequency after I posted this. Thanks again!
    Apr 2016
    Mi, USA
    Sorry for the repeated post.
    for barry
    have now, seems to work nicely
    slider as per http://ww1.microchip.com/downloads/e...tes/01250a.pdf
    made on ds board the bottom side is unconnected, slider pad are 10mm*40mm the top is grounded
    covered with sticky tape (durex for a sniker from the euro's)
    see pic
    a slider design like this on single sided board is worth trying out,i think it would be more sensitive and the board could be painted to encourage the user to slide finger along the horizontal line. next time i'm doing some chemical etching I will make one [if I remember]
    Is it necessary to have the ground line in the middle of the two channels? Won't this affect the operation.
    according to this app note it is
    I have not tried without it , the other way is to use a chevron pattern which has no earth requirement
    but uses more pins [several]
    OK, yes. It is used toi isolate the two sensors between them.
  1. Replies: 5
    Last Post: - 18th March 2012, 22:40
  2. multi functions button press
    By malwww in forum mel PIC BASIC Pro
    Last Post: - 27th May 2009, 01:12
  3. Multi-Threading
    By Ted's in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 06:55
  4. Multi-tasking
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 13th July 2006, 19:50
  5. Multi Interrupt How To ?
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2005, 15:48
Members who have read this thread : 4
