Using INCLUDE to add a text file in PBP3
Results 1 to 5 of 5
    Sep 2008
    Arizona
    Default Using INCLUDE to add a text file in PBP3
    I am attempting to include a text file in my program. The file consists of 120 rows of 5 numbers (1 - 5). It is to be used as data by the program. The idea is to use a random number the result of which will be used to determine what row to start on in the text file.
    As I read the manual, I get the impression that I am limited to .bas files.
    Anyone have a good idea how to do this?
    Thanks in advance,
    Bob.
    Oct 2011
    East Coast USA
    Default Re: Using INCLUDE to add a text file in PBP3
    A .bas file is simply a text file that conforms to the format that picbasic expects and can compile. You can declare arrays of variables in that file that can be used in the remainder of the program.
    Arrange your values prefixed by DATA inside the INCLUDE file, load a table (refer to manual) then process it as you see fit.
    But DATA stores the values in EEPROM - don't know if it matters in this case but it needs to be considered.
    The topic "Strings in codespace" has come up a couple of times, Darrel had some routines for it but his site is no longer available for apparent reasons. There's a repository somewhere on the forum, perhaps it's there. Anyway, here's the thread with the discussion around his code. There are other threads as well.
    has to be 18f device, org 0x.... start location in program memory..... quotes around text, spaces have to be added with dec 34, cr is dec 13
    that is text and decimals or hex numbers placed in memory at program time, accessed starting at the org location
    ''==============TABLES============= ''!!! ADD 0,0,0 TO END
    tbl1 org 0xA400
    db "HTTP/1.0 200 OK",13,"Content-Length: 800 ",13,13
    db "<html>",13,"<h1> PIC 18F...TT Server v1.0</h1>",13,"<input type=",34,"text",34," id=",34,"txt",34,">"
    db "<script type=",34,"text/javascript",34,">" ,13," var c=0;var t;var timer_is_on=0; "
    db "function timedCount(){document.getElementById('txt').value= c;c=c+1; "
    db "t=setTimeout(",34,"timedCount()",34,",1000);}func tion doTimer(){if (!timer_is_on){timer_is_on=1;timedCount();}} "
    db "</script><form method=",34,"get",34,">Project name: <input type=",34,"text",34," name=",34,"PIC",34," value=",34,"PIC18F2525 ",34," />"
    db "<br>select one: <select><option>Amps</option> "
    db "<option>Volts</option><option>Frequency</option> </select>"
    db "<input type=",34,"submit",34," value=",34,"Submit",34," /></form> "
    db "<body onLoad=",34,"doTimer()",34,"><p><b>Note: TEXT HERE </b><br><script type=",34,"text/vbscript",34,">"
    db "document.write(NOW & ",34," Hello World!",34,")</script><br></body></p> </html> "
    db "<style type=",34,"text/css",34,">body{background-color:#d0e4fe;}h1{color:red;} style> "
    db "<BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR>< BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR><BR ><BR> ",0,0,0
  1. PBP3 to include 18F97J94?
    By fowardbias in forum PBP3
    Last Post: - 18th December 2013, 17:42
  2. Include File problem
    Last Post: - 23rd March 2011, 18:44
  3. Can't seem to add AllDigital to the include files
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 12th November 2009, 05:21
  4. Include ASM file help
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2007, 21:22
  5. The ultimate include file
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 26th January 2007, 20:35
