Multiple Block Write SD protocol issue
Results 1 to 2 of 2
    Sep 2009
    South Wales (UK)
    Default Multiple Block Write SD protocol issue
    1. Hi all,
    I've been working with SD cards for a couple of years now, but only using Single Block Write. I'm trying to get Multiple Block Write to work but it fails after writing the first set.
    Posting code will be difficult as it's a complicated program and would be easier if I started again, just to put something up to post.
    What I've been trying so far is to use CMD25 and sending four blocks of data (4x 512 bytes) and then, once they've gone through, sending a single byte $fd using:
    SDC_data_in = SSPBUF
    SSPIF = 0
    SSPBUF = $FD
    While !SSPIF
    Wend
    and then raising the CS line to, in theory, finish that set of block writes.
    Then, when I wish to write another set of 4 blocks (at the next available address), I do the same as above, but, after the first 512 bytes go through, I get a data not accepted error ("Unknown fail"):
    for cnt = 0 to 511
         SDC_data_out = SDC_buffer[SDC_buffer_current_mul+cnt]
         gosub write_byte
    next cnt
    SDC_data_out = $ff
    gosub write_byte	      ' send 16 1s as a dummy CRC
    gosub write_byte
    SDC_data_in = SSPBUF	  ' clear the buffer
    SSPIF = 0		          ' clear the interrupt flag
    SSPBUF = $ff		      ' shift out a dummy byte
    While !SSPIF		      ' wait for receive byte
    Wend
    SDC_data_in = SSPBUF	  ' get the byte
    If ((SDC_data_in & $0f) != DATA_ACCEPTED) Then
            SEROUT2 Serial_out,6,[$d,$a,"Unknown fail"]
            high red_led
            gosub stop_read
    Does anyone have any code that successfully sets up a multiple block write to an SD card, terminates using the multiple stop token, and then successfully repeats this on the same card? I've been trying to do this for 3 days now with no success.
    I also tried CMD12 but I got an Illegal Command error in the R1 response.
    I have checked using a hex editor (changing the data it's writing each time to make sure it 'is' doing its job) that the 4 blocks are being written in the first multiple block write instance...
    Best,
    Jimbo
    Bombay, India
    Default Re: Multiple Block Write SD protocol issue
  1. Multiple Block Write SD protocol issue
    By jimbostlawrence in forum General
    Last Post: - 16th April 2016, 14:58
  2. Multiple Block Write SD protocol issue
    By jimbostlawrence in forum mel PIC BASIC Pro
    Last Post: - 14th February 2016, 20:25
  3. Lcdout multiple variables issue
    By MarkEngineer in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2015, 14:51
  4. DT Multiple Software PWM and 18F2321 issue
    By microuser in forum mel PIC BASIC Pro
    Last Post: - 20th December 2012, 08:23
  5. SD Multiple Write?
    Last Post: - 21st October 2011, 17:45
