PICKIT 2 verification failed at memory address 0x0000
THE BOOK of DT's INTERRUPTS is an organization of interrupt service routines and other works written by Darrel Taylor, RIP.
Interrupt routines are arranged per Darrel's original list. Darrel Taylor's Instant Interrupts are an extension of the work of Tim Box whom in October of 2002 wrote INT_CTRL.pbp
Many of the forum members felt this is a long overdue project.
will be a valuable resource and a tribute to Darrel Taylor the "Fanatical Contributor".
THE BOOK of DT's INTERRUPTS is located at http://dt.picbasic.co.uk/
+ Reply to Thread
Results 1 to 3 of 3
    Jan 2016
    Default PICKIT 2 verification failed at memory address 0x0000
    I have been using a "pic16f628A"
    The problem I am getting:
    Failed to verify at programming address 0x0000 (when I click the Verify button).
    Failed to program at programming address 0x0000 (when I click the Write button).
    Successful (when I click Read button).
    Successful (when I click erase button).
    when I put another chip with same model is working
    Dec 2010
    Default Re: PICKIT 2 verification failed at memory address 0x0000
    Maybe a silly question but are you SURE it's connected properly? Pins not offset by one, connector not backwards, no broken wires?
    Oct 2021
    I had the same problem. Measure the correct value of the programming voltage.
  1. First try at DT_INT's, I failed! help please!
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2012, 22:07
  2. Debug Failed
    By firdano in forum General
    Last Post: - 10th February 2011, 15:08
  3. Replies: 12
    Last Post: - 4th March 2010, 21:20
  4. DTMF verification
    Last Post: - 1st May 2008, 23:28
  5. Timing verification.
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 31st August 2004, 15:44
