PICKIT 2 verification failed at memory address 0x0000
Results 1 to 3 of 3
    Jan 2016
    Default PICKIT 2 verification failed at memory address 0x0000
    I have been using a "pic16f628A"
    The problem I am getting:
    Failed to verify at programming address 0x0000 (when I click the Verify button).
    Failed to program at programming address 0x0000 (when I click the Write button).
    Successful (when I click Read button).
    Successful (when I click erase button).
    when I put another chip with same model is working
    Dec 2010
    Default Re: PICKIT 2 verification failed at memory address 0x0000
    Maybe a silly question but are you SURE it's connected properly? Pins not offset by one, connector not backwards, no broken wires?
    Oct 2021
    I had the same problem. Measure the correct value of the programming voltage.
  1. First try at DT_INT's, I failed! help please!
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2012, 22:07
  2. Debug Failed
    By firdano in forum General
    Last Post: - 10th February 2011, 15:08
  3. Replies: 12
    Last Post: - 4th March 2010, 21:20
  4. DTMF verification
    Last Post: - 1st May 2008, 23:28
  5. Timing verification.
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 31st August 2004, 15:44
