RN-131 WiFly Module
Results 1 to 5 of 5
    Sep 2005
    Default RN-131 WiFly Module
    Hi All,
    Has anyone played with the RN-131 WiFly Module?, I have one and been playing about and seem to have everything working except trying to log onto an Access Point, I can keep getting the error AUTH-ERR, if someone could help me see where I am going wrong that would help allot!,
    Many Thanks,
    Gavo
    Default Re: RN-131 WiFly Module
    How about posting some relevant code.
    Sep 2005
    I don't have code at the moment as I have playing in a Terminal Program, please see below:
    wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:28 on RN-131
    MAC Addr=00:06:66:21:c5:61
    *READY*
    CMD
    scan
    ERR: ?-Cmd
    <4.00> scan
    <4.00>
    SCAN:Found 5
    01,01,-48,00,0104,00,00,00:9c:02:cc:6a:18,HP-Print-18-Officejet Pro 8600
    02,01,-29,04,110c,28,c0,a0:63:91:d0:4d:f5,OConnor-Bedfordview_2GEXT
    03,01,-75,02,1104,28,00,c8:3a:35:2d:b0:c8,Gaspari
    04,04,-66,04,1115,28,40,a4:2b:b0:f0:b7:be,TP-LINK_2.4GHz_F0B7BE
    05,06,-41,04,3104,28,40,9e:a9:e4:a8:3a:c0,VodafoneMobileW iFi-A83AC0
    END:
    set wlan phrase <mVT6705985>
    AOK
    <4.00> join # 5
    Auto-Assoc VodafoneMobileWiFi-A83AC0 chan=6 mode=MIXED SCAN OK
    <4.00> Joining VodafoneMobileWiFi-A83AC0 now..
    Disconn from VodafoneMobileWiFi-A83AC0,1:2
    Disconn from VodafoneMobileWiFi-A83AC0,AUTH-ERR
    scan
    <4.00>
    SCAN:Found 5
    01,01,-49,00,0104,00,00,00:9c:02:cc:6a:18,HP-Print-18-Officejet Pro 8600
    03,01,-76,02,1104,28,00,c8:3a:35:2d:b0:c8,Gaspari
    04,04,-68,04,1115,28,40,a4:2b:b0:f0:b7:be,TP-LINK_2.4GHz_F0B7BE
    05,06,-33,04,3104,28,40,9e:a9:e4:a8:3a:c0,VodafoneMobileW iFi-A83AC0
    END:
    set wlan pass <mVT6705985>
    AOK
    <4.00> join # 5
    set wlan number <mVT6705985>
    AOK
    <4.00> join # 5
    You have set wlan phrase <mVT6705985> and set wlan pass <mVT6705985> both seem incorrect according to following.
    In the PDF page 27 I got from here http://ww1.microchip.com/downloads/e.../50002230B.pdf it says
    If the access point is secure, the passphrase must be set prior to issuing the join
    command. The RN module attempts to inquire and determine the access point’s
    security protocol which means the authentication mode does not need to be set. To set
    the WPA passphrase use the set wlan passphrase <string> command.
    For WEP,
    set the key using the set wlan key <value> command.
    Could this be your problem, I would also have turned off encryption when testing, when that is working then try with encryption.
    Sep 2005
    I found the problem - have it working now, I put the Password as set wlan passphrase <gavo1234> and it should of been set wlan passphrase gavo1234
    All working now and thanks for the help!
  1. New WiFi Module
    By dhouston in forum WiFi
    Last Post: - 15th February 2017, 09:27
  2. RF module help
    By greensasquatch in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 18:50
  3. Replies: 1
    Last Post: - 27th July 2008, 06:14
  4. RF Module
    By shahidali55 in forum General
    Last Post: - 9th March 2007, 09:00
  5. Rf module
    By tangray in forum Adverts
    Last Post: - 7th August 2006, 07:14
