Do you think about adding functions to control Graphic LCDs (PicBasic)?
Thanks...
Thanks...
I agree graphic support would be nice. Graphic displays are more complicated but PBP support could simplify text and bargraph routines, especially for the novice.
Yes, yes its great idea. We need the Graphic LCD library. We look forward to this support.
thanks a lot
And I suppose you'd like it to fit into a 1K Memory device like 16F84 ????Originally Posted by muskut
Try being serious !!! Just have a look to what exists on the subject ...with a serial input and "line, circle, etc .." commands, it just needs a 16F876@20 Mhz... for a 64 x 128 display.
And it's full from full's ... LoL !!!
Look at this forum title "PBP Wish List".
And this is my wish. It can be or not. Please Dont move with your supposition and please be careful your words. I bought this compiler and I gave my money for this compiler so I have chance to express my wish to the engineers of the PBP. If the Customer Support of this compiler is good they will consider our wishes. If this wish is possible they will talk about, if its not they will talk about agian.
thank you so much.
Hi, Muskut
IF you daren't read your manual, how will you do for such a complicated piece of software...
hmmmm ????
Hellow
I Want The File By Whish I Can Write Progrsm With Pbp
Or Beatsh
Thank You
I'd guess the main reason for no graphic support is all the different types of graphic LCD's out there. If MELabs offered support for say the KS0108 type, people would want some other LCD variety supported too.
The graphic LCD's are really fairly easy to use if you read the data sheets several times (the data sheets are typically pretty poor translations).
There is also a web-site with some sample code:
http://www.compsys1.com/workbench/
Writing your own code allows you to tailor everything to your specific needs, without filling up a whole '876!
Dear All,
i would like to use GLCD but i cannot do it as your discussion here.
I only found on the net that PROTON and micro e are able to control very easy GLCD.
The problem is that we are using now picbasic and i dont wont to change from that, i'm used to it.
Is there any plan to see an update of the picbasic pro for supporting the GLCD?
Did you search the forum for your particular model of GLCD?
Did you start a thread asking for help on code or schematic?
There's already several examples on these forums. Sometimes you can use techniques used for one model and customize it for another with just a few tweaks.
There was one particular model that I had used that had no examples anywhere on the web. I started with the datasheet, found a "close model" and went on from there.
Putting too much functionality into PICs is not necessarily a good idea, it takes up space. Imagine if all PICs now had DT's interrupt, barely enough room to LCDOUT "Hello" on most of them, if at all.
yes i have searched for the GLCD 128x64 with Samsung KS0108.
to be honest with Proton i did a grahpical model in less that 10 minutes.
Is it so difficult to put a library for these GLCDs? I dont care for the PIC's space since there are 32x16 ones that can store an elephant in there.
I just want my life to be easier and save time. I didnt ask for a code but for better features like proton and micro c
I'm currently working on a driver for the GLCD.
Here you can see how far I got.
Code:'**************************************************************** '* Name : GLCD driver * '* Author : Pedja089 * '**************************************************************** ' LCD Commands are: ' Lcd_Init ' Lcd_SetX ' Lcd_SetY ' Lcd_Clr ' Lcd_On ' @ PrintStr x,y, "string goes here" ' will auto wrap to next line if needed ' @ PrintVar x,y, _anyvariablehere ' You can manually position x,y and print characters by the following: ' PosX = 0 ' move to position 0 of 83 (char best viewed at spacing of 6) ' PosY = 1 ' move to second line of 6 ' Lcd_SetX ' Lcd_SetY ' Lcd_Data = "H" ' Note byte size single char. ' Gosub Lcd_SendChar symbol RW=portb.3 symbol RS = portb.2 symbol E = portb.4 symbol CS1 = portb.0 symbol CS2 = portb.1 symbol RST = portb.5 Symbol LCD_DATA=portd LCD_DATA=0 TRISD=0 output rst Output RW Output RS Output E Output CS1 Output CS2 PosX var Byte ' Variable for Position X PosY var Byte ' Variable for Position Y GLCD_SX var byte GLCD_X var byte GLCD_FC var Byte [5] ' Variable 5 bytes = 1 character GLCD_CharNum var byte ' character number GLCD_VarData var word ' variable to print to lcd GLCD_n0 var byte ' for next variable GLCD_n1 var byte GLCD_digits var bit ' number of digits in VarData GLCD_Addr VAR WORD GLCD_Char VAR byte ' lcdchardata[0] gosub Lcd_init goto OverLCD '_______________________________________________________________________________ ' @ PrintVar macro function ' format should look like this: @ PrintVar x,y, _anyvariable ASM PrintVar macro x, y, Variable ; input values from: @PrintVar 0,1, _any_variable local OverVar goto OverVar OverVar MOVE?CB x, _GLCD_X MOVE?CB x, _GLCD_SX MOVE?CB y, _PosY ; move y from above statement to PosY MOVE?WW Variable, _GLCD_VarData ; move variable in statement to VarData L?CALL _GLCD_VariableOut ; call VariableOut function endm ENDASM GLCD_VariableOut: 'for GLCD_n1 = 4 to 0 step -1 ' cycles through all possible digits of number Gosub Lcd_SetX Gosub Lcd_SetY ' place character at position PosX and PosY GLCD_Char = (GLCD_VarData dig 2) + 48 ' digit number n to character str format gosub Lcd_SendChar ' print char to screen PosX = PosX + 6 ' next x position for character Gosub Lcd_SetX Gosub Lcd_SetY ' place character at position PosX and PosY GLCD_Char = (GLCD_VarData dig 1) + 48 ' digit number n to character str format gosub Lcd_SendChar ' print char to screen PosX = PosX + 6 ' next x position for character Gosub Lcd_SetX Gosub Lcd_SetY ' place character at position PosX and PosY GLCD_Char = (GLCD_VarData dig 0) + 48 ' digit number n to character str format gosub Lcd_SendChar ' print char to screen PosX = PosX + 6 ' next x position for character GLCD_SkipChar: 'next GLCD_n1 return '_______________________________________________________________________________ ASM PrintStr macro x, y, Str local TheString, OverStr goto OverStr TheString data Str, 0 OverStr MOVE?CB x, _GLCD_X MOVE?CB x, _GLCD_SX MOVE?CB y, _PosY MOVE?CW TheString, _GLCD_Addr L?CALL _GLCD_StringOut endm ENDASM GLCD_StringOut: Readcode GLCD_Addr, GLCD_Char ' Get a character if GLCD_Char = 0 then GLCD_StringDone ' Look for Null char, Stop if found if glcd_x=> 123 then ' If end of line, cycle to next line PosY = PosY + 1 glcd_x=GLCD_SX endif If glcd_x<64 then lcd_data=0 cs1=0 cs2=1 posx=glcd_x else lcd_data=0 cs1=1 cs2=0 posx=glcd_x-64 endif Gosub Lcd_SetX gosub Lcd_SetY gosub Lcd_SendChar ' puttext GLCD_Addr = GLCD_Addr + 1 ' Point to next character glcd_x=glcd_x + 1 goto GLCD_StringOut ' Continue with rest of the string GLCD_StringDone: return '_______________________________________________________________________________ Lcd_SendChar: lookdown GLCD_Char,_ [" !\#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz{|}~"],GLCD_CharNum GLCD_Char = GLCD_CharNum +32 sELECT CASE GLCD_Char Case 32 GLCD_FC(0)=$00:GLCD_FC(1)=$00:GLCD_FC(2)=$00:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // sp Case 33 GLCD_FC(0)=$00:GLCD_FC(1)=$00:GLCD_FC(2)=$2f:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // ! Case 34 GLCD_FC(0)=$00:GLCD_FC(1)=$07:GLCD_FC(2)=$00:GLCD_FC(3)=$07:GLCD_FC(4)=$00 ' // " (shown as \ in Lookdown table) Case 35 GLCD_FC(0)=$14:GLCD_FC(1)=$7f:GLCD_FC(2)=$14:GLCD_FC(3)=$7f:GLCD_FC(4)=$14 ' // # Case 36 GLCD_FC(0)=$24:GLCD_FC(1)=$2a:GLCD_FC(2)=$7f:GLCD_FC(3)=$2a:GLCD_FC(4)=$12 ' // $ Case 37 GLCD_FC(0)=$c4:GLCD_FC(1)=$c8:GLCD_FC(2)=$10:GLCD_FC(3)=$26:GLCD_FC(4)=$46 ' // % Case 38 GLCD_FC(0)=$36:GLCD_FC(1)=$49:GLCD_FC(2)=$55:GLCD_FC(3)=$22:GLCD_FC(4)=$50 ' // & Case 39 GLCD_FC(0)=$00:GLCD_FC(1)=$05:GLCD_FC(2)=$03:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // ' Case 40 GLCD_FC(0)=$00:GLCD_FC(1)=$1c:GLCD_FC(2)=$22:GLCD_FC(3)=$41:GLCD_FC(4)=$00 ' // ( Case 41 GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$22:GLCD_FC(3)=$1c:GLCD_FC(4)=$00 ' // ) Case 42 GLCD_FC(0)=$14:GLCD_FC(1)=$08:GLCD_FC(2)=$3E:GLCD_FC(3)=$08:GLCD_FC(4)=$14 ' // * Case 43 GLCD_FC(0)=$08:GLCD_FC(1)=$08:GLCD_FC(2)=$3E:GLCD_FC(3)=$08:GLCD_FC(4)=$08 ' // + Case 44 GLCD_FC(0)=$00:GLCD_FC(1)=$00:GLCD_FC(2)=$50:GLCD_FC(3)=$30:GLCD_FC(4)=$00 ' // , Case 45 GLCD_FC(0)=$10:GLCD_FC(1)=$10:GLCD_FC(2)=$10:GLCD_FC(3)=$10:GLCD_FC(4)=$10 ' // - Case 46 GLCD_FC(0)=$00:GLCD_FC(1)=$60:GLCD_FC(2)=$60:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // . Case 47 GLCD_FC(0)=$20:GLCD_FC(1)=$10:GLCD_FC(2)=$08:GLCD_FC(3)=$04:GLCD_FC(4)=$02 ' // / Case 48 GLCD_FC(0)=$3E:GLCD_FC(1)=$51:GLCD_FC(2)=$49:GLCD_FC(3)=$45:GLCD_FC(4)=$3E ' // 0 Case 49 GLCD_FC(0)=$00:GLCD_FC(1)=$42:GLCD_FC(2)=$7F:GLCD_FC(3)=$40:GLCD_FC(4)=$00 ' // 1 Case 50 GLCD_FC(0)=$42:GLCD_FC(1)=$61:GLCD_FC(2)=$51:GLCD_FC(3)=$49:GLCD_FC(4)=$46 ' // 2 Case 51 GLCD_FC(0)=$21:GLCD_FC(1)=$41:GLCD_FC(2)=$45:GLCD_FC(3)=$4B:GLCD_FC(4)=$31 ' // 3 Case 52 GLCD_FC(0)=$18:GLCD_FC(1)=$14:GLCD_FC(2)=$12:GLCD_FC(3)=$7F:GLCD_FC(4)=$10 ' // 4 Case 53 GLCD_FC(0)=$27:GLCD_FC(1)=$45:GLCD_FC(2)=$45:GLCD_FC(3)=$45:GLCD_FC(4)=$39 ' // 5 Case 54 GLCD_FC(0)=$3C:GLCD_FC(1)=$4A:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$30 ' // 6 Case 55 GLCD_FC(0)=$01:GLCD_FC(1)=$71:GLCD_FC(2)=$09:GLCD_FC(3)=$05:GLCD_FC(4)=$03 ' // 7 Case 56 GLCD_FC(0)=$36:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$36 ' // 8 Case 57 GLCD_FC(0)=$06:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$29:GLCD_FC(4)=$1E ' // 9 Case 58 GLCD_FC(0)=$00:GLCD_FC(1)=$36:GLCD_FC(2)=$36:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // : Case 59 GLCD_FC(0)=$00:GLCD_FC(1)=$56:GLCD_FC(2)=$36:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // ";" Case 60 GLCD_FC(0)=$08:GLCD_FC(1)=$14:GLCD_FC(2)=$22:GLCD_FC(3)=$41:GLCD_FC(4)=$00 ' // < Case 61 GLCD_FC(0)=$14:GLCD_FC(1)=$14:GLCD_FC(2)=$14:GLCD_FC(3)=$14:GLCD_FC(4)=$14 ' // = Case 62 GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$22:GLCD_FC(3)=$14:GLCD_FC(4)=$08 ' // > Case 63 GLCD_FC(0)=$02:GLCD_FC(1)=$01:GLCD_FC(2)=$51:GLCD_FC(3)=$09:GLCD_FC(4)=$06 ' // ? Case 64 GLCD_FC(0)=$32:GLCD_FC(1)=$49:GLCD_FC(2)=$59:GLCD_FC(3)=$51:GLCD_FC(4)=$3E ' // @ Case 65 GLCD_FC(0)=$7E:GLCD_FC(1)=$11:GLCD_FC(2)=$11:GLCD_FC(3)=$11:GLCD_FC(4)=$7E ' // A Case 66 GLCD_FC(0)=$7F:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$36 ' // B Case 67 GLCD_FC(0)=$3E:GLCD_FC(1)=$41:GLCD_FC(2)=$41:GLCD_FC(3)=$41:GLCD_FC(4)=$22 ' // C Case 68 GLCD_FC(0)=$7F:GLCD_FC(1)=$41:GLCD_FC(2)=$41:GLCD_FC(3)=$22:GLCD_FC(4)=$1C ' // D Case 69 GLCD_FC(0)=$7F:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$41 ' // E Case 70 GLCD_FC(0)=$7F:GLCD_FC(1)=$09:GLCD_FC(2)=$09:GLCD_FC(3)=$09:GLCD_FC(4)=$01 ' // F Case 71 GLCD_FC(0)=$3E:GLCD_FC(1)=$41:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$7A ' // G Case 72 GLCD_FC(0)=$7F:GLCD_FC(1)=$08:GLCD_FC(2)=$08:GLCD_FC(3)=$08:GLCD_FC(4)=$7F ' // H Case 73 GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$7F:GLCD_FC(3)=$41:GLCD_FC(4)=$00 ' // I Case 74 GLCD_FC(0)=$20:GLCD_FC(1)=$40:GLCD_FC(2)=$41:GLCD_FC(3)=$3F:GLCD_FC(4)=$01 ' // J Case 75 GLCD_FC(0)=$7F:GLCD_FC(1)=$08:GLCD_FC(2)=$14:GLCD_FC(3)=$22:GLCD_FC(4)=$41 ' // K Case 76 GLCD_FC(0)=$7F:GLCD_FC(1)=$40:GLCD_FC(2)=$40:GLCD_FC(3)=$40:GLCD_FC(4)=$40 ' // L Case 77 GLCD_FC(0)=$7F:GLCD_FC(1)=$02:GLCD_FC(2)=$0C:GLCD_FC(3)=$02:GLCD_FC(4)=$7F ' // M Case 78 GLCD_FC(0)=$7F:GLCD_FC(1)=$04:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$7F ' // N Case 79 GLCD_FC(0)=$3E:GLCD_FC(1)=$41:GLCD_FC(2)=$41:GLCD_FC(3)=$41:GLCD_FC(4)=$3E ' // O Case 80 GLCD_FC(0)=$7F:GLCD_FC(1)=$09:GLCD_FC(2)=$09:GLCD_FC(3)=$09:GLCD_FC(4)=$06 ' // P Case 81 GLCD_FC(0)=$3E:GLCD_FC(1)=$41:GLCD_FC(2)=$51:GLCD_FC(3)=$21:GLCD_FC(4)=$5E ' // Q Case 82 GLCD_FC(0)=$7F:GLCD_FC(1)=$09:GLCD_FC(2)=$19:GLCD_FC(3)=$29:GLCD_FC(4)=$46 ' // R Case 83 GLCD_FC(0)=$46:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$31 ' // S Case 84 GLCD_FC(0)=$01:GLCD_FC(1)=$01:GLCD_FC(2)=$7F:GLCD_FC(3)=$01:GLCD_FC(4)=$01 ' // T Case 85 GLCD_FC(0)=$3F:GLCD_FC(1)=$40:GLCD_FC(2)=$40:GLCD_FC(3)=$40:GLCD_FC(4)=$3F ' // U Case 86 GLCD_FC(0)=$1F:GLCD_FC(1)=$20:GLCD_FC(2)=$40:GLCD_FC(3)=$20:GLCD_FC(4)=$1F ' // V Case 87 GLCD_FC(0)=$3F:GLCD_FC(1)=$40:GLCD_FC(2)=$38:GLCD_FC(3)=$40:GLCD_FC(4)=$3F ' // W Case 88 GLCD_FC(0)=$63:GLCD_FC(1)=$14:GLCD_FC(2)=$08:GLCD_FC(3)=$14:GLCD_FC(4)=$63 ' // X Case 89 GLCD_FC(0)=$07:GLCD_FC(1)=$08:GLCD_FC(2)=$70:GLCD_FC(3)=$08:GLCD_FC(4)=$07 ' // Y Case 90 GLCD_FC(0)=$61:GLCD_FC(1)=$51:GLCD_FC(2)=$49:GLCD_FC(3)=$45:GLCD_FC(4)=$43 ' // Z Case 91 GLCD_FC(0)=$00:GLCD_FC(1)=$7F:GLCD_FC(2)=$41:GLCD_FC(3)=$41:GLCD_FC(4)=$00 ' // [ Case 92 GLCD_FC(0)=$02:GLCD_FC(1)=$04:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$20 ' // \ (we are using this for Case 34 " above) Case 93 GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$41:GLCD_FC(3)=$7F:GLCD_FC(4)=$00 ' // ] Case 94 GLCD_FC(0)=$04:GLCD_FC(1)=$02:GLCD_FC(2)=$01:GLCD_FC(3)=$02:GLCD_FC(4)=$04 ' // ^ Case 95 GLCD_FC(0)=$40:GLCD_FC(1)=$40:GLCD_FC(2)=$40:GLCD_FC(3)=$40:GLCD_FC(4)=$40 ' // _ Case 96 ' GLCD_FC(0)=$00:GLCD_FC(1)=$01:GLCD_FC(2)=$02:GLCD_FC(3)=$04:GLCD_FC(4)=$00 ' // ` GLCD_FC(0)=$02:GLCD_FC(1)=$04:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$20 ' // \ (shown as ` in Lookdown table) Case 97 GLCD_FC(0)=$20:GLCD_FC(1)=$54:GLCD_FC(2)=$54:GLCD_FC(3)=$54:GLCD_FC(4)=$78 ' // a Case 98 GLCD_FC(0)=$7F:GLCD_FC(1)=$48:GLCD_FC(2)=$44:GLCD_FC(3)=$44:GLCD_FC(4)=$38 ' // b Case 99 GLCD_FC(0)=$38:GLCD_FC(1)=$44:GLCD_FC(2)=$44:GLCD_FC(3)=$44:GLCD_FC(4)=$20 ' // c Case 100 GLCD_FC(0)=$38:GLCD_FC(1)=$44:GLCD_FC(2)=$44:GLCD_FC(3)=$48:GLCD_FC(4)=$7F ' // d Case 101 GLCD_FC(0)=$38:GLCD_FC(1)=$54:GLCD_FC(2)=$54:GLCD_FC(3)=$54:GLCD_FC(4)=$18 ' // e Case 102 GLCD_FC(0)=$08:GLCD_FC(1)=$7E:GLCD_FC(2)=$09:GLCD_FC(3)=$01:GLCD_FC(4)=$02 ' // f Case 103 GLCD_FC(0)=$0C:GLCD_FC(1)=$52:GLCD_FC(2)=$52:GLCD_FC(3)=$52:GLCD_FC(4)=$3E ' // g Case 104 GLCD_FC(0)=$7F:GLCD_FC(1)=$08:GLCD_FC(2)=$04:GLCD_FC(3)=$04:GLCD_FC(4)=$78 ' // h Case 105 GLCD_FC(0)=$00:GLCD_FC(1)=$44:GLCD_FC(2)=$7D:GLCD_FC(3)=$40:GLCD_FC(4)=$00 ' // i Case 106 GLCD_FC(0)=$20:GLCD_FC(1)=$40:GLCD_FC(2)=$44:GLCD_FC(3)=$3D:GLCD_FC(4)=$00 ' // j Case 107 GLCD_FC(0)=$7F:GLCD_FC(1)=$10:GLCD_FC(2)=$28:GLCD_FC(3)=$44:GLCD_FC(4)=$00 ' // k Case 108 GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$7F:GLCD_FC(3)=$40:GLCD_FC(4)=$00 ' // l Case 109 GLCD_FC(0)=$7C:GLCD_FC(1)=$04:GLCD_FC(2)=$18:GLCD_FC(3)=$04:GLCD_FC(4)=$78 ' // m Case 110 GLCD_FC(0)=$7C:GLCD_FC(1)=$08:GLCD_FC(2)=$04:GLCD_FC(3)=$04:GLCD_FC(4)=$78 ' // n Case 111 GLCD_FC(0)=$38:GLCD_FC(1)=$44:GLCD_FC(2)=$44:GLCD_FC(3)=$44:GLCD_FC(4)=$38 ' // o Case 112 GLCD_FC(0)=$7C:GLCD_FC(1)=$14:GLCD_FC(2)=$14:GLCD_FC(3)=$14:GLCD_FC(4)=$08 ' // p Case 113 GLCD_FC(0)=$08:GLCD_FC(1)=$14:GLCD_FC(2)=$14:GLCD_FC(3)=$18:GLCD_FC(4)=$7C ' // q Case 114 GLCD_FC(0)=$7C:GLCD_FC(1)=$08:GLCD_FC(2)=$04:GLCD_FC(3)=$04:GLCD_FC(4)=$08 ' // r Case 115 GLCD_FC(0)=$48:GLCD_FC(1)=$54:GLCD_FC(2)=$54:GLCD_FC(3)=$54:GLCD_FC(4)=$20 ' // s Case 116 GLCD_FC(0)=$04:GLCD_FC(1)=$3F:GLCD_FC(2)=$44:GLCD_FC(3)=$40:GLCD_FC(4)=$20 ' // t Case 117 GLCD_FC(0)=$3C:GLCD_FC(1)=$40:GLCD_FC(2)=$40:GLCD_FC(3)=$20:GLCD_FC(4)=$7C ' // u Case 118 GLCD_FC(0)=$1C:GLCD_FC(1)=$20:GLCD_FC(2)=$40:GLCD_FC(3)=$20:GLCD_FC(4)=$1C ' // v Case 119 GLCD_FC(0)=$3C:GLCD_FC(1)=$40:GLCD_FC(2)=$30:GLCD_FC(3)=$40:GLCD_FC(4)=$3C ' // w Case 120 GLCD_FC(0)=$44:GLCD_FC(1)=$28:GLCD_FC(2)=$10:GLCD_FC(3)=$28:GLCD_FC(4)=$44 ' // x Case 121 GLCD_FC(0)=$0C:GLCD_FC(1)=$50:GLCD_FC(2)=$50:GLCD_FC(3)=$50:GLCD_FC(4)=$3C ' // y Case 122 GLCD_FC(0)=$44:GLCD_FC(1)=$64:GLCD_FC(2)=$54:GLCD_FC(3)=$4C:GLCD_FC(4)=$44 ' // z case 123 ' GLCD_FC(0)=$00:GLCD_FC(1)=$08:GLCD_FC(2)=$36:GLCD_FC(3)=$41:GLCD_FC(4)=$00' // { GLCD_FC(0)=$10:GLCD_FC(1)=$24:GLCD_FC(2)=$20:GLCD_FC(3)=$24:GLCD_FC(4)=$10 ' // Smily face (shown as { in Lookdown table) case 124 ' GLCD_FC(0)=$00:GLCD_FC(1)=$00:GLCD_FC(2)=$7F:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // | GLCD_FC(0)=$20:GLCD_FC(1)=$40:GLCD_FC(2)=$20:GLCD_FC(3)=$10:GLCD_FC(4)=$08 ' // Tick (shown as | in Lookdown table) case 125 ' GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$36:GLCD_FC(3)=$08:GLCD_FC(4)=$00' // } GLCD_FC(0)=$20:GLCD_FC(1)=$14:GLCD_FC(2)=$10:GLCD_FC(3)=$14:GLCD_FC(4)=$20 ' // Frown face (shown as } in Lookdown table) case 126 GLCD_FC(0)=$10:GLCD_FC(1)=$08:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$08' // ~ ' case 127 ' GLCD_FC(0)=$10:GLCD_FC(1)=$08:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$08' // DEL ' Case 128 ' GLCD_FC(0)=$55:GLCD_FC(1)=$2A:GLCD_FC(2)=$55:GLCD_FC(3)=$2A:GLCD_FC(4)=$55 ' // 55 (shaded) end SELECT for GLCD_n0 = 0 to 4 If glcd_x=64 then lcd_data=0 cs1=1 cs2=0 posx=0 gosub lcd_setx gosub lcd_sety endif glcd_x=glcd_x + 1 lcd_data=GLCD_FC(GLCD_n0) GOSUB Lcd_Pod next GLCD_n0 return '_______________________________________________________________________________ Lcd_Init: posx=0 posy=0 rw=0 cs1=0 cs2=0 e=1 LCD_DATA=0 rst=0 pause 1 rst=1 cs1=1 cs2=1 gosub Lcd_On LCD_DATA=192 gosub Lcd_Kom gosub Lcd_clr return Lcd_Pod: rs=1 e=0 pauseus 1 e=1 pauseus 1 return Lcd_Kom: rs=0 e=0 pauseus 1 e=1 pauseus 1 return Lcd_SetX: LCD_DATA=64+posx gosub Lcd_Kom return Lcd_SetY: LCD_DATA=184+posy gosub Lcd_Kom return Lcd_Clr: for GLCD_n0=0 to 7 posy=GLCD_n0 gosub Lcd_SetY posx=0 gosub Lcd_SetX LCD_DATA=0 for GLCD_n1=0 to 63 gosub Lcd_pod next GLCD_n1 next GLCD_n0 return Lcd_Off: LCD_DATA=62 gosub Lcd_kom return Lcd_On: LCD_DATA=63 gosub Lcd_Kom return OverLCD:Text works correctly, but the variable can not make it to work.Code:include "glcd.pbp" z var byte z=12 pause 2000 pocetak: @ PrintStr 1,0,"Some text and move to second line if first line isn't enought bla bla" PAUSE 2000 @ PrintStr 7,4,"test" '@ PrintVar 3,6, _z ' I allways get random number pause 1000 end
Code is not mine, I downloaded it from the forum and make some changes.
that's very interesting, thank you a lot.
But why they dont make one for all of us?
Look at what I found going through my archives:
Code:'************************************************************************ 'GLIPICW.BAS Graphic application for use with a KS0108 (or compatible) 'graphic LCD controller connected to a Microchip(TM) PIC 16F877 'Written in MELabs PicBasicPro(TM) Ver 3.32 'Beta version 0.8.0 '================== NOT FOR COMMERICIAL USE ============================= ' ' Author: Ranjit Diol - COMPSys LLC, March 2000 ' (c) Copyright Ranjit Diol, 2001 ' ' DISCLAIMER: This file is being released as non-commericial ' freeware. It is being provided "AS IS", neither the author, ' nor COMPSys LLC shall be held liable for any damages caused ' by its use. ' ' LICENSE: This application may be used in its entirety or ' in parts within some other non-commercial application as long ' as the author is given credit for those parts used. ' ' Contact: [email protected] for more information ' '************************************************************************ ' IMPORTANT, PLEASE NOTE THE FOLLOWING 'This application assumes you have a 64KBit external eeprom connected 'via I2C. Without that you will only be able to send images directly 'to the LCD display and not be able to store them -- See the readme.txt 'for the Windows GLiPIC interface. ' 'Adjust the PIN assignments as neccessary for your prototype 'This was tested using a 20MHz xtal if you use a different OSC speed 'you may have to make some adjustement in the 'strobe' subroutine. '************************************************************************ DEFINE ONINT_USED 1 'Required if using ISP DEFINE OSC 20 'OSC speed, you may have to tweak the 'strobe' 'routine's e_pause constant for other speeds ADCON1 = 7 'Make all pins digital, you may adjust as needed SPBRG=0 '************ NOTE *********** RCSTA=0 'This is required if you are using TXSTA=2 'Shane Tolmie's bootloader (PICLoader) '***************************** dat VAR PORTD 'LCD bus Pins 7-14 LSB-MSB scl VAR PORTC.3 'I2C SCL for ext eeprom sda VAR PORTC.4 'I2C SDA for ext eeprom in_pin VAR PORTC.7 'Serial input pin out_pin VAR PORTC.6 'Serial output pin e VAR PORTC.0 'Enable pin on LCD cd VAR PORTC.1 'Data/Command Pin 4 on LCD rw VAR PORTC.2 'Read/Write Pin 5 on LCD cs1 VAR PORTB.1 'ChipSelect1 Pin 15 on LCD cs2 VAR PORTB.2 'ChipSelect2 Pin 16 on LCD rst VAR PORTC.5 'Reset Pin 17 on LCD 'Set pins for output TRISB.0 = 0 TRISB.1 = 0 TRISB.2 = 0 TRISD = 0 TRISC.0 = 0 TRISC.1 = 0 TRISC.2 = 0 TRISC.3 = 0 TRISC.4 = 0 TRISC.5 = 0 'Constants used ser_baud CON 32 '19200 baud serout/serin ctl CON $A0 'EEprom control code row CON $b8 'LCD page 0 last_row CON $bf 'LCD page 7 col CON $40 'Line byte position 0 last_col CON 63 'Last column (1-64) first_col CON 0 'First column max_col CON 128 'Last column (1-127) max_line CON 8 'Line 8 (based on 1-8) max_pos CON 64 'Column 64 positon per side (1-64) cr CON 13 'CR for serout lf CON 10 'LF for serout disp_on CON $3f 'LCD Display ON disp_off CON $3e 'LCD Display OFF disp_ram CON $c0 'Ram Display 0 (Page 0 at top of display) blank CON $00 'Blank character e_pause CON 10 'Pauseus 6 for Strobe routine 'Word variables used eepaddr VAR WORD addr VAR WORD 'Arrays used in_array VAR byte[32] in_ctl VAR byte[8] 'Byte Variables used buff_count VAR BYTE 'buffer count hex_nibble VAR BYTE 'hex nibble from serin in_ascii VAR BYTE 'ASCII char from serin buf_cnt VAR BYTE 'buffer counter byte_pos VAR BYTE 'To keep track of a byte's position in_byte VAR BYTE 'The incoming byte tmp VAR BYTE 'Temporary var index VAR BYTE 'Index for arrays j VAR BYTE 'General counter k VAR BYTE 'General counter line VAR BYTE 'An LCD row delay VAR BYTE 'Execution delay, used with 'pause' 'Initialize variables hex_nibble = 0 byte_pos = 0 delay = 10 in_byte = 0 tmp = 0 index = 0 'Reset LCD dat = 0 ' Clear PORTD cd = 0 rw = 0 e = 0 cs1 = 1 cs2 = 0 rst = 1 pause 100 'Let things stabilize rst = 0 pause 10 ' Reset LCD rst = 1 pause 500 'Jump over subroutines to main program goto main ' **** (GO)SUB ROUTINES **** strobe: e = 1 pauseus e_pause e = 0 return clearall: cd = 0 ' Command mode dat = disp_off ' Display Off gosub strobe cs1=1 cs2=0 for index = 1 to 2 for j = row to last_row cd = 0 'Command mode gosub strobe ' Write the data dat = col ' Column address = 0 gosub strobe dat = j gosub strobe cd = 1 ' Write mode for k = first_col to last_col dat = blank gosub strobe next next swap cs1,cs2 next cs1=0 cs2=1 cd=0 dat=row gosub strobe dat = disp_ram ' Ram Line 0 gosub strobe dat=col gosub strobe dat = disp_on 'display on gosub strobe cs1=1 cs2=0 dat=row gosub strobe dat = disp_ram ' Ram Line 0 gosub strobe dat=col gosub strobe dat = disp_on 'display on gosub strobe cd = 1 ' Set Data command cs1 = 1 ' Left side active cs2 = 0 return init: 'Initialization cd = 0 ' Set command mode cs1 = 1 ' Left Side on cs2 = 0 ' Right Side off for index = 1 to 2 dat = disp_off ' Display Off dat = disp_ram ' Ram Line 0 gosub strobe ' Write the data dat = col ' Y address = 0 gosub strobe dat = row ' Page = 0 gosub strobe dat = disp_on ' Display On gosub strobe swap cs1,cs2 next cs1=1 cs2=0 return '****Place char on LCD Routine ***** 'Place byte of data on lcd assumes in_byte, byte_pos and line (line) 'Char position on LCD byte_pos = 0-127 (Horiz), ROW 0-7 (vert) putbyte: dat = in_byte 'Display the byte gosub strobe byte_pos=byte_pos+1 'Increment position 'Now do some LCD house cleaning and adjust counters if byte_pos=max_pos then cs1=0 cs2=1 cd = 0 dat = col gosub strobe dat = disp_ram gosub strobe dat = row + line gosub strobe cd = 1 endif if byte_pos = max_col then 'Check if line = line + 1 'New Line if line = max_line then line = 0 endif byte_pos = 0 'Reset byte_pos cs1=1 cs2=0 cd = 0 dat=col gosub strobe dat = row + line gosub strobe dat = disp_ram gosub strobe cd =1 endif return '***** Convert incoming ascii to hex byte Routine ***** find: Lookdown in_array[index],["0123456789abcdef"],hex_nibble return '=============================== ' **** BEGIN MAIN PROGRAM ****** '=============================== main: gosub init ' Initialize LCD gosub clearall ' Clear all pages serout2 out_pin,ser_baud,["Load image..."] goto term logo: gosub init ' Initialize LCD gosub clearall ' Clear all pages '**** DISPLAY IMAGES IN EXTERNAL 64KBit EEPROM VIA I2C ***** ' Load opening screen from eeprom assuming a 64KBit eeprom byte_pos=0 line =0 for addr = 0 to 8192 I2CREAD sda,scl,ctl,addr,[in_byte] gosub putbyte if (addr=1024) OR (addr=2048) OR (addr= 3072) OR (addr=4096) OR (addr=5120) OR (addr=6144) OR (addr=7168) OR (addr=8192) then pause 4000 gosub init gosub clearall endif next pause 4000 gosub init gosub clearall 'goto logo 'Continue looping inifitum! '******************************************** 'Terminal Subroutine term: 'Assumes Home Position 'Setup variables j=0 index=0 k=0 'line=0 addr=0 in_ascii = 0 buff_count = 32 delay = 10 'addr = 0 'byte_pos = 0 'Get the initial parameters get_param: addr = 0 byte_pos = 0 line=0 serin2 in_pin,ser_baud,[wait ("*"),STR in_ctl\9] for index = 0 to 8 Lookdown in_ctl[index],["0123456789abcdef"],hex_nibble in_ctl[index]=hex_nibble next delay = (in_ctl[7]<<4) | in_ctl[8] buff_count = (in_ctl[1]<<4) | in_ctl[2] addr.byte1 = (in_ctl[3] <<4) | in_ctl[4] addr.byte0 = (in_ctl[5] <<4) | in_ctl[6] buf_cnt = (buff_count - 1) eepaddr = addr j=in_ctl[0] if j = 3 then lcd_loop 'Display directly on LCD if j = 1 then eep_loop 'Load ext eeprom if j = 2 then logo 'Display images loop goto get_param eep_loop: serin2 in_pin,ser_baud,5000,get_param,[wait ("]"),STR in_array\buff_count] 'Wait for ] and the load in_array for index = 0 to (buff_count - 1) gosub find 'Get char and place in array in_array[index]=hex_nibble next for index = 0 to (buff_count - 1) step 2 in_byte = (in_array[index]<<4) | (in_array[index+1]) 'Form a hex number MSB-LSB I2CWRITE sda,scl,ctl,addr,[in_byte] pause 5 addr=addr+1 next goto eep_loop lcd_loop: serin2 in_pin,ser_baud,5000,get_param,[wait ("]"),STR in_array\buff_count] 'Wait for ] and the load in_array for index = 0 to (buff_count - 1) gosub find 'Get char and place in array in_array[index]=hex_nibble next for index = 0 to (buff_count - 1) step 2 in_byte = (in_array[index]<<4) | (in_array[index+1]) 'Form a hex number MSB-LSB gosub putbyte next goto lcd_loop '*********** E N D ************ end ' **** END OF MAIN PROGRAM ****
It had the following text file for pinout:
All the credit goes to the good people at Compsys.GLIPIC BOARD Ver C and and Higher
The GL board 20 pin header has the following pinouts:
PIN ----- PIC PIN ------------ KS0108 pin
01---------- GND --------------- GND
02-----------Vdd 5v--------------Vdd
03---- wiper of 20k pot-----------Vo
04-----------PORTC.1--------------D/I
05---------- PORTC.2--------------R/W
06-----------PORTC.0-------------- E
07-----------PORTD.0--------------DB0
08-----------PORTD.1--------------DB1
09-----------PORTD.2--------------DB2
10-----------PORTD.3--------------DB3
11-----------PORTD.4--------------DB4
12-----------PORTD.5--------------DB5
13-----------PORTD.6--------------DB6
14-----------PORTD.7--------------DB7
15-----------PORTB.1--------------CS1
16-----------PORTB.1--------------CS2
17-----------PORTC.5-------------RESET
18-------one end of 20k pot----- Vee(connects to Vo via the 20k pot)
19-----------PORTE.1---Do not connect to KS0108 LCD*
20-----------PORTE.2---Do not connect to KS0108 LCD*
*If the LCD has a backlight LCD PINS 19 and 20 are used to power the backlight. Usually, for an LED backlight PIN19 is the A (anode) and PIN 20 is K (cathode). However, on some displays the order is reversed. Check LCD documentation before connecting power to them!
If you have a 128x64 KS0108 LCD with the above pinouts, then you can test out the GL board by running the Windows app GLUTIL2.EXE.
http://www.compsys1.com/workbench/On...ontroller.html
I had saved these files back in 2005 when I was starting on LCDs.
I first I tried so I just used a lookup instead of eeprom ....
Here's the code
Code:trisb=0 trisd=0 portb=0 portd=0 symbol RW=portb.3 symbol RS = portb.2 symbol E = portb.4 symbol CS1 = portb.0 symbol CS2 = portb.1 symbol RST = portb.5 Symbol LCDDATA=portd i var byte X var byte Y var byte pocetak: call init LCDDATA=0 call clr cs1=0 x=1 call setx y=0 call sety for i=0 to 63 Lookup i, [$00,$00,$FE,$FE,$FE,$FE,$1E,$1E,$1E,$1E,$1E,$1E,$1E,$1E,$FE,$FE,$FC,$F8,$00,$FE,$FE,$FE,$FE,$0E,$0E,$0E,$0E,$0E,$0E,$0C,$00,$00,$00,$FE,$FE,$FE,$FE,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$FE,$FC,$F8,$F0,$00,0,$FE,$FE,$FE,$FE,$0E,$0E,$0E,$0E,$0E,$0E,$FE,$FE,$FC,$F8], LCDDATA call pod next i x=2 y=0 call sety call setx for i=0 to 63 Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$F0,$F0,$F0,$F0,$F0,$F0,$F0,$F0,$FF,$FF,$7F,$3F,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$00,$00,$E0,$FF,$FF,$FF,$FF,$E0,$E0,$C0,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$00,0,$FF,$FF,$FF,$FF,$80,$80,$80,$80,$80,$80,$FF,$FF,$FF,$FF], LCDDATA call pod next i x=3 y=0 call sety call setx for i=0 to 63 Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$01,$01,$01,$01,$01,$01,$01,$00,$00,$01,$FF,$FF,$FF,$FF,$01,$01,$01,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$00,0,$FF,$FF,$FF,$FF,$07,$07,$07,$07,$07,$07,$FF,$FF,$FF,$FF], LCDDATA call pod next i x=4 y=0 call sety call setx for i=0 to 63 Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$00,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$FF,$FF,$FF,$FF,$00,0,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF], LCDDATA call pod next i LCDDATA=0 cs1=1 cs2=0 x=1 call setx for i=0 to 63 Lookup i, [$00,$00,$FE,$FE,$FE,$FE,$1E,$1E,$1E,$1E,$1E,$1E,$1E,$1E,$FE,$FE,$FC,$F8,$00,$FE,$FE,$FE,$FE,$1E,$1E,$1E,$1E,$1E,$1E,$FE,$FE,$FC,$F8,$00,$FE,$FE,$FE,$FE,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$FE,$FE,$FC,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00], LCDDATA call pod next i x=2 call setx for i=0 to 63 Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$00,$FF,$FF,$FF,$FF,$80,$80,$80,$80,$80,$80,$FF,$FF,$FF,$FF,$00,$FF,$FF,$FF,$FF,$80,$80,$80,$80,$80,$80,$80,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00], LCDDATA call pod next i x=3 call setx for i=0 to 63 Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$00,$FF,$FF,$FF,$FF,$07,$07,$07,$07,$07,$07,$FF,$FF,$FF,$FF,$00,$07,$07,$07,$07,$07,$07,$07,$07,$07,$07,$07,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00], LCDDATA call pod next i x=4 call setx for i=0 to 63 Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$FF,$FF,$FF,$FF,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$FF,$FF,$FF,$FF,$00,$00,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00], LCDDATA call pod next i PAUSE 5000 cs1=1 cs2=1 CALL CLr x=0 y=0 call setx call sety LCDDATA=0 CS2=1 cs1=0 y=10 x=1 call setx call sety for i=0 to 63 Lookup i, [$00,$7E,$12,$1E,$00,$00,$7E,$4A,$4A,$4A,$00,$7E,$42,$42,$3C,$00,$60,$40,$7E,$00,$60,$1C,$12,$1C,$60,$00,$7E,$42,$7E,$00,$7E,$4A,$7E,$00,$5E,$52,$7E,$00], LCDDATA call pod next i y=26 x=3 call setx call sety for i=0 to 37 Lookup i, [$00,$3E,$40,$3C,$02,$3C,$40,$3E,$00,$00,$3E,$40,$3C,$02,$3C,$40,$3E,$00,$00,$3E,$40,$3C,$02,$3C,$40,$3E,0,64,0,$7E,$4A,$4A,$4A,$00,$7E,$40,$40,$00], LCDDATA call pod next i cs2=0 cs1=1 x=3 call setx for i=0 to 63 Lookup i, [$7E,$4A,$4A,$4A,$00,$7E,$10,$18,$24,$42,$02,$7E,$02,$02,$00,$7E,$0A,$1A,$6E,$00,$3C,$42,$42,$42,$3C,$00,$7E,$0C,$30,$7E,$00,$00,$7E,$00,$7E,$10,$18,$24,$42,$00,$60,$1C,$12,$1C,$60,$00,$40,$00,$7E,$48,$78,$00,$60,$1C,$12,$1C,$60,0], LCDDATA call pod next i cs2=1 cs1=1 pause 2000 for i=63 to 32 step -1 LCDDATA=192+i call kom pause 400 next i goto pocetak end Init: x=0 y=0 rw=0 cs1=0 cs2=0 e=1 LCDDATA=0 rst=0 pause 1 rst=1 cs1=1 cs2=1 call Dispon LCDDATA=192 call kom return Pod: rs=1 e=0 pauseus 1 e=1 return Kom: rs=0 e=0 pauseus 1 e=1 return SetX: LCDDATA=184+x call Kom return SetY: LCDDATA=64+y call Kom return Clr: for x=0 to 7 call setx y=0 call sety LCDDATA=0 for i=0 to 63 call pod next i next x return DispOff: LCDDATA=62 call kom return DispOn: LCDDATA=63 call kom return
But then the problem was that every time I want to print something, I have to draw a picture of the entire display, or create the font, and for each letter copy 5 bytes. Then I found a forum for the LCD of Nokia 3310, and tried to correct for KS0108.
I hope to be able to finish it, but now I am busy doing other things, so...
Hi guys,
I have been talking to our friend pedja089 about the lib in the first lib.
I did some good improvements, and now, I can print strings and Variables correctly.
I have already started writing some basic graphic routines, and I would like to publish it here as a contribution if our friend pedja089 agree with it, and I think he will.
To test it I did a small simple digital clock, just to check if printing is working.
The code compiles ok when I use a 18F4550 as a target controller. The hex's size is about 4500 bytes.
But, when I change to the 16F877, (which has 8kb available) it always show me the following erros :
Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (6573)
Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (7420)
Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (436C)
Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (6F63)
Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (6800)
Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (7820)
The line 207 in the Asm code is :
data Str, 0
from the macro :
goto OverStr
TheString
data Str, 0
OverStr
MOVE?CB x, _GLCD_X
MOVE?CB x, _GLCD_SX
MOVE?CB y, _PosY
I admit that I am absolutely noob on writing/uderstanding assembler.
Does some one have any ideao of what is wrong with this Macro.
Is this restricted to 18F series ?
Thank you !
regards,
Sérgio
Yup 18F don't work the same way for embedded strings. You may want to have a look at least at the following.
http://www.pbpgroup.com/modules/wfse...p?articleid=10
Notice the use of da vs Data and how to retrieve them.
You could also have a look at my NOKIA driver/wrapper.
http://www.picbasic.co.uk/forum/show...?t=327&page=54
Thank you Mister_e !
I will spend some time this weekend trying to make the Lib better.
I would like to make it work with 16F series (877 and above) and 18F and make it public.
There are a lot of nice and cheap KS0108 for sale on eBay. I bought some from the seller Wide Hk and they are small and nice. Perfect for embeded solutions.
Well, let´s study the posts and try to fix it !
regards,
Sérgio
I know there are heaps of different GLCD controller types around, but surely the gurus at MELabs could toss a coin and pick one that they consider to be the most popular (KS0108?) and do some GLCDOUT type stuff for that controller? After all, they did exactly that when they selected the Hitachi 447?? (whatever) controller they wrote the LCDOUT stuff for? That has proven quite usable?
My 2 cents worth, but I won't hold my breath.
Peter Moritz.
Up the bush, Western Plains,
New South Wales,
Australia.
Or a couple of different libraries to cover a few flavors of GLCDs. Like other compilers do.
Sure, if they did it I wouldn't protest against it.
But, as you say, there are plenty of graphic LCD controllers but basically only ONE standard for characters based displays and that IS the HD44780 (or compatibles). It's also a lot easier to drive than the graphical controllers, trust me I've tried with the RA6963C and the SSD1307. One issue is that the HD44780 basically just works and doesn't care about the number of characters per line etc, it doesn't care about the size (appart from number of lines) of the panel it's actually driving. But the graphical controllers are usually quite flexible when it comes to resolution of the panel and needs to be configured properly (not to mention timings, multiplex ratios etc etc.
My experience with MeLabs is that what they do they do properly and to do a general purpose GLCD driver to their standars is a LOT of work.
I wonder what they ARE working on at MELABS HQ nowadays, there's been no updates to compiler for 18 months. Darrels recent and unfortunate passing must have put a real dent in available resources
