PWM (ECCP) - piezo-sounder directly connected to half-bridge on PIC
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default PWM (ECCP) - piezo-sounder directly connected to half-bridge on PIC
    Hi there,
    I'm finishing my cooking-timer project and first time tried the PWM (ECCP) half-bridge functionality (when pin P1A is HIGH, P1B is LOW, next cycle inverts and so forth) on my PIC 16f690.
    The piezo-sounder I have works best (= is the loudest) @ 4kHz.
    The idea (not new at all) is to augment my piezo-sounder's loudness by inverting its power polarity @ 4kHz (kind of 10V peak-to-peak). As a matter of fact, it works very well
    Since my piezo-sounder draws not more than 1,5mA, I have connected it directly to the respective PIC's pins P1A & P1B.
    Is this way of doing okay or am I going to have a surprise in a certain period of time?
    Roger
    Default Re: PWM (ECCP) - piezo-sounder directly connected to half-bridge on PIC
    Hello Roger,
    I have done this many times ( because it works very well on getting a higher sound with 2 pins inverted ) and never had any problems.
    The only difference is that I use a small resistor ( 100 ohms ) between the pin and the piezo ( one for each pin ).
    The frequency depends on the piezo so it's best to test to see which is the optimal frequency ( as you did ).
    Rui
    Dec 2008
    Ploiesti, ROMANIA
    augment ... piezo-sounder's loudness by inverting its power polarity @ 4kHz (kind of 10V peak-to-peak).
    Please, can you post the code for this particular thing ? Thanks !
    That's the code, well... it's just THE part of the cooking-timer code to make that "half-bridge" PWM work:
    ' PIC 16F690 Fuses (MPASM)
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_HS_OSC &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    ' Registers   76543210
    OPTION_REG = %10000110 ' Pull-Ups OFF, Prescaler TMR0 1:128
    ANSEL      = %00000000 ' Select analog inputs Channels 0 to 7
    ANSELH     = %00000001 ' Select analog inputs Channels 8 to 11
    WPUA       = %00000000 ' Select weak pull-ups
    WPUB       = %00000000 ' Select weak pull-ups
    ADCON0     = %10000000 ' AD Module
    ADCON1     = %00000000 ' AD control register
    CM1CON0    = %00000000 ' Comparator1 Module
    CM2CON0    = %00000000 ' Comparator2 Module
    INTCON     = %10100000 ' INTerrupts CONtrol; GIE=1, T0IE=1
    TRISA      = %00000000 ' Select Input/Output (0 to 5)
    PORTA      = %00000000 ' Set High/Low (0 to 5)
    TRISB      = %00110000 ' Select Input/Output (4 to 7)
    PORTB      = %00000000 ' Set High/Low (4 to 7)
    TRISC      = %01000000 ' Select Input/Output (0 to 7)
    PORTC      = %00000000 ' Set High/Low (0 to 7)
    ' HPWM registers
    T2CON      = %00000101 ' Timer2 = ON (bit2), prescaler (bits1:0) 00=1, 01=4, 1x=16
    CCP1CON    = %10001100 ' Select PWM Mode (%00001100 = PWM module ON)
    CCPR1L     = 62        ' Dutycycle set to 50% (= percentage of PR2)
    PR2        = 124       ' Freq 4kHz
    Roger
    Just as a precaution I would recommend to have the outputs at the same logic level when you do not want the sounder work. Thats because piezo do not like DC voltage.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks Mr.Flotulopex and Mr.Ioannis !
    It's verry usefull.
    ...I would recommend to have the outputs at the same logic level...
    When the souder is not used, I set CCP1CON register to 0.
    Is this okay?
    Roger
    ....hum, sorry for my silly question
    Just measured the ports and they need to be reset.
    Thanks for noticing Ioannis
    Roger
    As you observed Roger, you must be in luck to have both ports at the same level. They will be in a random state.
  1. Replies: 4
    Last Post: - 7th June 2011, 05:02
  2. PWM with PIC16F88 controlling h-bridge
    By deimantas in forum mel PIC BASIC Pro
    Last Post: - 20th May 2010, 22:03
  3. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  4. 18F4620 HPWM Half Bridge Mod problem
    By showtime in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2007, 12:55
  5. Using HPWM in half bridge mode on 16f690
    By Chris Barron in forum mel PIC BASIC
    Last Post: - 29th December 2006, 11:18
