rak VAR WORD
ss VAR BYTE 'current line of selection in the menu
qq VAR BYTE 'number of the first line displayed in the LCD
ssmax VAR BYTE 'maximum number of variables
ss1 VAR BYTE 'where to write first variable in the LCD
ss2 VAR BYTE 'where to write second variable in the LCD
ss3 VAR BYTE
ss4 VAR BYTE
ss5 VAR BYTE
ss6 VAR BYTE
advanced:
ssmax=6
ss=1
gosub show_text
advanced_1:
if but=15 then 'up
ss=ss-1
if ss<1 then ss=6
gosub advanced_2
gosub show_text
gosub menu_arrow
if but=16 then 'down
ss=ss+1
if ss>6 then ss=1
gosub ayarlar_advanced_2
gosub show_text
gosub menu_arrow
IF but=17 Then 'enter
' for saving variables modified here
EndIF
gosub type_in
if rak>999 then
for k=0 to 9:p(k)=0:next k:k=0:rak=0
goto advanced_1
advanced_2:
if ss=1 then rak=v1
if ss=2 then rak=v2
if ss=3 then rak=v3
if ss=4 then rak=v4
if ss=5 then rak=v5
if ss=6 then rak=v6
show_text:
lcdout$fe,1
qq=ss-2
if (ss-2<=0) then qq=1
if (ss=ssmax) then qq=ss-3
Select Case qq
Case 1:ss1=128:ss2=192:ss3=148:ss4=212:gosub y1:gosub y2:gosub y3:gosub y4
Case 2:ss2=128:ss3=192:ss4=148:ss5=212:gosub y2:gosub y3:gosub y4:gosub y5
Case 3:ss3=128:ss4=192:ss5=148:ss6=212:gosub y3:gosub y4:gosub y5:gosub y6
End Select
y1:
lcdout$fe,ss1,"VARIABLE1=",#v1
y2:
lcdout$fe,ss2,"VARIABLE2=",#v2
y3:
lcdout$fe,ss3,"VARIABLE3=",#v3
y4:
lcdout$fe,ss4,"VARIABLE4=",#v4
y5:
lcdout$fe,ss5,"VARIABLE5=",#v5
y6:
lcdout$fe,ss6,"VARIABLE6=",#v6
menu_arrow:
gosub menu_arrow_delete
lcdout$fe,159,">"
if (ss=1) then
lcdout$fe,139,">"
if (ss=2) then
lcdout$fe,203,">"
if (ss=ssmax) then
lcdout$fe,223,">"
' if ss=1 then lcdout$fe,$8b,">" 'I still need to work on this for modifying selected variable
' if ss=2 then lcdout$fe,$cb,">"
' if ss=3 then lcdout$fe,$9f,">"
' if ss=4 then lcdout$fe,$df,">"
menu_arrow_delete:
lcdout$fe,$8b,":":lcdout$fe,$cb,":":lcdout$fe,$9f,":":lcdout$fe,$df,":"
type_in:
p(k)=but
if but=10 then p(k)=0
k=k+1
if k>3 then
p(0)=but:LCDOut$fe,155," ":k=1
rak=0
if ss=1 then lcdout$fe,$8c,#rak," "
if ss=2 then lcdout$fe,$cc,#rak," "
if ss=3 then lcdout$fe,$a0,#rak," "
if ss=4 then lcdout$fe,$e0,#rak," "
Select Case k
Case 1:rak=p(0)
Case 2:rak=p(0)*10+p(1)
Case 3:rak=p(0)*100+p(1)*10+p(2)
End Select
So the main idea is to shift the menu downwards when last line is reached, or likewise to the upward direction.
