Strange Variable Issue ...
Results 1 to 6 of 6
    Dec 2012
    Türkiye
    Default Strange Variable Issue ...
    Hello everyone ..
    I'm having a very very interesting problem with my code ... I'm trying to understand the basics of a Enhanced Asynchronous communication but in the code there is a line that drives me crazy ...
    '*  Name    : EUSARTRX.BAS                                      *
    '*  Author  : [BURAK GÜNAY]                                     *
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 7/22/2015                                         *
    #header
      errorlevel -303  ; suppress Program word too large
    #ENDHEADER
    #config
     __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
     __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_19 & _LVP_OFF
    'define OSC 4
    DEFINE OSC 16
    'define OSC 32
    '------------- LCD DEFINES ------------------------
    DEFINE LCD_DREG PORTB 'LCD data port
    DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTA 'LCD register select port
    DEFINE LCD_RSBIT 7 'LCD register select bit
    DEFINE LCD_RWREG PORTA   ' LCD read/write port
    DEFINE LCD_RWBIT 5   ' LCD read/write pin bit
    DEFINE LCD_EREG PORTA 'LCD enable port
    DEFINE LCD_EBIT 6 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    'OSCCON=%01101010    'OSC is @ 4 MHZ
    OSCCON=%11111000
    'OSCCON=%11110000     'OSC is @ 32 MHZ (PLLEN MUST BE ENABLED)
    PORTA=%00000000     :      PORTB=%00000000
    TRISA=%00000000     :      TRISB=%00000010
    ANSELA=%00000       :      ANSELB=%00000000
    'ADCON0=%00000001    :      ADCON1=%11100000
    OPTION_REG.7=0      :      WPUB=%11111111
    RCSTA = $90         ' Enable serial port & continuous receive
    TXSTA = $24         ' Enable transmit, BRGH = 1
    SPBRG = 160         ' 9600 Baud @ 16MHz, -0.08%
    SPBRGH = 1
    BAUDCON.3 = 1       ' Enable 16 bit baudrate generator
    T1CON=%00100000     ' 1:4 prescaler
    X       VAR WORD
    DAT     VAR WORD
    GP      VAR byte        ' GP variable
    BytesIn VAR byte[2]     ' Up to 2 bytes
    ByteCnt VAR byte        ' Indicates number of bytes in buffer
    'EOM     CON "~"         ' EOM = "End Of Message" marker
    OERR    VAR RCSTA.1     ' Alias USART over-run bit
    CREN    VAR RCSTA.4     ' Alias USART continuous receive enable bit
    RCIF    VAR PIR1.5      ' Alias USART received character interrupt flag bit
    ByteCnt = 0             ' Zero counter
    TMR1ON  VAR T1CON.0  :   TMR1ON=0   :   TMR1=0
    LED     VAR PORTA.1
    LCDOUT $FE,1
    PAUSE 500
    LCDOUT $FE,$80,"     READY     "
    PAUSE 1000
    LCDOUT $FE,1
    MAIN:
    IF OERR=1 THEN
        CREN = 0                         ' Over-run so disable receive
        CREN = 1                         ' Re-enable & clear OERR "over-run" flag
    IF RCIF=1 THEN                       ' If RCIF=1 there's a new character in RCREG
        TMR1ON=1
        BytesIn[ByteCnt]=RCREG           ' Yes. Store new char in array
    '    IF BytesIn[ByteCnt]=EOM THEN Out ' End of message?
        ByteCnt=ByteCnt+1                ' No. Increment array index pointer
        TMR1ON=0
        IF ByteCnt >=2 THEN Out          ' Test for software buffer over-run
    IF OERR=1 THEN
    GOTO MAIN
    Out:
    TMR1ON=1'---
    DAT.LOWBYTE=BYTESIN[0]
    DAT.HIGHBYTE=BYTESIN[1]
    x=dat
    FOR GP=0 to ByteCnt                 ' Clear array bytes 0 to ByteCnt
        BytesIn[GP]=0
    NEXT
    ByteCnt=0                           ' Reset index pointer back to first element
    WHILE RCIF=1                        ' Trash anything received after the EOM marker
        GP=RCREG                        ' by reading RCREG until RCIF is cleared.
    WEND
    tmr1on=0'---
    LCDOUT $FE,$80,"Num  : ",DEC5 x
    LCDOUT $FE,$C0,"Delay: ",DEC5 TMR1," uS"
    TMR1=0
    GOTO MAIN
    If I try to view the variable "DAT" directly it always shows zero ... But If I first add a line "x=dat" just as in the code and try to display the "x" it displays the number ?
    A way more strange thing is ;
    if I change the codelines and try to view both x and dat only x is displayed dat remains zero .. (THE CODE CHANGE IS BELOW)
    LCDOUT $FE,$C0,"Num  : ",DEC5 DAT
    How can it happen ? There is something I skip or ignore to see ?
    Thanks in advance ..
    Dec 2012
    Türkiye
    Default Re: Strange Variable Issue ...
    I think the problem is using array variables ... By creating proper byte variables everything works as I expect ...
    - Ipsa scientia potestas est -
    if ByteCnt=2 how many times will it run through this for/next loop ?
    BytesIn[GP]=0
    NEXT
    when you set BytesIn[2] to 0 what var do you think will get clobbered
    its not a Strange Variable Issue ... its a write to an out of bounds array index
    Dec 2012
    Türkiye
    BytesIn[GP]=0
    NEXT
    Hmm I've changed the line as follows
    FOR GP=0 to ByteCnt-1 ' Clear array bytes 0 to ByteCnt
    BytesIn[GP]=0
    NEXT
    And it works as expected ... Thank you for your answer Richard ..
    Now can you explain what happens when it tries to clear a nonexisting variable ? It clobbers my DAT variable next as it should not , yet somehow it does .. ?
    I think there is something happening on the background that is out of my knowledge ..
    from the manual
    A single Array Variable can be visualized as a list of values. The variable name is
    how you access the list, and a number –or index– is used to point to any single
    value within the list.
    The index value is enclosed in brackets and appended after the array variable's
    name.
    myarray[index] = 0
    The index can be a literal number, a variable, or an expression.
    For the following examples, an array named "stored" is used:
    stored VAR WORD[8] 'Create an array named "stored"
    with 8 elements.
    Note that the 8 elements in our array are numbered 0 through 7. There is no
    element-8. This is very important, because PBP doesn't place a limit at the end of
    the array. If you write "stored[8]", PBP won't generate an error and you will be
    accessing memory outside of the array. (The end of the array is stored[7] and there
    is no stored[8].) This could have disastrous results and be very difficult to debug.
    The elements of "stored" can be written individually:
    stored[0] = 1260
    stored[1] = 2500
    Or, you might want to write values with a loop. You could read PORTB once per
    second and save 8 readings:
    FOR index = 0 TO 7 'Loop 8 times
    stored[index] = PORTB 'Save value of PORTB
    PAUSE 1000 'Wait a second
    NEXT index 'Loop again
    this is not just a pbp issue most 8 bit micro languages have the same limitation on array bounds checking ie . none at all
    Dec 2012
    Türkiye
    Thank you Richard , for the amazing explanations ... Good to know and keep such knowledges for the pic that is working on the background of my brain ..
  1. IF-THEN issue
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 12th February 2014, 23:09
  2. Assigning a string variable to another string variable
    By Christopher4187 in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2013, 18:55
  3. strange readings
    By cheezy1963 in forum General
    Last Post: - 29th November 2007, 01:46
  4. Code Issue - select case or 'if' issue - not sure why
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 7th October 2007, 09:52
  5. One variable made up of another variable
    Last Post: - 1st September 2007, 01:18
