A tft addin for pbp3
Page 1 of 2 12 LastLast
Results 1 to 40 of 142
    Default A tft addin for pbp3
    The first of my tft modules arrived today a 1.8 inch st7735 with spi interface
    so far I have a scalable chr32 to 90 font and a rectangle fill utility . no one responded to my previous offer to make joint effort to develop this idea but now that I have something working it might be different . so I will have one more go ,if no one is interested I will just develop it for myself .
    this is just a demo and not documented at all ( it would be a waste of time if there is no interest)
    Default Re: A tft addin for pbp3
    a photo of the output
    Sep 2009
    Very nice. And nice example for using USERCOMMAND
    Oct 2009
    Utah, USA
    That's very nice!
    yes, please do share... I'd live to try one of those little displays.
    thanks
    Dwight
    tft now with duck, drawimage now works
    and a python script to convert utf565 generated c file to pbp friendly format
    forgot the python script
    The dev board I'm using for this project has a w25q32 flash memory chip on board , unfortunately on the same spi port as the display. this little display does a really fine job on graphics but transferring image data from flash to display is turning out to be much more complicated than expected. the other spi port is loaded up with a rtc and an eeprom (both i2c) . I'm not sure how they will react to the spi signals if I move the display to that port.
    hoping to avoid smoke
    here is the flash usercommand file so far
    glad to see some interest
    some ideas needed :-
    currently to display a string
    fg=$F800  ; set colour
     TEXTSIZE=2
     ARRAYWRITE buffer,["HELLO WORLD",0]
     GLCDC 1,63     ; set x ,y position
     ch=0
     WHILE (ch< 32) AND (buffer[ch]>0  )  ; check for end of string
     GLCDC  buffer[ch]        ; disp ch
     ch=ch +1
     WEND
    I would rather have a usercommand
    GLCDS 1,63 ,buffer
    but I can't figure a way of getting the address of buffer from the usercommand macros
    GLCDS 1,63 ,"HELLO WORLD"
    but I can't figure a way of getting the string data from the usercommand macros
    I would like to put the display hardware dependent code into a separate include file (that way other displays could be incorporated)
    not all the useful input combinations have had their macros written for each user command
    more user commands are required
    drawHline,drawVline,drawline,drawcircle,drawrect,f illcircle
    the hardware connection interface is defined like this
      tft_dc_bit con 4
      tft_cs_bit con 1
      tft_rst_bit con 8
      tft_port var latd
    its a bit clunky I sure there are better ways
    bit banging the data could be investigated
    over to you
    I have a bit of conditional compiling going on to select mssp1 or mssp2 but is there a way to conditionally check if the pic18 chosen to compile for has 1,2 or no mssp modules .
    #IFNDEF TFT_SPI
        #DEFINE TFT_SPI 1
          ;DEFAULT
     #ENDIF
     #IF   TFT_SPI = 1
         SSP1_IF VAR pir1.3
     #ELSE
         SSP1_IF VAR PIR3.7
     #ENDIF
    TFT_CMD:
    spi_cbyte :
        tft_port =  tft_port & (~ tft_dc_bit )
    TFT_DATA:
    spi_byte :
    '@       movff    INTCON , _p_int
    '@       bcf     INTCON ,7
        tft_port =  tft_port& (~ tft_cs_bit )
        SSP1_IF = 0
        #IF   TFT_SPI = 1
        SSP1BUF = CMD
        #else
        SSP2BUF = CMD
        #endif
        WHILE   SSP1_IF =0 ' wait for SPI interupt flag
        wend
        tft_port = tft_port |   ( tft_dc_bit|  tft_cs_bit   )
    '@     movff  _p_int  , INTCON
    the problem is that if the pic has only one mssp then sspbuffer becomes sspbuf where as for two its ssp1buf or ssp2buf.
    and it would nice to have shiftout as an option.
    other than that it nearly a done deal
    Hi Richard,
    Apart from including a list of all PICs with two MSSP modules and checking against that list I don't know a way of telling at compile time. There's probably a way to have the assembler do it but then its too late.....
    However, looking at the P18F45K22.INC file, as an example, one can see that SSPBUF and SSP1BUF are both declared and pointing at the same adress so I think you should be safe using SSPBUF and SSP2BUF. Obviously one can't know if Microchip will continue to alias SSPBUF to SSP1BUF on devices with multiple MSSP modules...
    hi henrik
    in asm I can do this
     asm
      ifdef SSPIF
         #define  ssp_1  0
        ifdef SSP1IF
         #define  ssp_1  1
    endasm
    but a #define thats made here seems unreadable to the pbp compiler
    and I don't really want to do the whole routine in asm
    tried using
    SSPBUF = CMD
    when ssp1buf exists and it syntax errors it really wants SSP1BUF = CMD
    tried
    sspbuf var ssp1buf
    result
    syntax error var is already an alias
    Hi Richard,
    Which device are you targeting?
    Oct 2013
    Is it possible that I destroy my TFT-display because my power supply for PIC18f4520 is 5volt?Communication between PIC and ILI9341 is on 5 volt.
    done a bit more
    have added tft_sleep tft_wake tft_on tft_off subs, added DRAWRRECT usercmd (draw round cornered rectangle).
    change way buttons are defined . can have rectangular buttons , a button colour scheme and the button "title" text is now stored in pgm memory
    attached is a demo for a pic18f2520 using sleep/ wake on touch interrupt , backlight modulation using a pnp trany bc557 (full 10 bit)
    can supply cct if req
    Oct 2013
    Hello people
    if someone tried Richard's example with PIC18F2520 or PIC18f4520
    I tried his example with PIC18F4520 and unfortunately not working. I have just a white screen.
    If someone can send me a hex file or an example of code that works with the PIC18F4520 so that I know if my screen working properly or it is damaged.
    my connection from TFT to PIC
    tft_dc_bit con 8 ;ie bit 3 PORT B.3
    tft_cs_bit con 32 ;ie bit 5 PORTB.5
    tft_rst_bit con 16 ;ie bit 4 PORTB.4
    tft mosi PORTC.5
    tft sck PORTC.3
    when I change value of this variable the led intensity is change on port C.2 , so PIC is working
    cont=50 ;half brightness
    another pic
    Sep 2009
    Never done something like that, but as DT said there is no better manual than .mac and .lib files.
    So here is what I found.
    Compiler use this macro from pbppic18.mac file when LCDOUT STR is used
    ;* LCDOUTSTR?B : Macro - Lcdout string                          *
    ;* Input      : B[]                                             *
    ;* Output     : None                                            *
    ;* Notes      :                                                 *
    LCDOUTSTR?B macro Bin
            MOVE?CW LCDOUTJ, R8 'dont know what this line do
    	MOVE?CB	high (Bin), FSR2H 'load highbyte of adr, from pbppic18.lib Macro - Move BYTE Variable into WORD Variable
            MOVE?CA	low (Bin) 'load low byte of adr to w, from pbppic18.lib MOVE?CA    : Macro - Move constant into W
            L?CALL  SEROUT2STR
    SEROUT2STR is in file pbppic18.
    SEROUT2STR movwf FSR2L          ; Set up for index
    serout2strloop movf POSTINC2, W	; Get a character
    	bnz	serout2str1	; Not null char
    So you could use in your program something like this:
    TFTSTR?B macro Bin
    	MOVE?CB	high (Bin), FSR2H ;load highbyte
            MOVE?CB	low  (Bin), FSR2L ;load low byte
    local tftstrloop
    local tftStrDone
    tftstrloop movf POSTINC2, W	; Get a character, then increment pointer
            BZ  tftStrDone ;All strings must end with 0
           ;Not Null char
            L?CALL tftWoutput; CALL print char in W to TFT
            BRA tftstrloop ;Get next chr
    tftStrDone: ;Null char
    endm ;end of macro
    EDIT:
    You could also use PBP's routine like LCDOUTSTR do, but you must see what this flags do
    LCDOUTJ_USED = 1
    SEROUT2STR_USED = 1
    And how JUMPMAN is used.
    Hi Richard,
    Where is the subroutine tft_init ?
    I have ordered 2 from your seller should get then before Christmas . . .
    These look very promising .. .
    updated version , complete this time {end must have fallen off first time}
    that's what I was looking for thanks pedja089
    that's one down , works like a dream
    GLCDSTR?CCB  macro Xin ,Yin ,Bin
            movlw    Xin
            CHK?RP    _X
            MOVWF     _X
            movlw    Yin
            CHK?RP    _Y
            MOVWF     _Y
            bnz outstr1 ; Not null char
            bra exstr
    outstr1 MOVWF _g_chr
            L?CALL _gcga
            bra   strloop
    exstr
    woops - looping in macro for multiple calls is a no go
    needs to be like this
            movlw    Xin
            CHK?RP    _X
            MOVWF     _X
            movlw    Yin
            CHK?RP    _Y
            MOVWF     _Y
            L?CALL  bfill
    bfill
    Next_Char
            bnz	outchr	; Not null char
            bra exstr2
    outchr	MOVWF _g_chr
            L?CALL _gcga
            bra   Next_Char
    exstr2  return
    And if you want to avoid CHK?RP, declare variable to BANKA.
    the book says that to declare a variable in BANKA is not guaranteed its just a suggestion to the compile process. if this is just an addon to a much larger project I'm thinking CHK?RP is probably a good thing just in case
    but I'm open to suggestion
    Sep 2009
    If variable doesn't fit into BANKA, then MPASM show error.
    Used almost in all my project, and always worked fine. Also when coding in ASM, I use SYSTEM, so there is no annoying underscore in front of variable name.
    EDIT:
    From manual:
    BANKx Instructs PBP to locate the variable in a specific bank of RAM.
    If things as address of variable, and bank of variable not guarantied if you specify them, then that is idiotic
    I'm sure if you specify location and bank of variable, compiler will try to fit in that location, otherwise throw error or at last warning.
    EDIT:
    From manual:
    yet in 7.3
    You can suggest to PBP a particular bank to place the variable in:
    penny VAR WORD
    BANK0
    nickel VAR BYTE
    BANK1
    If specific bank requests are made, those are handled first. If there is not enough room in a requested bank, the first available space is used and a warning is issued.
    but you get a warning
    Sep 2009
    I newer see that syntax...
    I use pdf that came with PBP 3
    PICBASIC PRO™ Compiler
    REFERENCE MANUAL
    Revised March 6, 2013
    Bank should be stated after variable type.
    eg
    ticker VAR BYTE BANK0 SYSTEM 'Creates "ticker" as a BYTE in BANK0, with no Assembly prefix character
    wsave VAR BYTE $70 'Creates "wsave" at RAM address 0x70 (hex)
    Richard,
    I'd be happy to help if I can. You're WAY ahead of me with the usercommand and assembly type stuff so I just sit back and admire your work.
    Unfortunately the forum (or my computer(s)) no longer allows me to download any attachments. Even when logged all it serves me is a file called attachment.php. Had that happen before, then it worked with another computer but not any more.
    REFERENCE MANUAL
    eg
    the forum messes with the white space so the layout of my post was a bit off looking, but look at your reference manual pdf section 7.3 ram allocation page 265 ,thats what I'm referring to.
    circles and lines and constant string
    The 2.2 " ili9341 (ili9340c how do tell) arrived today , after resoldering all the dry joints on the module it works .
    I have separated things out like this main pbp pgm --- usercommand pbpmod file , an include bas file for either st7735 or ili9341 and a font bas file
    in the pbp file
    your hardware connections
    ;----GLOBAL----HW---------
        SSP_IF VAR PIR3.7      ; must match your spi port
       tft_dc_bit con  32     ;5      binary weighted pin values
        tft_cs_bit con 16   ;4
        tft_rst_bit con 128   ;7
        tft_port var lath ;          ; the output port for control signals
    includes
        INCLUDE "glcd_chr.pbpmod"        ;glcdc
        include "tft-ILI9431.bas"      one or the other  not both
    ;    include "tft-ST7735.bas"      one or the other  not both
        INCLUDE "DT_INTS-18.bas"
        INCLUDE "ReEnterPBP-18.bas"
        INCLUDE "Elapsed_INT-18.bas"
        INCLUDE "font7x8.bas"
    in the usercommand file glcd_chr
    WIDTH con 320;160 X
    HEIGHT con 240; 128 Y
    set to appropriate values
    and this bit needs to match your spi port too a definite conditional compile potential here
    TFT_CMD:
    spi_cbyte :
    TFT_DATA:
    spi_byte :
    @       bcf     INTCON ,7
        SSP_IF = 0
        SSP2BUF = CMD
        WHILE   SSP_IF =0 ' wait for SPI interupt flag
        wend
    and off you go
    I would have liked to have the hw connections and the height width in the relevant hw include file but that presented too many issues for me
    Jan 2011
    Sydney, Australia
    Hi Richard,
    I am keen to replicate the great work you are doing with these TFT displays.
    I have looked on eBay for an ILI9341 display and there appears to be a gazillion of them to choose from.
    Can you share information on the eBay seller you bought your display from?
    Cheers
    Barry
    VK2XBP
    hi barry ,these are what I used I'm sure the others would be ok too just make sure the I/f is spi
    http://www.ebay.com.au/itm/271683495...%3AMEBIDX%3AIT
    http://www.ebay.com.au/itm/191534577...%3AMEBIDX%3AIT
    Jan 2011
    Sydney, Australia
    Thanks Richard.
    I have now placed an order and hope to take delivery some time in July.
    Cheers
    Barry
    VK2XBP
    Dec 2007
    Finland
    Very nice work Richard!
    ILI9341 based TFT display with resistive touch screen could be the module that I was searching.
    With STMPE610 touch controller (SPI/I2C) it would be easy to make systems that do not need any additional input devices (buttons/joystick).
    Oct 2013
    hi Richard,
    today arrived TFT display to me from eBay.
    I can not wait to start playing with it
    Do you can tell me if this is the correct way to connecting peripherals with a PIC processor (pic18f87J11)
    TOUCH PANEL connection to PIC
    TOUCH PANEL PIC
    T_CS PORT F.2
    T_DIN PORT F.3
    T_DO PORT F.4
    T_CLK PORT F.1
    T_IRQ PORT F.5
    TFT display connection to PIC
    TFT DISPLAY PIC
    DC PORT C.2
    CS PORT C.1
    RST PORT C.0
    MOSI PORT C.5
    SCK PORT C.3
    FLASH MEMORY W25Q32 connection to PIC
    FLASH W25Q32 PIC
    CS PORT H.0
    SO PORT D.5
    SI PORT D.4
    SCK PORT D.6
    My TFT module have a XPT2046 touch controller is this the some controller on your board?
    Model of my tft module is : TJTCM24028-SPI 2.8 TFT SPI 240X320 v1.1
    its not the only way but its the way my demo platform is connected
    my tft touch module is : TJTCM24024-SPI 2.8 TFT SPI 240X320 , I got no docs with it and have not been able to identify the controller. but it has XPT2046 stamped on the chip so it looks the same as yours
    I was looking on ebay and i could not find any 2.8" TJTCM24024.
    The only TJTCM24024 i could find is a 2.4"
    see here:
    http://www.ebay.com/itm/2-4-240x320-...item20eaff07d1
    Also the TJTCM24028:
    http://www.ebay.com/itm/240x320-2-8-...item41998b289b
    Maybe the 24028 means 2.8" and the 24024 means 2.4".
    @Richard,
    Can you double check you your display is really 2.4" or 2.8"?
    Rui
    forgot the happy snap
    Oct 2013
    HELLO Richard,
    If you could give me some explanations about connections of the LCD display on PIC processor.
    I just ordered one piece from eBay and on it I have these pins:
    LCD DISPLAY ILI9341 --------> PIC-PROCESSOR
    VCC---->3.3V
    GND--->ground
    LED--->
    CS---->
    D/C------->
    RESET---->
    SDI------>
    SDO----->
    SCK------->
    I don't now how to connect it on PIC?
  1. Replies: 0
    Last Post: - 25th September 2013, 18:33
  2. code examples / libraries for ILI9320 2.8" TFT LCD Module
    Last Post: - 6th June 2013, 08:50
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 16:05
  4. What's with PBP3?
    Last Post: - 10th August 2011, 17:09
  5. Experience of driving TFT screens?
    By isaac in forum General
    Last Post: - 26th September 2008, 00:15
Members who have read this thread : 7
