I am using a PIC18F87K22 micro. I have timer2 setup with PR2 to generate an interrupt 250 times per second
'setup timer2
'Fosc/4 with prescaler=16 AND postscaler of 16 yields 62,500 Hz, count of 250 gives interrupt every 250th of a second
'64mhz/4 = 4 mhz............16mhz/256 = 62500 hz.....use for 64 Mhz clock
PR2 = 249 'Timer2 Period Register
T2CON = 111110
PIE1.1 = 1 'enable the timer2 interrupt
Both UARTS are set to 19,200 baud (actually 19,230)
Each UART will generate an interrupt if a character arrives and I can read both serial ports without any issues whatsoever.
It is when I send characters where it appears that the UART timing seems to go screwy and the receiving
computer gets strings with incorrect or missing characters
If I transmit an array this way
HSEROUT2 [STR SENDBUFF\30]
It does not work. But if I disable the timer2 interrupt it works fine.
However if I use assembly the timer2 interrupt does not affect it at all.
FOR I = 0 TO 29
SENDCHAR = SENDBUFF(I)
GOSUB SENDCOM2
NEXT I
SENDCOM2:
;MOVFF source, destination = move source reg to dest reg
@MOVFF _SENDCHAR,TXREG2
CHECKCOM2:
@MOVFF TXSTA2,_SENDCHAR
IF SENDCHAR.1 = 0 THEN GOTO CHECKCOM2 'wait until transmit buffer is empty
Suggestions?
					 HSEROUT with Timer2 Interrupt
 Re: HSEROUT with Timer2 Interrupt
