Not able to compile code due to PBPPROC.bal file not found
+ Reply to Thread
Results 1 to 3 of 3
    Jun 2015
    Default Not able to compile code due to PBPPROC.bal file not found
    Hey All, I am relatively new to programming with the Picbasic Pro compiler and MPLAB IDE v.8.53. I am currently trying to compile some old code (C with inline assembly) on a windows 8.1 machine. I am trying to compile this for the 18F4520. When attempting to compile, I am getting the following error:
    Executing: "C:\PBP\PBPMPLAB.BAT" -p18F4520 -n -ampasmwin -k# "FILE.pbp"
    Executing: "C:\PBP\PBPW.EXE" -p18F4520 -n -ampasmwin -k# "FILE.pbp"
    PICBASIC PRO(TM) Compiler 2.60LA, (c) 1998, 2009 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to find -p<pic> processor file PBPPROC.BAL
    PICBASIC PRO(TM) Compiler 2.60A, (c) 1998, 2010 microEngineering Labs, Inc.
    Note that there is a 18F4520.BAL file in the PBP directory, and there appears to be a .BAL, .BAS and .INC file for most processors. There is also a PBPPROC.BAS file and a PBPPROC.INC file but no PBPPROC.BAL file. The PBPPROC .BAS and .INC files both only contain this:
    INCLUDE "16F84.BAS"
    in the .bas file and
    INCLUDE "16F84.INC"
    in the .inc file.
    Is there an easy solution to solve this? Can I make a .BAL file? Why wasn't this file in the directory when I installed PBP?
    Thanks in advance!
    Default Re: Not able to compile code due to PBPPROC.bal file not found
    Am I understanding you correctly? You are trying to compile C code with PicBasic? If so, that will not work, PicBasic is a compiler for PicBasic.
    If I am misunderstanding, please post your code so we can see what is going on.
    Jun 2015
    Whoops, that was a mistake. The file is indeed in PicBasic, and has inline assembly denoted by "asm" and "ENDASM" lines. It was provided as a .txt file, and includes a .pbp file that is just a bunch of routines written in assembly. Thank you for the quick response!
  1. Installation. Include file not found?
    By thronborg in forum General
    Last Post: - 18th March 2011, 20:46
  2. Replies: 1
    Last Post: - 16th May 2010, 19:24
  3. Fail to compile, COD file missing
    By Jumper in forum mel PIC BASIC Pro
    Last Post: - 29th June 2009, 18:20
  4. ERROR: Macro MOD?TCB not found in macro file.
    By JohnP in forum mel PIC BASIC Pro
    Last Post: - 17th February 2009, 20:10
  5. Cannot Open File Compile Error
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 9th January 2009, 19:18
