LCD showing mostly jibberish on 16F716
Results 1 to 22 of 22
    Dec 2007
    Default LCD showing mostly jibberish on 16F716
    I've had a break from PIC's for a little so I'm a bit rusty, but I don't recall having this many issues in the past.
    Just trying to get an LCD to work first on my 16F716. I haven't used this pic before so might have some config wrong.
    B4-B7 goto DB4-DB7 on my 2-line LCD
    RW is held low VIA code, Enable and RS are on corresponding pins.
    The issue is that I get mostly jibberish all over the screen changing constantly, with glimpses of the text I'm trying to put there. I've mostly used 4-line LCD's before so don't even know if I have the addressing right, I dont' have a datasheet for this exact LCD
    I have tried fiddling the COMMANDUS and DATAUS values but they haven't had an effect, even without them there.
    @ __CONFIG    _WDT_ON & _RC_OSC & _PWRTE_ON
    DEFINE  LCD_DREG        PORTB
    DEFINE  LCD_DBIT        4
    DEFINE  LCD_RSREG       PORTB
    DEFINE  LCD_RSBIT       3
    DEFINE  LCD_EREG        PORTB
    DEFINE  LCD_EBIT        1
    DEFINE  LCD_LINES       2
    DEFINE LCD_COMMANDUS 1500 	'defines the delay after LCDOUT statement
    DEFINE LCD_DATAUS 44 		'delay in micro seconds
    TRISA = %11111
    TRISB = %00000000
    butdn           var porta.4
    butup           var porta.3
    butmode         var porta.2
    bail2           var porta.0
    bail3           var porta.1
    clutch          var portb.0
    lcdrw           var portb.2
    c               var word
    c = 0
    lcdrw = 0
    pause 150
    lcdout $fe,1
    Start: '************************************************************************   START
    c = c + 1
    lcdout $fe,1
    lcdout $fe,$00,"This is a test "
    lcdout $fe,$40,DEC c
    if c > 100 then
      c = 0
    GOTO start
    Default Re: LCD showing mostly jibberish on 16F716
    I was going to suggest increasing the command and/or data delay considerably (say 5000us for command and 200 for data) just to see if it starts to work but perhaps you've already tried that while fiddling with the numbers?
    Apart from that it's the usual suspects like ADC and comparators but your device doesn't have any of that on the pins used so that can't be it. So, I think it's either a slow controller or a hardware problem like one of the datalines not reaching the controller.
    Dec 2007
    Thanks for thereply.
    I haven't gone that high with the numbers so I'll try that in the morning. I made the pcb with a cnc machine, the socket is very close to the pic and the lcd is plugged straight into it. I don't think it's a connection problem but I will triple check. I put a 4 line lcd on and the same problem occurs.
    I am using the internal oscillator, could that be a cause?
    Oct 2009
    If that's the full code, then should there not be an DEFINE OSC XX to let PBP know what frequency the PIC is running at.
    Have a look at my last post in this thread http://www.picbasic.co.uk/forum/showthread.php?t=20024
    You may need to change the config settings to match the chip you are using, but if it has an internal 4 Mhz clock then it should work without too much modifications
    Dec 2007
    A late night case of "I wonder if" has got me up. Set the command and data times up higher, still the same.
    Not real happy with a couple of the SMD solder pads for the pic. The leg has solder, and the pad has solder, but not convinced they are soldered together. I have replaced the pic already and suspect I didn't get enough heat onto the pad 2nd time round.
    Tomorrow I'll resolder at the workshop and cross my fingers.
    Oct 2009
    I don't have a 16F716 to play with, but the following code works with an 18F 4580 running at 4mhz from its internal clock. LCD is on port B
      __CONFIG    _CONFIG1H, _OSC_IRCIO7_1H ; _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 4
    ADCON1 = $0F
    clear
    DEFINE LCD_DREG  PORTB           ' LCD Data port
    DEFINE LCD_DBIT  0               ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB           ' LCD Enable port
    DEFINE LCD_EBIT  5               '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB           ' LCD Register Select port
    DEFINE LCD_RSBIT 4               '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4               ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4               ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000        ' Command delay time in us
    DEFINE LCD_DATAUS 50             ' Data delay time in us
    LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250 ' Initialize LCD
    TRISA = %11111
    TRISB = %00000000
    butdn           var porta.4
    butup           var porta.3
    butmode         var porta.2
    bail2           var porta.0
    bail3           var porta.1
    clutch          var portb.0
    lcdrw           var portb.2
    c               var word
    c = 0
    lcdrw = 0
    pause 150
    lcdout $fe,1
    c = c + 1
    lcdout $fe,1
    lcdout $fe,$00,"This is a test ",DEC c
    if c > 100 then
      c = 0
    GOTO start
    I'm using an EasyPIC5 board which has the LCD wired as shown below
    You could try breadboarding the circuit to confirm the code etc is working. If so then the issue may well be with your PCB
    Dec 2007
    Scampy,
    That is interesting and a part of this PIC I don't fully understand. I've used PIC's with Internal OSC before, but quite a while ago and I don't remember being this confused about it.
    It seems unclear to me in the datasheet what frequency the internal OSC runs at and if any external components are required. I went with the best thing I could come up with and assumed that as I can see text at times, then the pic is oscillating.
    I did try DEFINE OSC 4 at the top earlier, but the problem still occurred.
    Oct 2009
    Obviously by using the internal oscillator you can omit the external crystal shown in the easyPIC5 diagram. Some of the config lines in the code might need removing as you are using a different family of PICs than the one I used for testing. When I tried your code it compiled OK, but you have one line missing which could be the cause
    Dec 2007
    I noticed the LCD_BITS 4 line in your code. I've never used that line before and always used 4-bit LCDs. I added it anyway and no change. I also changed the LCD init line to same as yours, and outputted everything on one LCDOUT command like you. Same result.
    I'm sure I recall using a specific command to use the internal osc in the past, whereas this datasheet indicates clearing option register bit 5 will turn it on?
    To be honest I don't really know how to set the option register bits with the setup I am using now. I'm using the dos-based pickit2 so I don't get to choose the option bits before I hit program.
    I feel stupid for claiming I've done this before but not knowing how to set option reg bits.
    Scampy,
    Nice catch and something Worth a try but the manual does say that if not told otherwise PBP assumes 4-bit mode.
    davewanna,
    You say in your post that you're using the internal oscillator but as far as I can see the 16F716 doesn't have one. And you've got the config set to RC_OSC indicating external RC combination on the OSC1 pin. If that IS what you're using what values do you have for R and C and have you verified at what frequency the PIC is actually running?
    If you don't DEFINE OSC xx PBP assumes 4MHz. If the actual speed is different, then all timings will be off.
    EDIT: OPTION_REG.5 Controls from where TMR0 gets its clock. OPTION_REG.5 = 0 will clear that bit but it's got nothing to do with the problem at hand.
    Dec 2007
    After reading more datasheet and looking at the PBP inc file for this chip, the best I came up with in my tired state is to change my first line to....
    @ __CONFIG _WDT_ON & _RC_OSC & _PWRTE_ON & OPTION_REG = %11011000
    Now I'm sure this is wrong, can anyone point me to the idiots guide to setting option regs?
    Dec 2007
    Henrik,
    That would explain why I can't find an easy way of turning it on and off. Having said that, in my circuit the OSC pins are left floating. How is it doing anything?
    Edit: I think you're right Henrik, I've been trying to make it do something it isn't meant to do.
    I will add a crystal osc tomorrow and change the osc source and see how I go.
    Yeah, with the OSC pins floating it might be picking up noise and running off of that.
    For that device you need an external crystal/resonator or an external R/C network - or an external clock signal for that matter. With both OSC pins floating you have neither.
    Dec 2007
    You're exactly right Henrick.
    I put a 4Mhz osc on it thismorning, works perfectly.
    I'm surprised it worked at all with no external osc components.
    Cheers
    Oct 2009
    I must admit I'm surprised that it doesn't have a built in oscillator. Thought that all pics had that ??
    Actually, according to the product selector on Microchips website only 18 out of around 375 models (which are in production) is missing an internal oscillator of one type or another. They are:
    PIC16F54
    PIC16F57
    PIC16F716
    PIC16F59
    PIC16F1454
    PIC16F1455
    PIC16F1459
    PIC16HV540
    PIC16F818
    PIC16F819
    PIC16F72
    PIC16F73
    PIC16F84A
    PIC16F74
    PIC16F76
    PIC16F77
    PIC18F6520
    PIC18F8520
    So it's close but not quite all ;-)
    I have used both the pic16f818 and 819 which are in the list. Both have internal oscillators to 8mhz.
    Microchip has one of the worst website/search engines out there.
    That's just weird, selecting No and None in the Internal Oscillator column of the product selector produced the above list. Checking the 16F818 does indeed show it's got internal oscillator.
    Thanks for pointing that out Mark!
    Dec 2007
    I cut my teeth on the 16F877 and it is my understanding it does not have an internal oscillator. And it doesn't seem to be in your list Henrik.
    That seems correct.
    Conclusion: The list is flawed and so is the data Microchip is using in their selector tool - which is what generated the list.
    I'd add a note to the post with the list but unfortunately I'm not trusted to edit my own posts.
    Sorry for the confusion.
    Dec 2007
    All is good. I'm just glad I'm able to shift some of the blame from myself to Microchip in this instance.. haha
    Thanks for all the help anyway circuit now working like it should, now back to finishing the code....
    Sep 2006
    Indiana, USA
    Your open pins were probably acting like little antennas and picking up something nearby on occasion that just happened to be what the pic was expecting as an OSC frequency, hence the occasional flicker of life . Floating pins on PICs can do some pretty weird stuff, or on logic chips of any sort.
    Glad you got it sorted!
  1. Replies: 6
    Last Post: - 19th August 2013, 12:22
  2. 16f716
    By amit28 in forum mel PIC BASIC Pro
    Last Post: - 28th November 2007, 18:56
  3. 16f716
    By mwhatley in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2006, 21:35
  4. Showing numbers in diffrent ways?
    By SuB-ZeRo in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 16:57
  5. Reading a Hex value from a Modem and showing it as Decimal..
    Last Post: - 16th March 2005, 18:58
