Pulse capture on 12F1822
Results 1 to 4 of 4
    Nov 2008
    Default Pulse capture on 12F1822
    Hello all, I'm having a bit of a problem using the CCP hardware to measure a pulse length on a 12F1822. I know where the program stalls but I can't figure out why. I debugged the program by lighting an LED at the various points. It never moves past the second while/wend loop when the trailing edge of the pulse is supposed to trigger an interrupt. Any ideas on why the interrupt is never happening? Thanks.
    	__CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    	__CONFIG _CONFIG2, _PLLEN_ON
    OSCCON = %01110000		'8Mhz clock with 4x PLL (32MHz)
    APFCON = %00000001		'CCP1 on RA5 (pin 2) T1G is RA4 (pin 3)
    PORTA = 0				'RA5 all low
    TRISA = %00100000		'RA5 input
    CM1CON0 = 0 			'turn off comparitor 1
    CM1CON1 = 0 			'configuration of comparator
    MDCON = 0 				'turn off data modulator
    DACCON0 = 0 			'turn off DAC
    DACCON1 = 0				'turn off DAC
    ANSELA = 0				'All pins digital
    OPTION_REG = %10000000	'Weak pull ups off
    FVRCON = 0				'Bunch of stuff disabled
    CPSCON0 = 0				'Cap touch sensors off
    CCP1AS = 0
    PIE1.2 = 1
    PIE2 = 0
    T1GCON = 0
    DEFINE OSC 32
    Include "modedefs.bas"
    Symbol		Capture = PIR1.2
    T1			VAR word
    PW			VAR word
    reload:
    low porta.2
    CCP1CON = %00000101
    T1CON = 0
    TMR1H = 0
    TMR1L = 0
    T1CON.0 = 1
    Capture = 0
    while !Capture
    wend
    T1.HighByte = CCPR1H
    T1.LowByte = CCPR1L
    CCP1CON = %00000100
    Capture = 0
    while !Capture
    wend
    PW.HighByte = CCPR1H
    PW.LowByte = CCPR1L
    PW = PW-T1
    serout porta.4,N9600,[#PW,"uS High",13,10]
    goto reload
    Nov 2007
    West Covina, CA
    Default Re: Pulse capture on 12F1822
    It looks like you're monitoring for a positive going pulse that is caught by the first While/Wend but will stay there because the second While/Wend is waiting for it to go Positive again.
    Change the second one to:
    while Capture
    wend
    So now it is waiting for the pulse to go Low.
    Or am I missing something to?... yup, thought the "Capture" was a pin, it's the interrupt. NM
    Louie
    Nov 2007
    West Covina, CA
    Okay looked a little closer and "think" you need to enable the interrupts with:
    INTCON = %11000000  'Enables global and all active peripheral interrupts
    Louie
    Nov 2008
    Louie, thanks for looking it over but I have to admit the mistake of operator error on my part I was using the sync output on the signal generator instead of the real output. Here is the working code.
    CCP1AS = 0
    PIE2 = 0
    T1GCON = 0
    INTCON = 0
    DEFINE OSC 32
    T1			VAR word
    PW			VAR word
    reload:
    CCP1CON = %00000101
    T1CON = 0
    TMR1H = 0
    TMR1L = 0
    T1CON.0 = 1
    Capture = 0
    while !Capture
    wend
    T1.LowByte = CCPR1L
    CCP1CON = %00000100
    Capture = 0
    while !Capture
    wend
    PW.LowByte = CCPR1L
    PW = PW-T1
    serout porta.4,N9600,[#PW,10,13]
    goto reload
  1. 12F1822 troubles
    By Charlie in forum mel PIC BASIC Pro
    Last Post: - 24th June 2012, 13:53
  2. Use Timer1 Gate to Capture Pulse Widths
    Last Post: - 23rd March 2012, 17:21
  3. 12F1822 embedded host?
    By dhouston in forum USB
    Last Post: - 18th September 2011, 19:14
  4. MIBAM and 12F1822...
    By alesniak in forum mel PIC BASIC Pro
    Last Post: - 17th September 2011, 07:45
  5. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
