Spi flash example - 4kb/32kb/64kb erase support / winbond 25q series
Results 1 to 10 of 10
    Feb 2012
    PERTH AUSTRALIA
    Default Spi flash example - 4kb/32kb/64kb erase support / winbond 25q series
    Hi Guys
    had need to review the SPI flash routines to incorporate the 4kb/32kb/64kb erase support and other features offered by the WINBOND series of flash chips
    this is a re- vamp of the code i did last year and i posted for the 8mb chip to support another flash chip manufacture
    hope you find it of use and dont have to re do the code wheel - again
    this should be as an include to your main code
    regards
    Sheldon
    '*          : All Rights Reserved                                                        *
    '*  Date    : 4/05/2015        *
    '*  Version : 2.0        *
    '*  Notes   : Rewriten for Winbond SPI W25Q series Serial NOR Flash chips ..             *
    '*          :  W25Q32 - 32Mbit(4MB)                                                      *
    '*          : --- Orginal code (V1.1) based on support for M25P80 8Mbit chip or simular  *
    '*          :  no support of duel / quad SPI & QPI options                               *
    '*          :  No support for Fast Write ( W25Q80 )                                      *
    '*          :  NO support of Suspend write/read operations                               *
    '*          : chips are 3.3v - NOT 5V input tollerant                                    *
    '*          : Code supports .....                                                        *
    '*          : 1  Software Protection of data , hardware WP and Hold pins high            *
    '*          : 2. 4KB sectors , 32/64KB blocks, for protection / erasing, copy commnads   *
    '*          : 3. Manufacture ID /Chip size detection / selection for number of blocks    *
    '*          : 4. Copy commands reseved use of scratch pad area of Block 0                *
    '*       : code does not need Longs to be enabled to save on code space                  *
    ' Operational Notes on Timing Max and Min times                                          *
    '   1. powerup delay to CE & WR = 5ms min                                                *
    '   2. 256 bytes max per read / write                                                    *
    '   3. spi bus (mode 3) (clock idle High) and flash CE configures in main program        *
    '   4. avg is 20ma during write /25ma for erase, 15ma for read                           *
    '   5. min 50ns  on CE deselect                                                          *
    '   6. SPI chip interface timing has min of 5ns requirements , so no timing issues       *
    '       for picbasic which has a min of 2us using shiftout cmd                           *
    '   7. software reset via spi = min 30us - BUSY & SUS bits are checked before issue      *
    '   8. sector erase (4KB)= min 45mS  max 400ms,                                          *
    '   9. block Erace(32KB) = min 120ms max 1.6sec                                          *
    '  10. Block Erase (64KB)= min 150ms max 2.0sec                                          *
    '  11. Chip Erase(32Mbit)=min 10sec max 50sec                                            *
    '  12. hold/reset pin - factory dephalt is hold                                          *
    '  13. WP pin is not active - SRP1=0 , SRP0 =0 - FACTORY DEPHALT                         *
    '  14. 25QxxIQ has QE bit in register 2 = 1 from factory and cannot be cleared           *
     '---------- Winbond SPI FLASH (W25Q series) commands set --------------------------------
     ' NOTE: No support for DUAL/QUAD/ QPI instruction sets
     '             SDC_cmd, SDC_CmdCode
     ' command 1-13 use the Write enable command ---
     Flash_Wr_reg1        con 1  ' $01       'def write the Status Register 1(S7-S0)   - 1 byte data - write enable req prior
     Flash_Wr_reg2        con 2  ' $31       'def write the Status Register 2(S15-S8)  - 1 byte data - write enable req prior
     Flash_Wr_reg3        con 3  ' $11       'def write the Status Register 3(S23-S16) - 1 byte data - write enable req prior
     Flash_WR             con 4  ' $02       'def Page Program mode command        ( 24bit address req)+ (1 byte data)- write enable req prior
     Flash_Wr_Secreg      con 5  ' $42       'def Program Security Register write  ( 24bit address req)+ (1 byte data)- write enable req prior  - holds access upto 256byte data per register
     Flash_Sec_Ers        con 6  ' $20       'def Sector Erase command (4KB)       ( 24bit address req)               - write enable req prior
     Flash_Blk32_Ers      con 7  ' $52       'def Block 32KB Erase Command (32KB)  ( 24bit address req)               - write enable req prior
     Flash_Blk64_Ers      con 8  ' $D8       'def Block 64KB Erase Command (64KB)  ( 24bit address req)               - write enable req prior
     Flash_Indv_Blk_LCK   CON 9  ' $36       'def Indervidual Block/Sector Lock    ( 24bit address req): WEP must be 1 to setup and use  - write enable req prior
     Flash_Indv_Blk_UNLCK CON 10 ' $39       'def Indervidual Block/Sector UNLock  ( 24bit address req): WEP must be 1 to setup and use  - write enable req prior
     Flash_Secreg_Ers     con 11 ' $44       'def Erase Program Security Register  ( 24bit address req) - write enable req prior
     Flash_Bulk_Ers       con 12 ' $C7       'def Bulk Erase command                 - write enable req prior
     Flash_Globe_LCK      con 13 ' $7E       'def Globel Block /Sector Lock      : WEP must be 1 to setup and use   - write enable req prior
     Flash_Globe_UNLCK    con 14 ' $98       'def Globle Block/Sector Unlock     : WEP must be 1 to setup and use   - write enable req prior
     ' commands 14-12 use the Read command ---
     Flash_RD             con 15 ' $03       'def read data at normal speed        ( 24bit address req)+ (1 byte data)
     Flash_Rd_HS          con 16 ' $0B       'def read data at High speed (Fast Read) ( 24bit address req)+ (1dummy+1 byte data)
     Flash_Rd_Secreg      con 17 ' $48       'def Program Security Register read  ( 24bit address req)+ (1 dummy +1 data)( simular to fast read command )
     Flash_Rd_Sig         con 18 ' $4B       'def read Flash device Unique ID signature - cmd + 4 dummy bytes , returns 64bit ID MSB first
     Flash_Rd_Blk_LCK     con 19 ' $3D       'def Read Block/Sector Lock status  , returns 0= unlocked 1= Locked ( 24bit address req)+ (1 byte data)
     Flash_Rd_ID          con 20 ' $9F       'def Read manufacture 1byte/device/UID code 2 bytes ( JEDEC ID) - returns 3 bytes
     Flash_Rd_reg2        con 21 ' $35       'def read the Status Register 2(S15-S8)  - returns 1 data byte
     Flash_Rd_reg3        con 22 ' $15       'def read the Status Register 3(S23-S16) - returns 1 data byte
     '---- not in command lookup table - used directly -----
     Flash_Wr_dis      CON $04        'def write disable command
     Flash_Rd_reg1     con $05        'def read the Status Register 1(S7-S0)  - done by Bsy_chk routine
     Flash_Wr_en       con $06        'def write Enable command
     Flash_Vol_Wr_EN   con $50        'def  Volatile SR Write Enable - used to change write_reg1 bits but wont set WEL flag - quick way of changeing register for protection bits ( no write enable
     Flash_EN_Rst      con $66        'def Enable Software Reset  - reset takes min 30us
     Flash_Rst         Con $99        'def Do a Reset  - Must be combined with Flash_EN_Rst
     Flash_PWR_Dwn     con $B9        'def Deep Power Down command
     Flash_PWR_Up      con $AB        'def Release From Deep Power Down command
    ' ----------  FLASH varables -------------------------
     Data_Length    var byte       ' table of data length
     SDC_buffer	    Var Byte[256]  ' indexed data - max 256 bytes - 8mb FLASH has a 256 Limit from page Writes - Note 512 used in SD routines
     SDC_data_in    Var Byte       ' Data in byte from flash
     SDC_data_out   Var Byte       ' Data out byte from Flash -
     SDC_address_High   Var word   ' address higher word sent to FLASH
     SDC_address_Low    Var word   ' address lower  word sent to FLASH
     SDC_index	    Var Word       ' Loop index counter
     SDC_CmdCode    Var Byte       ' used here as Sector protect value for the Write Status register
     SDC_cmd	    Var Byte       ' command code for selected operation
     SDC_Block      var Byte       ' 64K block Address   - uses SDC_address_High.low , each block 0-63(32Kbit) 0-127(64Kbit), addressing used both
     SDC_Sector     var byte       ' 4K Sector address   - uses SDC_address_Low.highbyte , each sector = 16 pages , so sector 0 = page 0-15  - values = 0 -15
     SDC_Page       var byte       ' Page Address
     SDC_Byte       Var byte       ' Bytes Address
     Flash_RD_Fast  var bit        ' Flag for High speed read 1 = Highspeed read speed 0= normal read speed
     Flash_Install  var bit        ' flag set when flash install program used
     Flash_32KB_Block_Sel  var bit ' Sets StartPage address for 32KB Block erase - 0 = lower block - sets start page address - page 0 - 127, 1 = High block - page 128 - 256
     Flash_Protect  var bit        ' Set Protect =1 / Unprotect =0 of a block , used as a read of block status as well
     Flash_Blk_Orgin    var byte  ' Orgin sector value     - copy sector command
     Flash_Blk_Dest     var byte  ' destination  sector value  - copy Sector Command
     Flash_Sec_Orgin    var byte  ' Orgin sector value     - copy sector command
     Flash_Sec_Dest     var byte  ' destination  sector value  - copy Sector Command
     Flash_Page_Orgin   var byte  ' Orgin Page value
     Flash_Page_Dest    var Byte  ' Dest Page Value
     Flash_Page_Length  var byte  ' number of pages
     Flash_Clear         var bit  ' flag to clear orginal sector 1= clear
     Flash_Manf_id   var byte    ' manufacture id code
     Flash_Manf_type var byte    ' device type code
     Flash_Manf_cap  var byte    ' device capacity code
     Flash_tmp       var byte    ' used as a temp varable
     Flash_tmp2      VAR BYTE    ' used as a temp varable
     Flash_Reg_val   var byte    ' Flash register value
     Flash_Addr_Copy_Low  var word  ' low word temp storage of input address and data length
     Flash_Addr_Copy_High var word  ' high word temp storage of input address and data length
    '----------- Varable settings at startup ---------------------------------------------
       Flash_RD_Fast = 0        ' Set to normal read at start
       Flash_Install = 0        ' set to 0 when flash  install not being used
       Flash_Clear = 0          ' set not to clear
       Flash_32KB_Block_Sel = 0 ' set to use low address
    '---------------- Routines  ------------------
    goto JumpOverSPIFLASH     ' Jump to end of this include file  for Correct compile
      Flash_Init:
        ' do a read register command to clear the Flash register after power up
             FLASH_CE = 0                                  ' Bring the FLASH chip select line low
              SDC_data_out = Flash_Rd_reg1                 ' Send the read status register command byte
     	      Gosub Flash_spiw	                           ' Write Byte SDC_data_out. , subroutine writes a byte on the SPI bus
             FLASH_CE = 1                                  ' Bring the FLASH chip select line high
             gosub buffer_clear                            ' clear varables area
      Buffer_Clear:
          For SDC_index = 0 To 255
              SDC_buffer[SDC_index] = 0
          next SDC_index
      Flash_Reset:
      ' routine to software reset the flash
      ' enable reset and reset must be consecutive
          SDC_data_out = Flash_EN_Rst                 ' Send Enable Reset command
          gosub Flash_spiw	                          ' Write Byte SDC_data_out. , subroutine writes a byte on the SPI bus
          SDC_data_out = Flash_Rst                    ' Send Reset command
     Flash_Format:
     'Note wont work if any sectors are protected
      ' can take upto 50sec on 32mbit chip
       sdc_cmd = Flash_Bulk_ers  ' excutes as it sounds
       gosub Flash_Comand
     Flash_Sec_Erase:
      ' assumes Block address  0-63
      ' assumes Sector value 0 -15
      ' erases 1 Sector at a time  address (4KB)= 15 pages
      ' Erases wont work on sectors that are write protected
      ' sector erase take 400ms per instruction
       SDC_pAGE = 0                          ' ensure 0
       SDC_pAGE = sdc_SECTOR << 4            ' shift given sector 0-15 to upper page value
       sdc_cmd = Flash_Sec_Ers               ' Erases  sector ( 256 pages x 256 bytes )
       SDC_address_high.byte0 = SDC_Block    ' set sector Address 0 to 15 for chip
       SDC_address_low.byte1  = SDC_Page     ' set page start address 0 to 255
       SDC_address_low.byte0  = 0            ' set byte start address 0 to 255
       gosub Flash_Comand                    ' Do the command
     Flash_Blk32_Erase:
      ' assumes flag 32KB_Block_Sel 0 = bottom 32Kb start address page, 1= 128page address
      ' erases 1/2 a 64KB Block at a time  address (32KB)= 128 pages
      ' sector erase take min 120ms max 1.6Sec per instruction
       IF Flash_32KB_Block_Sel = 0 THEN           ' select offset page for 32 byte sector
           SDC_PAGE = 0
           SDC_PAGE = 128
       sdc_cmd = Flash_blk32_Ers             ' Erases 32kB block ( 128 pages of 256 bytes )
       SDC_address_high.byte0 = SDC_Block    ' set block Address for chip
       SDC_address_low.byte1  = SDC_PAGE     ' set page start address 0 to 255
     Flash_Blk64_Erase:
      ' erases a 64KB Block at a time  address (64KB)= 256 pages
      ' sector erase take min 160ms max 2.0Sec per instruction
       sdc_cmd = Flash_blk64_Ers             ' Erases 64kB block ( 256 pages of 256 bytes )
       SDC_address_high.byte0 = SDC_Block    ' set Block Address for chip
       SDC_address_low.byte1  = 0            ' set page start address 0 to 255
     Flash_Block_Copy:
      ' copys data from 1 block to another
      ' erases destination block - optional clean of orginal block
      ' assumes Flash_Sect_Orgin,Flash_Sect_Dest ,Flash_clear
      ' Erases wont work on blocks that are write protected
      ' block erase take 400ms per instruction
          SDC_Block  = Flash_Blk_Dest            ' clear destination block
          gosub Flash_blk64_Erase                ' use SDC_blk64_erase info to erase destination sector
           for SDC_PAGE = 0 to 255               ' copy pages to selected block ( 256bytes at a time)
               SDC_Block  = Flash_blk_Orgin      ' block to copy
               SDC_byte    = 0
               Data_Length = 255
               gosub Flash_Read                  ' read the data to buffer
               SDC_Block  = Flash_Blk_Dest       ' block to copy to
               SDC_byte    = 0                   ' use block details for destination
               Data_Length = 255
               gosub Flash_Write                 ' write the data
           next SDC_PAGE
         if Flash_clear = 1 then
            SDC_Block = Flash_Blk_Orgin         ' clean up orgin Block
            gosub Flash_Blk64_Erase
     Flash_Page_Copy:
      ' copys data from pages 0 -255 from orgin or destination block
      ' assumes destination block pages are Erased
      ' assumes pages orgin and pages destination do not cross block boundrys
      ' assumes Flash_Page_Orgin,Flash_Page_dest ,Flash_Page_length, Flash_blk_orgin ,Flash_blk_dest
      ' writes wont work on blocks that are write protected
         for  Flash_tmp2 =  Flash_Page_Orgin to Flash_Page_length    '  copy sector 0 pages to selected sector 0 ( 256bytes at a time)
               SDC_Block  = Flash_blk_Orgin                     ' sector to copy
               SDC_PAGE =  Flash_tmp2
               SDC_byte    = 0
               Data_Length = 255
               SDC_Block  = Flash_blk_Dest                       ' sector to copy to
               SDC_PAGE = Flash_Page_Dest                        ' page to copy to
               SDC_byte    = 0
               Data_Length = 255
               Flash_Page_Dest = Flash_Page_Dest + 1              ' increment destination page
         next Flash_tmp2
     Flash_Write:
      ' assumes data length , address and upto 256 bytes in  SDC_buffer[] to send
      ' writes bytes from SDC_buffer[] into flash , block/page/byte loction must be "FF" at start
      ' write wont work on sectors that are write protected
       sdc_cmd = Flash_WR               ' excutes as it sounds - max of 256 bytes
       SDC_address_low.byte0  = SDC_byte     ' set byte start address 0 to 255
       gosub Flash_Comand
     Flash_Read:
      ' assumes Block, page, bytes , data length input
      ' gets upto bytes data into SDC_buffer[] from flash
      ' uses normal read speed if no Flash_RD_Fast flag set
       if Flash_RD_Fast = 1 then
         sdc_cmd = Flash_Rd_HS          ' excutes fast read  - max of 256 bytes
         sdc_cmd = Flash_RD             ' excutes normal read - max of 256 bytes cos of buffers size/ page size
       gosub Flash_Comand
     Flash_WR_protect:
     ' routine to protect/ unprotect a set block of 60-63 in 32kbit chip ( block 60-63 used by K9 system stored settings )
     ' Assumes Flash_Protect - 0 = unprotect 1 = Protect a sector
     ' SETUP FOR 32kB CHIP
     '  Bit7 = SRP0 - Set to 0 - software protect (SRP1= 0 DEPHALT(stat_reg2(bit0), not WP pin
     ' bits6(SEC) = 0 = 64KB Block 1= 4Kb SECTOR , Bit5(TB) 0= Top, 1 = Bottom , Bit4-2 = BP2-BP0. bits 1-0 (wel, busy )
         if Flash_Protect = 0 then
            SDC_buffer[0] = $00 ' clear all blocks
            SDC_buffer[0] = $0C ' set blocks 60-63 protected for K9 project
          sdc_cmd = Flash_Wr_reg1  ' write register
          data_length = 1          ' set 1 byte
          gosub Flash_Comand
       Flash_WR_Disable:
       ' reset the write enable latch
      Flash_Read_ID:
      ' returns JEDEC ID-  returns Manufacture ID byte($EF), mem type - (ID15-ID8)1byte ,capacity(ID7-ID0)1byte)
        sdc_cmd =  Flash_Rd_ID              ' Flash Read ID
        data_length = 3                     ' 3 bytes
        gosub Flash_Comand
        Flash_Manf_id =  SDC_buffer[0]
        Flash_Manf_type = SDC_buffer[1]
        Flash_Manf_cap  = SDC_buffer[2]
        IF FLASH_Install = 1 then
           HSEROUT ["Flash Manf ID = ",hex Flash_Manf_id,"  Flash Device ID = ",hex Flash_Manf_type,"  Device Capacity ID = ",hex Flash_Manf_cap,13,10]
      Flash_Read_Sig:
      ' returns the flash chips Unique ID number ( 64Bit)
        sdc_cmd = Flash_Rd_Sig               ' Flash Read Unique ID signature
        data_length = 4                      ' 4 bytes                ' Flash Read Unique ID signature
        gosub Flash_Comand
     Flash_Read_BLK_Lock:
     'routine to read block or sector locks ( WPS=1 to work )
       sdc_cmd =  Flash_Rd_Blk_LCK                          ' Flash Read block lock
       data_length = 1                                     ' 1 bytes
       gosub Flash_Comand
       Flash_Protect = SDC_buffer[0] & $01                  ' get bit0 value - 1 = locked .0 = unlocked
      Flash_Power_Down:
     ' sEt Flash chip to low power mode from standby mode - no command other tha powerup will wake the device
          SDC_data_out = Flash_PWR_Dwn              ' command to pwr down
      Flash_Power_Up:
     ' sEt Flash chip to standby mode - no command other tha powerup will wake the device
          SDC_data_out =  Flash_PWR_Up              ' command to pwr up
     Flash_Read_reg2:
     ' reads write register 2 -
     ' Register 2 controls .....
     ' bit7(S15)- Suspend Status
     ' bit6(S14)CMP -Compliment Protect - dephalt CMP =0
     ' bit5-3(S13-11)- Security Register(One time programable) dephalt = 000
     ' bit1(S9) - QE - Quad SPI Mode Enable ( default =0 when chips NOT FVIQ type)
     ' bit0(S8) - SRP1-  Protect bit1 _ dephalt =0
       sdc_cmd =  Flash_Rd_reg2                          ' Flash Read register 2
       data_length = 1                                   ' 1 bytes returned
       gosub Flash_Comand
     Flash_Read_reg3:
     ' Register 3 controls .....
     ' bit7(S23) - Hold(0- dephalt)/Reset(1) pin fuction
     ' bit6,5(S22,S21)(0,0=100%),(0,1=75%),(1,0=50%),(1,1=25%- dephalt) read driver strength- used to overcome cpacitive loading ,trace impendace issues with signal at high speed reads
     ' bits4,3 - reserved (writen as 0)
     ' Bit2(S18) WPS - selects Protection methode - Indervidual block/sectors(WPS=1) or by grouping range(WPS=0) ( WPS dephalt is 0 )
     ' Bits1,0-reserved(writen as 0)
       sdc_cmd =  Flash_Rd_reg3                          ' Flash Read register 3
       gosub Flash_Comand
      Flash_Comand:
      ' assumes SDC_address long
      ' assumbe data_Length = Lookup table to fill
      ' max 256 bytes per write
      ' erase of the sector by byte  / bulk is needed prior to write , as a write only changes a 1 to 0 , and the erase chanse the 0 to 1
       if  SDC_cmd = 0 then return           ' invalid command if value =0
     Lookup SDC_cmd,[$00,$01,$31,$11,$02,$42,$20,$52,$D8,$36,$39,$44,$C7,$7E,$98,$03,$0B,$48,$4B,$3D,$9F,$35,$15],SDC_CmdCode ' asignes command code to flash chip
          Flash_tmp = 0                        ' ensure 0 - counter for busychk loop
          gosub BSY_chk                        ' do for all commands
         if SDC_cmd <=14 then                  ' do for writes, sector erase,bulk erase , write reg protect - commands 1-14 use writen enable first
            FLASH_CE = 0                       ' Bring the FLASH chip select line low.
     	    SDC_data_out = Flash_Wr_en         ' Send  command byte that requires a write
       	    FLASH_CE = 1                       ' Bring the FLASH chip select line high to complete the write command
     	    pauseus 1                          ' pause between prev command  - may not need
         SDC_data_out =  SDC_CmdCode           ' Send the  command byte,
         if SDC_cmd =>4 and SDC_cmd <=11 or _           ' if write commands 4-11 then use 24bit address assigned
            SDC_cmd =>15 and SDC_cmd <=19 then          ' or read commands 15-19 then use 24bit address assigned , command 18 uses 24bit address as 3 dummy bytes
              SDC_data_out = SDC_address_high.Byte0     ' set block Address for chip
     	      SDC_data_out = SDC_address_low.Byte1      ' set page address 0 to 255
     	      SDC_data_out = SDC_address_low.Byte0      ' set byte address 0 to 255
              if SDC_cmd => 16 and SDC_cmd <= 18 then   ' if read High speed mode ,Program security read , Read Unique ID(add 4th dummy byte)
                 SDC_data_out = $00                     ' add a dummy byte to command
          if SDC_cmd <=5 or _                                ' if write commands require data bytes sent
             SDC_cmd >=15 and SDC_cmd <= 22 then             ' or read commands require data bytes returned
              For SDC_index = 0 To Data_Length-1             ' DATA LENGTH -1  so byte 0 is counted when setting data length
                  if SDC_cmd <= 5 then                       ' if write ,Write register,write Security register then
                     SDC_data_out = SDC_buffer[SDC_index]    ' send contents of indexed SDC_buffer
                     gosub  Flash_SPIw  	                 ' write byte SDC_data_in from SPI bus.  Returns SDC_data_in.
                  if SDC_cmd =>15 and SDC_cmd <=22 then      ' if read scommand returns data
                     gosub  Flash_SPIR  	                 ' Read Byte SDC_data_in from SPI bus.  Returns SDC_data_in.
     	             SDC_buffer[SDC_index] = SDC_data_in
              Next SDC_index
          pauseus 1
         FLASH_CE = 1                          ' Bring the FLASH chip select line high.
     Bsy_chk:
            SDC_data_out = Flash_Rd_reg1                ' Send the read status register1 command byte
            Flash_tmp = 0                               ' clear counter
           while  Flash_tmp <150                        '  loop test read for busy ( counter may need to be increased depending on size of chip and time for block erase command to complete
               Flash_Reg_val  = SDC_data_in               ' get value of read status reg value for use in flash install program checks for protection
               HSEROUT ["STATUS REG = ",hex Flash_Reg_val,13,10]  ' show on terminal when doing flash install
               HSEROUT ["Flash_tmp = ",dec2 Flash_tmp,13,10]
             Flash_tmp = Flash_tmp + 1
             SDC_data_in =  SDC_data_in & $01          ' mask bit 0 ( busy flag)
            if SDC_data_in = 0 then Flash_tmp = 151    ' Test bit 0 if write not busy,force exit of loop
           wend
      Flash_SPIR:
        SO = 1			                    ' Shift out high bits while shifing in data.
     	Shiftin SO, SCK, 6,[SDC_data_in]	' MSb first, clock idle high.
      Flash_SPIW:
          shiftout SI,SCK,5,[SDC_data_out]	    ' MSb first, clock idle high.
    JumpOverSPIFLASH:
    Default Re: Spi flash example - 4kb/32kb/64kb erase support / winbond 25q series
    Thank you for sharing with the forum!
    You can't use that Dave, Didn't you read the first line in the header!!!!!!
    EN82fn
    Well crap, I did not notice the first line...
    Feb 2012
    PERTH AUSTRALIA
    you can use it , i wrote it from scratch and you are welcome to it
    Feb 2012
    PERTH AUSTRALIA
    i am sure there will be further updates as i would like to use the suspend operations and other protection modes better
    what i like about flash is always the pricing for the size
    cheers
    sheldon
    Feb 2012
    PERTH AUSTRALIA
    since i put the data_length -1 in the "flash command " are so that value set in the data_length is the true byte value that will be returned - eg if data_lenght = 10 then 10 bytes are returned
    but the problem is that when you need 256byte (byte 0-255) then data_length needs to be a word value , not a byte
    cheers
    Sheldon
    Feb 2012
    PERTH AUSTRALIA
    did some updates
    this inlcude has a lot of bloat so comment it out if you not need the routines to reduce compile space
    i have shown some examples of how to use the routines as i got a few MP's on it recently
    remove comments as needed
    '*  Date    : 24/04/2022        *
    '*  Version : 2.0a        *
    ' Ver 2.0a - change example - fix Bsy_chk loop error for when multi 64k errace used      *
    '          - change to use flash_ce offset                                               *
    '          - change include name as SPI_flash.bas                                        *
    '          - make  Data_Length var a word cos of how the length input uses value of 256  *
    '            for selection                                                               *
    'SECTOR	PAGES REF          |   *** LATA.0 OFFSET VALUE CALCULATIONS FOR FLASH_CE ***     *
    '  0	0-15               |       LATA.0[0]  - LATA.0[7]  = LATA Port pins 0-7          *
    '  1	16-31              |       LATA.0[8]  - LATA.0[15] = LATB Port pins 0-7          *
    '  2	32-47              |       LATA.0[16] - LATA.0[23] = LATC Port pins 0-7          *
    '  3	48-63              |       LATA.0[24] - LATA.0[31] = LATD Port pins 0-7          *
    '  4	64-79              |       LATA.0[32] - LATA.0[39] = LATE Port pins 0-7          *
    '  5	80-95              |       LATA.0[40] - LATA.0[47] = LATF Port pins 0-7          *
    '  6	96-111             |       LATA.0[48] - LATA.0[55] = LATG Port pins 0-7          *
    '  7	112-127            |       LATA.0[56] - LATA.0[63] = LATH Port pins 0-7          *
    '  8	128-143            |       LATA.0[64] - LATA.0[71] = LATI Port pins 0-7          *
    '  9	144-159            |                                                             *
    '  10	160-175            |                                                             *
    '  11	176-191            |                                                             *
    '  12	192 -207           |                                                             *
    '  13	208-223            |                                                             *
    '  14	224-239            |                                                             *
    '  15	240-255            |                                                             *
    '============== EXAMPLE OF HOW TO USE THIS INCLUDE ======================================*
    ' a: SETUP I/O PINS FOR FLASH USE IN MAIN PROGRAM
    '    SCK           VAR LATC.3       ' Clock pin (output to RF modual)
    '    SO            Var PORTC.4      ' Master In   - flash chip Data out pin
    '    SI            Var LATC.5       ' Master Out  - flash chip Data in pin
    '    FLASH1_CE     con 22'= LATC.6  ' Chip select FLASH chip ( low)
    '   Note: i use an offset constant to select flash_ce, but normal var is fine
    '   offset methode used cos of multi flash chips on same spi pins and no need to change include to address them
    '   '*** NOTE: FLASH1_CE use LATA.0[LATA offset]
    '    LATA.0[FLASH1_CE] = 1          ' Active Low so set High to start
    '    SI = 1                         ' Set SI to idle high to start
    '    SCK = 1                        ' Set SCK to idle high to start
    '   Flash_EN = FLASH1_CE            ' Set Flash1_CE at start as the Flash1 to use in var of flash include
    ' b:   place include statement in main code
    '     INCLUDE "modedefs.bas"              ' Required for shiftout,shiftin commands as defined symbols
    '     include "SPI_Flash.bas"            ' include support of 8mbit Flash chip W25Q series
    ' C: examples of use
    '    most commands require the assumed variables listed in each command
    '   1. example 1 - Flash_Test:  routine to erase / write / read test data for scratchpad sector 0 - test of flash chip
    '   2. example 2 - erase lower 32k of block1
    '                  SDC_Block =1
    '                  Flash_32KB_Block_Sel = 0  ' select lower 32k of block
    '                  gosub Flash_Blk32_Erase
    '   3. example 3 - read block2 pages 0-2, 256 bytes of each page to serial monitor port
    '                - refer ' EXAMPLE 3  at end of page
     ' NOTE: there is a lot of bloat in this included where if you not need / use the routines they should be commented out
     '       this also should remove unused varables they use in routines you not need
     ' command 1-14 use the Write enable command ---
     ' commands 15-22 use the Read command ---
     Data_Length    var word       ' table of data length ( made word cos data length can be 256 so 0-255 byte = 256 total bytes
     Flash_Chk_Fail var bit        ' Flag result status of flash_test routine - called at startup
     Flash_SPI_Shared   var bit    ' Flag Set (1) when SPI is a shared bus between flash and RF module
     Flash_EN        var byte      ' Flash_CE pin value offset from LATA - value set in main program - allows for multi Flash chip CE from same routine
     Flash_tmp       var byte      ' used as a temp varable  - used in busy loop counter
      Flash_Init:
        ' called by gate_config routine at start
             LATA.0[Flash_EN] = 0                          ' Bring the FLASH chip select line low
             LATA.0[Flash_EN] = 1                          ' Bring the FLASH chip select line high
         '    gosub Flash_Reg_Setup                         ' setup req2 and reg3 for dephalts use of the flash 32Kb  ( not needed )
      Buffer_Clear:
          next SDC_index
      Flash_Reset:
     Flash_Format:
       gosub Flash_Comand
     'SECTOR	PAGES REF
    '  0    	0-15
    '  1	    16-31
    '  2	    32-47
    '  3	    48-63
    '  4	    64-79
    '  5	    80-95
    '  6	    96-111
    '  7	    112-127
    '  8	    128-143
    '  9	    144-159
    '  10	    160-175
    '  11	    176-191
    '  12	    192 -207
    '  13	    208-223
    '  14	    224-239
    '  15	    240-255
     Flash_Sec_Erase:
      ' erases 1 Sector at a time  address (4KB)= 16 pages - page 0 - 15 = sector 0
       sdc_cmd = Flash_Sec_Ers               ' Erases  sector (15 pages x 256 bytes )
     Flash_Blk32_Erase:
           SDC_PAGE = 0
           SDC_PAGE = 128
     Flash_Blk64_Erase:
     ' command routine commented out as it was not used to save space - but works ok
     'Flash_Byte_Modify:
     ' assumes Event_Get_Block_Page routine has given the event block and page
     ' assumes event selected block, event page address , event start SDC_byte , data length ( upto 256bytes )
     ' asusmes bytes changed are in the same sector and no boundry cross
     ' assumes block/sector 0 is not protected , block 0 is scrachpad
     ' assumes selected modifed block/sector is not protected
     ' assumes buffer[0]+ (length-1)  has bytes data that is to be modfifed
     ' Flash_Addr_Copy_high.byte1 =  Data_Length ' number of bytes to change  - save length in temp location
     ' Flash_Addr_Copy_high.byte0 =  SDC_Block   ' save event block address
     ' Flash_Addr_Copy_low.byte1  =  SDC_Page    ' save page addrees
     ' Flash_Addr_Copy_low.byte0  =  SDC_Byte    ' save start byte
     ' SDC_Sector = (SDC_Page & $F0) >> 4        ' get 4k sector from page number
     ' SDC_Block = 0                             ' set block to 0
     ' gosub Flash_Sec_Erase                     ' erase block 0 ,4k sector of page range
     ' SDC_Block = 0                             ' use sector 0,instead of given sector , but use given page, byte length
     ' SDC_Page =  Flash_Addr_Copy_low.byte1     ' restore orgin page addrees
     ' sDC_Byte =  Flash_Addr_Copy_low.byte0     ' restore orgin byte start address
     ' gosub Flash_write                         ' Write the changed byte data from buffer to sector 0
     ' if Flash_Addr_Copy_low.byte0 = 0 then               ' find the byte to copy - copy all bytes above 0 for given sector
     '       Flash_Page_Orgin =1                           ' start page of orgin
     '       Flash_Page_length = 255                       ' how many pages
     '       Flash_Sec_Orgin =  Flash_Addr_Copy_high.byte0 ' sector
     '       Flash_Sec_Dest = 0
     '       Flash_Page_Dest = 1
     '       gosub Flash_Page_Copy
    '   endif
    '  if Flash_Addr_Copy_low.byte1 = 255 then             ' find the pages to copy - copy all pages/ bytes  below given page/ byte of sector
    '        Flash_Page_Orgin =0                           ' start page of orgin
    '        Flash_Page_length = 254                       ' how many pages
    '        Flash_Page_Dest = 0
    '   endif
    '  if Flash_Addr_Copy_low.byte1 >0 and Flash_Addr_Copy_Low.byte1 < 254 then       ' find the pages to copy - copy all pages/ bytes  below given page/ byte of sector
    '        Flash_Page_length = Flash_Addr_Copy_low.byte1 - 1 ' how many pages
    '        Flash_Sec_Dest = 0                                ' start at same page value as orgin
    '        Flash_Page_Orgin = Flash_Addr_Copy_Low.byte1 + 1  ' start page of orgin
    '        Flash_Page_length = 255 - Flash_Page_Orgin        ' panges to copy  = 255 - start address +1
    '        Flash_Page_Dest = Flash_Addr_Copy_low.byte1 + 1
    '   endif
    '  if Flash_Addr_Copy_low.byte0 + Flash_Addr_Copy_high.byte1  < 255 then   ' if the start byte + data length of the data changed is < 255 bytes ,
               ' then copy  bytes  below the selected changed data
    '         SDC_Block  = Flash_Addr_Copy_high.byte0         ' read selected sector
    '         SDC_PAGE   =  Flash_Addr_Copy_low.byte1          ' of selected page
    '         SDC_byte = 0                                     ' start address bytes 0 to
    '         Data_Length = Flash_Addr_Copy_Low.byte0 - 1      ' selected byte - 1  ( length)
    '         gosub Flash_Read                                 ' read
    '         SDC_Block  = 0                                  ' use sector 0 aselected sector
    '         Data_Length = Flash_Addr_Copy_low.byte0 - 1      ' selected byte - 1  ( length)
    '         gosub Flash_Write                                ' write
              ' then copy  bytes above the selected changed data
    '         SDC_byte    = Flash_Addr_Copy_low.byte0 + Flash_Addr_Copy_high.byte1  ' start address bytes above given address and length
    '         Data_Length = 255 - SDC_byte                                 ' data above changed bytes ( length = 255 bytes  - given addrees + given length )
    '         gosub Flash_Read                                             ' read the data
    '         gosub Flash_Write                                            ' write  the data
    ' endif
        ' Block 0 should now have a complete copy of the data + changed data from the orginal selected sector
    '       Flash_Sec_Orgin = 0                          ' copy sector 0
    '       Flash_Sec_dest = Flash_Addr_Copy_high.byte0  ' erase destination  and copy data from flash orgin
    '       Flash_clear = 1                              ' set flag erase orgin sector 0 after copy
    '       gosub Flash_Block_Copy                      ' copy the sector
    ' return
    ' Flash_Block_Copy:
    '  ' copys data from 1 block to another
    '  ' erases destination block - optional clean of orginal block
    '  ' assumes Flash_Sect_Orgin,Flash_Sect_Dest ,Flash_clear
    '  ' Erases wont work on blocks that are write protected
    '  ' block erase take 400ms per instruction
    '      SDC_Block  = Flash_Blk_Dest            ' clear destination block
    '      gosub Flash_blk64_Erase                ' use SDC_blk64_erase info to erase destination sector
    '       for SDC_PAGE = 0 to 255               ' copy pages to selected block ( 256bytes at a time)
    '           SDC_Block  = Flash_blk_Orgin      ' block to copy
    '           SDC_byte    = 0
    '           Data_Length = 255
    '           gosub Flash_Read                  ' read the data to buffer
    '           SDC_Block  = Flash_Blk_Dest       ' block to copy to
    '           SDC_byte    = 0                   ' use block details for destination
    '           Data_Length = 255
    '       next SDC_PAGE
    '     if Flash_clear = 1 then
    '        SDC_Block = Flash_Blk_Orgin         ' clean up orgin Block
    '        gosub Flash_Blk64_Erase
    '     endif
    ' return
    ' Flash_Page_Copy:
    '  ' copys data from pages 0 -255 from orgin or destination block
    '  ' assumes destination block pages are Erased
    '  ' assumes pages orgin and pages destination do not cross block boundrys
    '  ' assumes Flash_Page_Orgin,Flash_Page_dest ,Flash_Page_length, Flash_blk_orgin ,Flash_blk_dest
    '  ' writes wont work on blocks that are write protected
    '     for  Flash_tmp2 =  Flash_Page_Orgin to Flash_Page_length    '  copy sector 0 pages to selected sector 0 ( 256bytes at a time)
    '           SDC_Block  = Flash_blk_Orgin                     ' sector to copy
    '           SDC_PAGE =  Flash_tmp2
    '           SDC_byte    = 0
    '           Data_Length = 255
    '           SDC_Block  = Flash_blk_Dest                       ' sector to copy to
    '           SDC_PAGE = Flash_Page_Dest                        ' page to copy to
    '           SDC_byte    = 0
    '           Data_Length = 255
    '           Flash_Page_Dest = Flash_Page_Dest + 1              ' increment destination page
    '     next Flash_tmp2
    ' return
     Flash_Write:
       gosub Flash_Comand
     Flash_Read:
       gosub Flash_Comand
     Flash_WR_protect:
          gosub Flash_Comand
       Flash_WR_Disable:
    '  Flash_Read_ID:
    '     sdc_cmd =  Flash_Rd_ID              ' Flash Read ID
    '     data_length = 3                     ' 3 bytes
    '     gosub Flash_Comand
    '     Flash_Manf_id =  SDC_buffer[0]
    '     Flash_Manf_type = SDC_buffer[1]
    '     Flash_Manf_cap  = SDC_buffer[2]
    '     IF FLASH_Install = 1 then
    '        HSEROUT2 ["Flash Manf ID = ",hex Flash_Manf_id,"  Flash Device ID = ",hex Flash_Manf_type,"  Device Capacity ID = ",hex Flash_Manf_cap,13,10]
    '      endif
    '   return
    '  Flash_Read_Sig:
    '    sdc_cmd = Flash_Rd_Sig               ' Flash Read Unique ID signature
    '    data_length = 4                      ' 4 bytes                ' Flash Read Unique ID signature
     ' return
    ' Flash_Read_BLK_Lock:
    '   sdc_cmd =  Flash_Rd_Blk_LCK                          ' Flash Read block lock
    '   data_length = 1                                      ' 1 bytes
     '  Flash_Protect = SDC_buffer[0] & $01                  ' get bit0 value - 1 = locked .0 = unlocked
    '  return
      Flash_Power_Down:
      Flash_Power_Up:
    ' Flash_Reg_Setup:
     ' ========== Note - NOT REQUIRED IT SEEMS ============
     ' Routine to write setup of status registers 2,3
    '      SDC_buffer[0] = %00000000 ' QE(bit1) is forced to 0 so that if FVIQ chip Fitted uses standard SPI bus , and not force pin Hold/ WP az data i/o
    '      sdc_cmd = Flash_Wr_reg2   ' write Status register2
    '      data_length = 1           ' set 1 byte
    '      SDC_buffer[0] = %01100000   ' this is the factory dephalt for chip
    '      sdc_cmd = Flash_Wr_reg3     ' write Status register3
    ' return
    ' Flash_Read_reg2:
    ' ' reads write register 2 -
    ' ' Register 2 controls .....
    ' ' bit7(S15)- Suspend Status
    ' ' bit6(S14)CMP -Compliment Protect - dephalt CMP =0
    ' ' bit5-3(S13-11)- Security Register(One time programable) dephalt = 000
    ' ' bit1(S9) - QE - Quad SPI Mode Enable ( default =0 when chips NOT FVIQ type)
    ' ' bit0(S8) - SRP1-  Protect bit1 _ dephalt =0
    '   sdc_cmd =  Flash_Rd_reg2                          ' Flash Read register 2
    '   data_length = 1                                   ' 1 bytes returned
    ' return
    ' Flash_Read_reg3:
    ' ' Register 3 controls .....
    ' ' bit7(S23) - Hold(0- dephalt)/Reset(1) pin fuction
    ' ' bit6,5(S22,S21)(0,0=100%),(0,1=75%),(1,0=50%),(1,1=25%- dephalt) read driver strength- used to overcome cpacitive loading ,trace impendace issues with signal at high speed reads
    ' ' bits4,3 - reserved (writen as 0)
    ' ' Bit2(S18) WPS - selects Protection methode - Indervidual block/sectors(WPS=1) or by grouping range(WPS=0) ( WPS dephalt is 0 )
    ' ' Bits1,0-reserved(writen as 0)
    '   sdc_cmd =  Flash_Rd_reg3                          ' Flash Read register 3
    '  return
      Flash_Comand:
    '   if Flash_SPI_Shared = 0 then NO_disable_rbc     ' if flag = 0 then is not a shared SPI bus with Rf Module  - jump over disable command
    '   #if __PROCESSOR__ = "18F27K40" or __PROCESSOR__ = "18F47K40"
    '@ INT_DISABLE IOC_INT                              ; Turn off IOC interupts (xxk40) for RX_mode   - done so shared SPI BUS ON RF-MODULE does not corrupt flash data
    '   #else
    '@ INT_DISABLE RBC_INT                              ; Turn off IOC interupts (xxk80,k22) for RX_mode   - done so shared SPI BUS ON RF-MODULE does not corrupt flash data
    '   #endif
    '  NO_disable_RBC:                                 ' label to jump over the INT_disable
            LATA.0[Flash_EN] = 0               ' Bring the FLASH chip select line low.
       	    LATA.0[Flash_EN] = 1               ' Bring the FLASH chip select line high to complete the write command
              Next SDC_index
         LATA.0[Flash_EN] = 1                          ' Bring the FLASH chip select line high.
    '     IOCCF.7 =0                                    ' 18f27k40 do a manual clear of the IOC port pin flag interupt - not done by DT_18_k40 atm 30/7/18
    '@ INT_ENABLE IOC_INT                              ; Turn on IOC interupts (xxk40) for RX_mode   - done so shared SPI BUS ON RF-MODULE does not corrupt flash data
    '   #else
    '@ INT_ENABLE RBC_INT                              ; Turn on IOC interupts (xxk80,k22) for RX_mode   - done so shared SPI BUS ON RF-MODULE does not corrupt flash data
    '   #endif
     Bsy_chk:
            while SDC_data_in.0 = 1                     ' while busy flag =1
                Flash_tmp = Flash_tmp + 1               ' tmp counter
                if Flash_tmp>65000 then goto BSY_Exit   ' if fail safe counter >65000 then exit - normaly under 65000 unless bulk erase
            wend
    BSY_Exit:
         '  IF FLASH_Install = 1 then                          ' used only for info
         '      HSEROUT2 [" Flash_tmp = ",dec Flash_tmp,13,10]
         '      IF Flash_tmp >65000 THEN HSEROUT2 [" Flash_tmp value HIGH - IF NOT CHIP ERASE",13,10] ' debug
         '  ENDIF
      Flash_SPIR:
      Flash_SPIW:
     ' routine to erase / write / read test data for scratchpad sector 0 - test of flash chip
     Flash_Test:
        SDC_Block = 0          ' set block address
        sdc_SECTOR = 0         ' set sector start address
        gosub Flash_Sec_Erase  ' erase sector 0  ( block0, pages 0-15 )
        SDC_Page = 0           ' set page start address 0 to 255
        SDC_byte = 0           ' set byte start address 0 to 255
        Data_Length = 256      ' set address length of 256 bytes  (0- 255)
        For  SDC_index = 0 to Data_Length -1          ' fill the data buffer  with 0 - 255  values
               SDC_buffer[SDC_index] = SDC_index
        next SDC_index
        pause 100                 ' seems buffer write error if no delay of 50ms or more from the prev erase command
        gosub Flash_Write         ' write test data to sector 0  to datalength
        gosub Buffer_Clear        ' clear the buffer after write
        Flash_RD_Fast = 1         ' set fast read
        gosub flash_read          ' read flash to buffer to datalength
        Flash_Chk_Fail = 1        ' set flag prior to test
        For  SDC_index = 0 to Data_Length-1                 ' check data
             if  SDC_buffer[SDC_index] <> SDC_index then
                 Flash_Chk_Fail = 0  ' if not correct value clear  flag , flag status shown on terminal at startup
               '  HSEROUT2 ["Fail - IDX = ",DEC SDC_index,"  Buffer Data = ", dec SDC_buffer[SDC_index],13,10]  ' DEBUG
        next SDC_index
        gosub Buffer_Clear        ' clear the buffer at end of routine
    ' EXAMPLE 3
    ' READ BLOCK 2 PAGES 0-2 , BYTES 0-255 OF EACH PAGE OUT TO SERIAL PORT MONITOR
    ' SDC_Block = 2         ' SET BLOCK TO READ    0-15 range
    ' Flash_Page_Orgin =0   ' SET Page START LOCATION READ value  0-255 range
    ' Flash_Page_Length = 2 ' SET number of pages TO READ VALUE  0-255 range
    ' Data_Length = 256     ' SET BYTES NUMBER TO READ -  0-256 range  note:
    ' gosub Flash_Test_RD   ' PLACE THE DATA OUT SERIAL PORT
    'return
     'Flash_Test_RD:
     'assumes  SDC_Block, Flash_Page_Orgin,Flash_Page_Length,Data_Length
     'Places seleted read data location out to serial port1
     ' FLASH_Install = 1 ' show status  info for ref
     ' gosub Bsy_chk ' just get the status reg value for ref
     ' for SDC_Page = Flash_Page_Orgin0 to Flash_Page_Length    ' set page range for read
     '   gosub Flash_Read                                        ' read page into buffers
     '   HSEROUT [13,10,"Sector ",dec SDC_Block," PAGE ",dec SDC_Page, 13,10]
     '   For SDC_index = 0 To Data_Length-1
     '     	HSEROUT [",",hex SDC_buffer[SDC_index] ]
     '   next SDC_index
     ' next SDC_Page
    'return
    'Flash_Test_copy:
      ' copys data from 1 sector to another
      ' erases destination sector - optional clean of orginal sector
      ' assumes Flash_Orgin,Flash_clear flag,SDC_Block for destination
      ' erases 1 sector at a time  address
      ' sector erase take 600ms per instruction
    '       Flash_Sec_Orgin =  0 ' sector
    '       Flash_Page_Orgin = 0                   ' start page of orgin
    '       Flash_Page_length = 9 ' how many pages
    '       Flash_Sec_Dest = Flash_Sec_Orgin          ' start at same page value as orgin
    '       Flash_Page_Dest = 20
    '---------- FLASH_MODIFY_BYTE TEST
     '   Data_Length = 10     ' changed data length
     '  For SDC_index = 0 to Data_Length
     '      SDC_buffer[SDC_index] = SDC_index  ' fill the data buffer  with 0 - 255  values
     '   next SDC_index
     '   SDC_Block = 1  ' sector start
     '   SDC_Page = 3    ' page start
     '   SDC_Byte = 16   ' byte star address   ($0f)
     '   gosub Flash_Byte_Modify
     ' Flash_Sec_dest = 1   ' erase sector 1 destination  and copy data from flash orgin
     ' Flash_clear = 1  ' erase sector 0 after copy
     ' gosub Flash_Sec_Copy
     '  SDC_Block = 1
     ' pause 3000
    '  SDC_Block = 1
     ' return
    'Flash_protect_test:
    '  SDC_Block = 0
    '  gosub Flash_WR_protect
    '  gosub Bsy_chk
    '  gosub Flash_Read_ID
    'return
    JumpOverSPIFLASH:
    Thanks for the code.
    Though I found it easier to use the cheap DF Player, using an SD-Card for the files. It is small, stereo and decodes mp3 and wav files. It also includes a power amp to drive speakers or line out to drive external speaker amplifier.
    Using it is dead simple. Either locally by push buttons or serially by a MCU.
    https://wiki.dfrobot.com/DFPlayer_Mi...R0299#target_3
    And here for the cheaper sell https://www.banggood.com/Geekcreit-D...ientCountry=GR
    Feb 2012
    PERTH AUSTRALIA
    for my needs i have several winbond 4mb chips in circuit and they are programmed updated via the pic , with other chips accessing the same flash chips off the bus
    i thought about going sd cards , but for my requirement flash chips were a better option
  1. Spi flash chip example - 8mb flash
    By longpole001 in forum Code Examples
    Last Post: - 1st August 2014, 12:00
  2. Flash erase byte routine
    By longpole001 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2014, 05:36
  3. ISD1700 series Winbond chipcorder
    By rickeybell in forum mel PIC BASIC Pro
    Last Post: - 21st March 2010, 07:13
  4. PBP PIC32 series support?
    By foss in forum mel PIC BASIC Pro
    Last Post: - 18th August 2008, 13:10
  5. Compact flash support,fat16 included...
    By Moldava in forum PBP Wish List
    Last Post: - 11th September 2004, 18:28
