Hersin timeout
Results 1 to 4 of 4
Thread: Hersin timeout
    May 2012
    Merseyside, UK
    Default Hersin timeout
    Hi All
    Am using HERSIN with a timeout... My question is :-
    What is the longest timeout I can use.... As I want to use this to put the device to sleep if no input on RX pin after X mins.
    The manual only states milliseconds so 1000 = 1 second.
    Maybe just try it and see ?
    BR
    Andy
    Default Re: Hersin timeout
    I believe the maximum variable size is 65535.
    EN82fn
    May 2012
    Merseyside, UK
    Hi Dave
    I knew that :-) Honest !
    Thank you.
    Aug 2003
    1 second is a nice even value,
    timeoutperiod var word
    HSERIN [Item... timeoutjump,1000] ; 1 second timeout
    resumeprogram:
    straight after the code that validates the actual input data
    timeoutperiod = 0; // reset sleep timeout
    anywhere in your main loop
    if timeoutperiod > 1199 then ; 20 mins with no valid input
    goto sleeproutine
    way at the end of your program...
    timeoutjump:
    timeoutperiod = timeoutperiod + 1;
    goto resumeprogram
  1. Debugin timeout
    By Alexey in forum Serial
    Last Post: - 10th May 2012, 23:03
  2. Serin2 Timeout
    By tazntex in forum Serial
    Last Post: - 15th August 2008, 15:40
  3. Packets of bytes to HERSIN again
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 19th April 2007, 16:33
  4. Need help with timeout
    Last Post: - 10th June 2006, 15:38
  5. SERIN timeout
    By Roger Harrold in forum General
    Last Post: - 26th November 2003, 21:21
