DT USB Flags
+ Reply to Thread
Results 1 to 5 of 5
Thread: DT USB Flags
    Default DT USB Flags
    How do these flags in DT_HID260.pbp:
    USB_Flags          VAR BYTE BANK0
    Plugged            VAR USB_Flags.0
    RX_Rcvd            VAR USB_Flags.1
    RX_READY           VAR USB_Flags.2
    TX_READY           VAR USB_Flags.3
    RX_ERROR           VAR USB_Flags.4
    TX_ERROR           VAR USB_Flags.5
    "Connect" with these pins in our programs:
    DEFINE USB_PLUGGED     PORTD,1      ; LED indicates if USB is connected
    DEFINE USB_RXrcv       PORTD,2      ;  "      "     data received from PC
    DEFINE USB_RXrdy       PORTD,3      ;  "      "     data being received from PC
    DEFINE USB_TXrdy       PORTD,4      ;  "      "     data being sent to PC
    DEFINE USB_RXerr       PORTD,5      ;  "      "     data error from PC
    DEFINE USB_TXerr       PORTD,6      ;  "      "     data error to PC
    I looked at the datasheet and can't figure out how Port D links up with Bank 0. I'm also puzzled by the syntax PORTD,2.
    Sep 2009
    Default Re: DT USB Flags
    That is ASM syntax.
    DEFINE's are just passed to LST file, after compile.
    There is no direct connection between that two pice of code.
    LED's are turned on/off with macro's in DT_HID260.pbp
    MACROs for LED:
        ifndef  USB_LEDPOLARITY          ; If LED polarity wasn't specified?
    USB_LEDPOLARITY = 1                  ;   default to ON when HIGH
    LEDOFF  macro Port, Bit              ; -- Turn LED OFF --
        if (USB_LEDPOLARITY == 1)        ;   If LED is ON when HIGH?
            LOW?T  Port, Bit             ;     make it LOW
        else                             ;   otherwise
            HIGH?T Port, Bit             ;     make it HIGH
    LEDON  macro Port,Bit                ; -- Turn LED ON --
        else                             ;   otherwise
    ifLEDisON  macro Port,Bit, Label
        if (USB_LEDPOLARITY == 1)        ; if LED is ON when HIGH
            btfsc   Port, Bit            ;   and the pin is LOW
        else                             ; or if LED is ON when LOW
            btfss   Port, Bit            ;   and the pin is HIGH
        endif                            ; then the LED is OFF
        goto      Label                  ;    so don't jump to the label
    ifLEDisOFF  macro Port,Bit, Label
        endif                            ; then the LED is ON
    As you can see from macros, Darrel used HIGH and LOW commands from PBP to handle BANK, TRIS, and output register of port.
    To turn TX LED:
    ;----[Send USB data]--------------------------------------------------------
    DoUSBOut:
            ifdef    USB_TXLED
                LEDON  USB_TXLED
    He call LED macro from DoUSBOut subrutine...
    DoUSBService:
        INTS_FROM = INTS_FROM | UIR
       ifdef USB_ServiceLED
         LEDON  USB_ServiceLED
    etc...
    Argh, I had looked for FLAG in the include.
    And I just noticed I can't rename those as I wish either, ooops.
    Jan 2013
    Texas USA
    "DEFINEs in PBP are converted literally to Assembly Language #DEFINE directives." from the PBP manual.
    The "DEFINE USB_RXrcv POTRD,2" in PBP is converted to "#DEFINE USB_RXrcv PORTD,2"
    An Assembly "#Define" in this case is just a text substitution.
    In the Assembly code, wherever "USB_RXrcv" is, it is substituted (replaced) with "PORTD,2"
    TABSoft
    Thank you, that's what I thought from Pedja's post.
  1. USB to USB flash Drive File Copier
    By surya089 in forum USB
    Last Post: - 16th December 2012, 02:22
  2. USB to USB flash Drive File Copier
    By emildownloads in forum General
    Last Post: - 27th October 2011, 02:23
  3. LCD issue - what does FLAGS = 0 really do?
    Last Post: - 27th February 2008, 06:26
  4. set flags within a variable?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 24th October 2006, 12:07
  5. trouble with FLAGs
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 10th November 2004, 03:26
