Again ADC with 12F675 ...
Results 1 to 30 of 30
    Dec 2008
    Ploiesti, ROMANIA
    Default Again ADC with 12F675 ...
    Hi !
    I wote this code for 12F675:
    @ __config _XT_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _BODEN_OFF & _CP_ON
    DEFINE OSC  4
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    CMCON = 7
    OPTION_REG  = %10000110
    TRISIO      = %00001100
    GPIO        = %00000001
    ANSEL       = %00010100
    ADCON0      = %10001001
    In ISIS I have multiple errors ... what did I do wrong ?
    Default Re: Again ADC with 12F675 ...
    Is that really ALL of the code?
    When you select an analog input which you want to convert the sample and hold circuit for the ADC needs to charge the S/H capacitor. It takes a certain amount of time (called acquisition time) for this capacitor to charge up. When the the A to D conversion starts the capacitor is disconnected from the input. If the A to D conversion is started before the acquisition time has expired the conversion result will not be correct.
    I'm not sure if perhaps ISIS can, based on the simulation, figure out that the acquisition time isn't long enough. I've never used ISIS (haven't been able to justify the cost) so I don't know.... From the time stamp it looks like you're doing a A to D conversion in a quite tight loop, I don't know if that's a possible problem. It think you're going to have to post more of the code.
    Finally, it's not an error, it's message telling you that it has happend. It doesn't prevent the code form compiling or from running but the behaviour of the code, as written, might not be what you actually wanted.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You so much for reply !
    The rest of code is :
    pause 200
     ADCON0.1 = 1
     WHILE ADCON0.1 = 1 : WEND
     adval.HighByte = ADRESH
     adval.LowByte = ADRESL
     if k=0 and adval > 10 and adval < 750 then
     k=1
     pause 250
     while k=1
     gosub start
     wend
    start:
     ADCON0.1 = 1
    if adval > 10  AND adval < 103 then gosub VolDn
    Is it? You're calling VolDn but I don't see that in the code but I guess there's nothing to do with the ADC there?
    Anyway, have you tried using ADCIN just to see if the message from ISIS goes away then?
    I'm asking beacuse the DEFINE ADC_SAMPLUS 50 is for use with the ADCIN command I don't think it does anything for you when you run the ADC "manually". Alternativaly, whenever you're doing a converstion try:
    ADCON0 = %10001001    ' Right justify, VRef=Vdd, select AN2, enable ADC.
    PAUSEUS 100
    ADCON0.1 = 1          ' Start conversion
    In this case I don't think anything of it really matters since you're always sampling the same channel but it might be worth a try just to see if ISIS stops generating the message.
    Finally, you're doing DEFINE ADC_CLOCK 3 but then you're overriding that by manually setting ANSEL to %00010100 which will set the ADC Clock to FOsc/8 instead of FRC. I don't think that's a problem in this case though.
    Dec 2008
    Ploiesti, ROMANIA
    Thank you verry much !
    Indeed, my mistake was the overriding of defines ...I didn't know until today the things You've posted. Hm ... so much to learn ! I'm glad I met people like You and other kindly members of this forum !
    Best regards !
    Dec 2008
    Ploiesti, ROMANIA
    Me, again ...with something strange (at least for me) !
    I try to use ADC for reading a couple of buttons. I have two situations :
    - three buttons, with 82 ohms, 164 ohms, 1448 ohms resistors ; ADC reading = 1023 nothing pressed ; 78 with button 1 pressed ; 144 with button 2 ; 605 with button 3 ;
    - three buttons, with 300 ohms, 1300 ohms, 3110 ohms AND 100 Kohms in parallel ; ADC reading = 1013 nothing pressed ; 236 with button 1 pressed; 575 with button 2 ; 768 with button 3.
    I tried with 2 version of code (for both situations):
     ADCON0.1 = 1
    if adval > 10  and adval < 300 then  gosub LED1
    ...etc....
    and
    ADCIN 3, adval
    ...etc...
    For first situation everything works fine, with both version of reading ADC !
    BUT ... for second situation, NOTHING HAPPENS !!! I really not understand what I do wrong ... Can me point to the right direction ? Thanks in advance !
Size:  98.3 KB Name:  not_working.jpg
    Dec 2008
    Ploiesti, ROMANIA
    Note : In Proteus both schematic work, so I made it on PCB. First variant works just fine, second none ...
    For the code using ADCIN, is the left/right justification set correctly? I can never remember which way around it wants it so whatever you have it set to, try changing it. And, do you have DEFINE ADCBITS 10 in there?
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    CMCON = 7
    TRISIO      = %00001100
    GPIO        = %00000001
    ANSEL       = %00010100
    ADCON0      = %10001001
    I don't change anything in code (except values for actions) ... just the resistors from "chain" command.
    With first chain work ; with second not. It's because of 100 kOhms ?!?
    may be we could suspect the debounce time for your switches ... 50 µs is rather a short time !
    did you try to use a little pause for settling ???
    Dec 2008
    Ploiesti, ROMANIA
    Thank you !
    That means to add something like "Pause 50" before or after ADCIN command ?
    Here you can find an example ( in assembler ... YES ! ) that shows how it is done.
    http://www.piclist.com/techref/micro...x4key1ad7r.htm
    did you also read that one ???
    http://www.picbasic.co.uk/forum/showthread.php?t=17956
    Dec 2008
    Ploiesti, ROMANIA
    Thanks ! But still no have answers on my problem ...
    Dec 2007
    Finland
    Hi Fratello,
    1) Do you have two PCB with different resistor values?
    or
    2) Have you changed resistors to same board and tested with two SW settings?
    In case
    1) there must be some other differences on PCB
    2) resistors are not with correct values
    Dec 2008
    Ploiesti, ROMANIA
    Thanks, Mr. Gusse, for support !
    I have only one PCB, without the resistors from chain (just R2=1k is soldered on PCB, between +5V and ADC_IN).
    I put the resistors from chain 1 from R2/ADC_IN to ground ; in first case works perfect.
    Then I soldered the R9=100k from R2/ADC_IN to ground ; I put resistors from chain 2 into circuit (in parallel with R9). In this case nothing happens.
    All the resistors are measured, look to be OK (this was my first concern too ...).
    Tomorrow I'm going to try to set some debounce ...
    Dec 2008
    Ploiesti, ROMANIA
    Update picture...
    Dec 2008
    Ploiesti, ROMANIA
    SOLVED !!!
    In first case the code is :
    "If adval > 419 and adval < 536 then gosub LED" = working fine.
    In second case :
    "If adval > 450 and adval < 600 then gosub LED" = NOT working.
    So I tried this :
    "If adval < 600 and adval > 450 then gosub LED"
    And VOILA, IT'S WORKING !!!
    Thanks for support ! Regards !
    I don't get it. That looks identical to me.
    Dec 2008
    Ploiesti, ROMANIA
    For me too ... But I can prove it (by video) !
    Maybe because when no button is pressed, ADC reading is NOT 1023 ?!
    Jan 2013
    Texas USA
    I do not know what version of PICBasic you are using or what version of MPASM either.
    I compiled and ran the following code in the MPASM Simulator and it works fine for all (3) IF/THEN statements in main.
    If adval <= 419 then myLED does not increment.
    If adval > 419 and <= 450 then myLED only increments 1 time for each loop (IF/THEN #1 : Not #2 and #3)
    if adval > 450 and < 536, then myLED increments 3 times for each loop (IF/THEN #1, #2 and #3)
    if adval => 536 and < 600 then myLED increments 2 times for each loop (IF/THEN #2 and #3 : Not #1)
    if adval => 600 then myLED does not increment.
    'MCU = 12F675
    'PBP v3.0.7.4
    'MPASM v8.90
    DEFINE OSC  4
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    CMCON = 7
    TRISIO      = %00001100
    GPIO        = %00000001
    ANSEL       = %00010100
    ADCON0      = %10001001
    adval var word
    myLED var word
    adval = 0
    myLed = 0
    LED:
        myLED = myLEd + 1
        for adval = 0 to 700
            If adval > 419 and adval < 536 then gosub LED   'Works
            If adval > 450 and adval < 600 then gosub LED   'Works
            If adval < 600 and adval > 450 then gosub LED   'Works
        next
    	myLed = 0
    TABSoft
    Dec 2008
    Ploiesti, ROMANIA
    Thanks !
    In Proteus my code work fine too ... But not work in "real life".
    Tomorrow I will come with another issue ...
    Dec 2008
    Ploiesti, ROMANIA
    ...so I'm back !
    After solving first problem, I meet another one ... I can not reading two channel ADC.
    I try two version of code :
    -first variant
    @ __config _XT_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _BODEN_ON & _CP_ON
    DEFINE OSC  4
    CMCON       = 7
    OPTION_REG.7= 1
    TRISIO      = %00001110
    GPIO        = %00000001
    ANSEL       = %00110110
    ADCON0.7    = 1
    adval  var word
    advalb var word
    PAUSE 200
     ADCON0.2 = 1
     ADCON0.3 = 0
     ADCON0.1 = 1
     PAUSE 50
    if adval < 950 then
    	if adval < 940 AND adval > 650 THEN gosub Led1
    	IF adval < 600 AND adval > 450 THEN gosub Led2
    	IF adval < 400 AND adval > 150 THEN gosub Led3
    	IF adval < 100 THEN gosub Led4
     ADCON0.2 = 0
     ADCON0.3 = 1
     ADCON0.1 = 1
     PAUSE 50
    if advalb < 950 then
    	if advalb < 940 AND advalb > 650 THEN gosub Led1
    	IF advalb < 600 AND advalb > 450 THEN gosub Led2
    	IF advalb < 400 AND advalb > 150 THEN gosub Led3
    	IF advalb < 100 THEN gosub Led4
    -second variant
    DEFINE OSC  4
    DEFINE ADC_BITS     10
    DEFINE ADC_CLOCK    3
    DEFINE ADC_SAMPLEUS 200
    CMCON = 7
    TRISIO      = %00000110
    GPIO        = %00000110
    ANSEL = %00000110
    ADCON0.7    = 1
    ADVALA  VAR WORD
    ADVALB  VAR WORD
    pAUSE 100
    adcin 1, advalA
    pause 5
    if advalA < 950 then
    	if advaLA < 940 AND advalA > 650 THEN gosub LED1
    	IF advalA < 600 AND advalA > 450 THEN gosub LED2
    	IF advalA < 400 AND advalA > 150 THEN gosub LED3
    	IF advalA < 100 THEN gosub LED4
    adcin 2, advalB
    pause 5
    if advalB < 950 then
     	if advalB < 940 AND advalB > 655 THEN gosub LED1
    	IF advalB < 600 AND advalB > 450 THEN gosub LED2
    	IF advalB < 400 AND advalB > 150 THEN gosub LED3
    	IF advalB < 100 THEN gosub LED4
    ONLY "advalA < 100" is sensing and LED4 command is executed ...
    Can somebody pointing to the right direction ? Thanks in advance !
    Schematic added.
    Jan 2013
    Texas USA
    A couple of suggestions second variant.
    Remove "GPIO = %00000110" you are trying to set a high on the input pins.
    Change "ANSEL = %00000110" to "%01110110", this will set the PIC ADC clock to RC mode and will match the
    "DEFINE ADC_CLOCK 3" directive.
    Then give Variant 2 a try.
    TABSoft
    Dec 2008
    Ploiesti, ROMANIA
    I will try this, thanks !
    Hi Fratello. A while back I did the same basic thing you're doing. On an ADC pin I attached a 47K pullup resistor. Then a 22K resistor with pushbutton to ground, 10K with button to ground, 2.2K with button to ground and a 1K with button to ground. Here is the code. It works perfect for me.
    ANSEL = 0 'all inputs digital
    CMCON = 7 'comparators off
    DEFINE OSCCAL_1K 1 ' Set OSCCAL for 1K device to accurize osc
    TRISIO = %11111111 'SET I/O'S to all inputs for now
    @ device pic12F675, INTRC_OSC_NOCLKOUT, wdt_on, BOD_ON,pwrt_on, mclr_off, protect_on
    BUT VAR BYTE 'BUTTON VARIABLE
    BUT2 VAR BYTE 'VARIABLE TO COMPARE READINGS TO PREVENT WRONG ADC READINGS
    Pause 500 'SETTLE DOWN
    STAYHERE:
    ADCIN 3,BUT 'ADCIN COMMAND AUTOMATICALLY CONVERTS I/O TO ADC PORT
    IF BUT < 100 Then STAYHERE 'IF BUTTON STUCK on power up WAIT HERE
    BEGIN:
    NAP 0 'REDUCE BATTERY DRAIN
    ADCIN 3,BUT
    IF BUT > 100 Then begin 'BUTTON not PUSHED
    table:
    ADCIN 3,BUT
    Pause 100
    ADCIN 3,BUT2
    IF BUT <> BUT2 Then TABLE 'RE-READ ADC should both be same
    IF BUT < 91 AND BUT > 71 Then (DO FUNCTION 1)
    IF BUT < 50 AND BUT > 40 Then (DO FUNCTION 2)
    IF BUT < 15 AND BUT > 8 Then (DO FUNCTION 3)
    IF BUT < 8 AND BUT > 4 Then (DO FUNCTION 4)
    IF BUT < 5 AND BUT > 2 Then (DO FUNCTION 5) '1K & 2.2K BUTTON PUSHED @ SAME TIME
    GOTO BEGIN
    Dec 2008
    Ploiesti, ROMANIA
    Thank you !
    As I say, with just one resistors chain , everything works PERFECT !
    My troubles appears when I try to use TWO resistors chains (and TWO ADC channel).
    I wrote another version :
    DEFINE OSC  4
    DEFINE ADC_BITS     10
    DEFINE ADC_CLOCK    3
    DEFINE ADC_SAMPLEUS 100
    CMCON = 7
    OPTION_REG.7= 1
    TRISIO      = %00000110
    GPIO        = %00000001
    ANSEL       = %00110110
    ADCON0.7    = 1
    adval   var word
    valb    var word
    vala    var word
    PAUSE 200
    goto mainloop
    getadv:
            PAUSEuS 50                      	' Wait for A/D channel acquisition time
            ADCON0.1 = 1
    getadvala:
            ADCON0 = %10000101
            Gosub getadv
            vala=adval
    getadvalb:
            ADCON0 = %10001001
            Gosub getadv
            valb=adval
    mainloop:
    gosub getadvala
    gosub getadvalb
    if vala < 950 then
    	if vala < 940 AND vala > 650 THEN gosub LED1
    	IF vala < 600 AND vala > 450 THEN gosub LED2
    	IF vala < 400 AND vala > 150 THEN gosub LED3
    	IF vala < 100 THEN gosub LED4
    if valb < 950 then
    	if valb < 940 AND valb > 650 THEN gosub LED1
    	IF valb < 600 AND valb > 450 THEN gosub LED2
    	IF valb < 400 AND valb > 150 THEN gosub LED3
    	IF valb < 100 THEN gosub LED4
    goto mainloop
    But still no have proper results ...
    Dec 2008
    Ploiesti, ROMANIA
    My schematic/code are from here : http://www.imdb.com/title/tt0052520/ !!!
    I did it work ... by re-reversing all those commands :
    " If VALA > 650 and VALA < 940 Then Gosub LED1"" ...
    instead of :
    " If VALA < 940 and VALA > 650 Then Gosub LED1"
    Nothing else ! And now everything works just fine !
    Thank you all for support !
    Have a Nice and Happy Easter !
    May 2009
    I think you may wat to try the following: if (vala >650) and (vala <920) then go sub xx
    SWITZERLAND (french speaking)
    In your very first post, I couldn't find any clear description of your problem or goal....
    Quote Originally Posted by fratello View Post
    Resistor coupling is apparently not the same in those two posts - is this okay?
    Try this:
    Button 1 = 0 Volt => ADC 8 bits = +/-0 , ADC 10 bits = +/-0
    Button 2 = 1,25 Volts => ADC 8 bits = +/-64 , ADC 10 bits = +/-320
    Button 3 = 2,5 Volts => ADC 8 bits = +/-128 , ADC 10 bits = +/-640
    Button 4 = 3,75 Volts => ADC 8 bits = +/-192 , ADC 10 bits = +/-960
    I didn't built the circuit above; if ADC values are not stable, try with all R values ( :10) => 10k becomes 1k, 3k3 becomes 300Ohms and so on.
    As an alternative, you may want to have a look here "Compiled Tips ‘N Tricks Guide".Name:  RC ramp.jpg
    Roger
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for info !
  1. ADC values above 4095 for 12 bit ADC
    By longpole001 in forum mel PIC BASIC Pro
    Last Post: - 1st February 2015, 22:24
  2. ADC problem on 18F46K22 device using all 28 ADC pins
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2012, 20:22
  3. 12f675
    By mystified in forum mel PIC BASIC
    Last Post: - 10th September 2007, 02:47
  4. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 01:55
  5. ADC on 12f675?
    By peu in forum mel PIC BASIC Pro
    Last Post: - 16th March 2005, 17:44
