A bit of point to point goodness :)
Results 1 to 9 of 9
    Aug 2003
    Default A bit of point to point goodness :)
    Hi Guys,
    I just spent a harrowing two days building and test software for a joystick recorder/player to cheat at games
    Some advice interfacing to the computer would be appreciated.
    The retro joysticks are just switches that ground the respective pins,
    but I think a device like this would typically have some buffering for the outputs rather than a pic sinking directly.
    Transistors. logic, bilateral switches?
    This is the I2C bus addressing done:
    It works!
    Cheers, Art.
    Aug 2003
    Default Re: A bit of point to point goodness :)
    Display board:
    Aug 2003
    Now we’re getting somewhere a greater than 7 hour player/recorder at 0.1 second sample resolution.
    There is more physical EEPROM that I’m using yet also, so I think I can sample much faster.
    I was surprised that at 20MHz, DT’s Elapsed time (real timer overflow interrupt) and I2C read/write works fine together.
    I have a flag watching for I2C error, and it’s not displaying unless I sabotage the hardware.
    LOL
    You just built the thingy that I warned a game dev about. I told them users can now "relatively" easily access devices to cheat in the time trial mode; racing alone on the race track.
    Saving wheel and pedal settings just takes a bit more space, but essentially it's the same thing.
    Cool device. I was wondering why you needed so much external memory.
    Aug 2003
    I still do have to save coin 1 and player 1 buttons. If the bot doesn’t start the game itself it won’t be synced to the game.
    The current program is saving a byte ten times per second, and provides a little over 7 hours recording,
    but I would like to improve that resolution to 100 times per second, which will require a few more chips.
    What if you use another medium; SD card would be perfect.
    How about using a sort of sample compression?
    Instead of storing the state at a fixed interval have a 24bit 10, 50 or 100Hz tick counter running. Whenever something changes state you store the counter value and the state.
    If the state is 16 bits each record will be 5 bytes total.
    Even at 100Hz resolution the 24bit tick counter allows for close to two days of recording before overflowing.
    Nice proto build!
    Aug 2003
    I did think of both ways, either time stamp and data, or continuous data.
    I suppose I like the idea of a memory timer as well though
    SD card I remember reading it’s easy to access byte by byte raw mode, but I never looked into it.
    yes I probably could have gone nuts, and these EEPROMs are samples,
    but if you buy them they aren’t cheap considering what you pay per byte.
    Aug 2003
    ...and done
  1. Replies: 10
    Last Post: - 8th March 2015, 19:26
  2. Using floating point
    By andywpg in forum mel PIC BASIC Pro
    Last Post: - 25th February 2015, 06:10
  3. pic16f88, xbee's & point-2-point comms
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2009, 08:43
  4. Getting out of floating point
    By jcb344 in forum General
    Last Post: - 5th August 2008, 21:18
  5. help floating Point!
    By Eric in forum mel PIC BASIC Pro
    Last Post: - 7th December 2003, 21:18
