18f14k22 portb.5 always high using hserout
Results 1 to 5 of 5
    Question 18f14k22 portb.5 always high using hserout
    Oops - - Should be 18f14k22
    Hi
    I cannot figure out why, when using HSEROUT, on PORTB.7, PORTB.5 is high
    no matter what I try.
    Making PORTB = 0 on the first line has no effect either
    Actually, when bit 5 on TRISB is set to an input, the port is not
    always high then - - that makes sense. Problem is, I need it as an output.
    I need to use HSEROUT for my Serial LCD, since I am using interrupts,
    and the data is corrupted otherwise.
    I am using PBP 2.60A
    The manual states on page 93 that "On devices with two serial ports,
    HSEROUT will only use the first port."
    My circuit board is etched, assembled, and everything works, but I need
    to use PORTB.5 as another output.
    Here is a simple program to show the problem. When the HSEROUT line
    is enabled, PORTB.5 is always high.
    If the HSEROUT line is commented out, PORTB.5 works just fine.
               DEFINE OSC 16
               OSCCON = %11110110  ' 16 MHZ INTERNAL OSCILLATOR
               TRISB = %00000000
               DEFINE HSER_BAUD 9600      ' FOR 4 LINE BY 20 CHARACTER LCD
    '                                      USES PORTB.7 - - DEDICATED HARDWARE SERIAL PORT
             DEFINE HSER_TXSTA 20H
               HERE:
               PAUSE    100
               HSEROUT  [254,128,"TEST TEST"]
               GOTO HERE
               ''''''''''Cant get much simpler than this . . . .
    Default Re: 18f14k22 portb.5 always high using hserout
    There are threads in this forum which have addressed this, worth a search, that said HSERIN idles the input pin at high logic level. To switch it to an i/o port you need to turn it off before you try to use it. Look at pp184 of the data sheet as it addresses RCSTA register.
    push goes to shove you might use Debug instead of HSER commands, it's pretty lean for bit bang serial port.
    When you enable the (E)USART (which HSERIN does of course) it takes control of the TX/RX pins, thus you can't use the as normal I/O.
    I found a "work-around" for this - I needed one output to pulse an LED as a "heart-beat", so I changed that to PORTB.5.
    In the program I change TRISB.5 from a 0 to 1 and back to a 0 to flash the LED. Therefore freed up the other output. From what I see it has no other effect on the program.
    Ken
    Another approach is to enable/disable the hardware port in your program. For the 16f1826 I use RCSTA.7 = 0 to disable the port when I'm done using it.
  1. Problem reading 24FC1025 EEPROM with 18f14k22
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 31st May 2013, 19:55
  2. High byte lost in HSEROUT a Word variable
    By Demon in forum General
    Last Post: - 7th October 2012, 21:30
  3. Replies: 6
    Last Post: - 12th March 2011, 13:11
  4. PortB pins will not initialize LOW, only HIGH?
    By ronbowalker in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 19:27
  5. 18F14k22 eTouch
    By warrier in forum mel PIC BASIC Pro
    Last Post: - 28th July 2009, 05:20
