Input problems with 12F629?
+ Reply to Thread
Results 1 to 14 of 14
    achilles03's Avatar
    achilles03 Guest
    Default Input problems with 12F629?
    I'm relatively new to PBP, and am still in the learning stages. I'm using a 12F629 to control a servo based on two inputs via pins 1 and 2. Pin 0 is the output pin. For some reason, the 12F629 doesn't recognize any inputs on pins 1 and 2. I've checked to make sure there's no port/pin type conflicts, but I'm sure I'm missing something. Does anyone know what I'm missing?
    Thanks in advance,
    (see program below)
    i VAR BYTE
    output 0
    input 1
    input 2
    Define OSCCAL_1K 1
    low 0
    loop:
    if GPIO.1=1 then turn1
    if GPIO.2=1 then turn2
    goto loop
    turn1:
    for i=0 to 5
    pulsout 0, 147
    pause 20
    next i
    goto loop
    turn2:
    for i=0 to 5
    pulsout 0, 152
    pause 20
    next i
    goto loop
    Default CMCON... Again :o)
    What about
    Define OSCCAL_1K 1
    CMCON=7 ' disable analog comparator
    TRISIO=%11111110 ' set GPIO as output
                     ' others as input
    i VAR BYTE
    low 0
    loop:
        goto loop
    turn1:
        for i=0 to 5
            pulsout 0, 147
            pause 20
            next i
        goto loop
    turn2:
        for i=0 to 5
            pulsout 0, 152
            pause 20
            next i
        goto loop
    Also, make sure you set MCLR pin to +5V OR you disable it at programming time.
    Same for internal OSC.
    Default Re: Input problems with 12F629?
    hi there
    can you tell me from where you got the syntax " PAUSE ..." in your pgm !
    I am using C language and dont know such a syntax
    Sep 2010
    Las Vegas, NV
    Loop is one of those reserved words in PBP3 and I'm pretty sure in earlier versions. It really fouls things up.
    If your inputs and outputs are either high or low you want to set all your pins to digital with analog select register. i.e ansel=0. Otherwise the pins get sensed in the middle and often never toggle.
    if you want gpio.0 to be low then I think you need low gpio.0 not just low 0.
    I've never used PULSOUT before but I'm certain you need to spell out gpio.0 and not just 0
    Most people recommend a CLEAR at beginning and a END at end.
    I'd also recommend you turn on capitalization of commands in PBP. It helps me recognize some of the reserved words and commands.
    If you'll post schematic I'll run it on simulator if you like.
    clear
    Define OSCCAL_1K 1
    ansel=0
    TRISIO=111110 ' set GPIO as output
                     ' others as input
    i VAR BYTE
    ' commented out low 0
    low gpio.0
    ' commented outloop:
    '  commented out   goto loop
    turn1:
        for i=0 to 5
    ' comment out        pulsout 0, 147
    pulsout gpio.0, 147
            pause 20
            next i
    turn2:
        for i=0 to 5
    ' comment out        pulsout 0, 152
    pulsout gpio.0, 152
            pause 20
            next i
    'commented out    goto loop
    Default Re:syntax for loop delay with 12F629?
    thanks avionics master.
    Default Re: syntax for loop delay with 12F629?
    This one should work ... ( ISIS tells so ... )
    '*  Name    : SERVOTEST0                                        *
    '*  Notice  : Copyright (c) 2013 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 10/02/2013                                        *
    '*  Notes   : 12F629 @4 Mhz internal                            *
       __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _CP_OFF & _MCLRE_OFF
    Servo   var GPIO.0
    Right   var GPIO.1
    Left    var GPIO.2
    Define OSCCAL_1K 1
    CMCON   =7 ' disable analog comparator
    ' ansel=0  NO ANSEL with the '629 !!!...
    TRISIO  = %11111110 ' set GPIO as output
                     ' others as input
    i VAR BYTE
    clear
    low Servo
    while 1
        IF Right THEN
            pulsout Servo, 147
        ELSEIF Left THEN
            PULSOUT Servo, 152
            PULSOUT Servo, 150  ' Center/stop ( ? ) if no button pushed ...
        Pause 19
    WEND
    Dec 2012
    Tennessee
    you can use Loop in PBP 2.6 and lower, but I agree it should have been a reserved word back then.
    I've see some samples of code online that use it. Those sites will need to update their code when 3.0 becomes the standard
    Sep 2010
    Las Vegas, NV
    Just sayin' according to page 19 of http://ww1.microchip.com/downloads/e...doc/41190c.pdf you need to configure ansel and cmcon to get digital ports. Page 44 tells you how to set up the ANSEL register.
    Shouldn't the clear be the first line of the program?
    I'd also add a goto main after the WEND or it will only do the movement once.
    Just curious, why pause 19? Is that the minimum time for all the stuff to settle out?
    May 2009
    ANSEL and CMCON are only required for a 12f675 that has analog input capability. A12f629 does not have analog inputs so these commands are not required for the 12f629.
    The clear command is not required and the variable "I" is also not needed as there are no for/ next loops in the program. A While 1 / wend forms a continuous forever loop so the goto command after the wend is not required. The pause 19 is in the loop so that the pulses are send every 19 milliseconds which is the repeat rate required by the servo decoder.
    Hi, Graham
    Good !
    1) I wanted to wipe line about " I var " ... but timeout for editing post caught me !!! - seriously - that doesn't change anything to the produced Hex , as it's just a compiler directive ...
    2) I also wanted to add
    LOW Servo
    just before each PULSOUT Command ... BTW ... could you tell us why ?
    to understand the "why" ... just plug and unplug the servo plug for 5 or 6 times in a row ... with power ON
    and 3) ... CLEAR might much better be after declaring the variables ... no ???
    and ... 4) BINARY numbers must be written %01010101 ... for
    TRISIO =
    Everything told now !
    Sep 2010
    Las Vegas, NV
    Thanks for straightening me out. You learn something new every day.
    Mar 2008
    I have read this thread several times and looked at the datasheet several time as well. I am having problems with code that has worked fine in the past and suddenly I can not make GPIO.0 and GPIO.3 function as inputs. This is the code I have used in the past. I have added a TRISIO statement and this does not seem to help either. “TRISIO = %11001011”
    This code works on GPIO.1 but not on GPIO.0 and GPIO.3. I have used three ICs and continue to have no luck?
    #IF __PROCESSOR__ = "12F629"
    #DEFINE MCU_FOUND 1
    cfg = _INTRC_OSC_NOCLKOUT ; INTOSC oscillator: I/O function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN
    cfg&= _WDT_ON ; WDT enabled
    cfg&= _PWRTE_OFF ; PWRT disabled
    cfg&= _MCLRE_OFF ; GP3/MCLR pin function is digital I/O, MCLR internally tied to VDD
    cfg&= _BODEN_ON ; BOD enabled
    cfg&= _CP_ON ; Program Memory code protection is enabled
    cfg&= _CPD_OFF ; Data memory code protection is disabled
    __CONFIG cfg
    #ENDIF
    #IFNDEF MCU_FOUND
    #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    CMCON = 7
    SYMBOL LTIN = GPIO.0 'input
    SYMBOL RTIN = GPIO.1 'input
    SYMBOL LTOUT = GPIO.2 'output
    SYMBOL FOURIN = GPIO.3 'input
    SYMBOL RTOUT = GPIO.4 'output
    SYMBOL PEIZO = GPIO.5 'output
    Over:
    IF LTIN = 1 THEN HIGH PEIZO
    IF LTIN = 0 THEN LOW PEIZO
    IF RTIN = 1 THEN HIGH PEIZO
    IF RTIN = 0 THEN LOW PEIZO
    IF FOURIN = 1 THEN HIGH PEIZO
    IF FOURIN = 0 THEN LOW PEIZO
    GOTO OVER
    Dec 2008
    Ploiesti, ROMANIA
    See this post : http://www.picbasic.co.uk/forum/show...=7072#post7072
    Maybe is useful !
    Mar 2008
    I just found my problem. It was these two lines
    I had changed my board on the last run and forgot to change the pin numbers in the code. The input was working fine it was the output the whole time.My silly mistake
    SYMBOL RTOUT = GPIO.5
    SYMBOL PEIZO = GPIO.4
    I am back up and running thank You for your reply!
  1. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  2. Input problems
    By ALFRED in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2006, 21:02
  3. Using GPIO.3 as input on 12F629
    By Sharky in forum mel PIC BASIC Pro
    Last Post: - 5th May 2006, 19:41
  4. Input on 12F629
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 16th March 2005, 11:14
  5. 12F629 I2C problems
    By AIW128ProGuy in forum mel PIC BASIC Pro
    Last Post: - 11th November 2004, 23:41
Members who have read this thread : 20
