Lcdout multiple variables issue
Results 1 to 6 of 6
    Nov 2014
    Default Lcdout multiple variables issue
    Having a problem with the LCDOUT Command on a PIC18F46K22 at 16MHz with a Vishay 4x20 LCD Display.
    If I use LCDOUT this way:
    LINE1 = $80
    LCDOUT $FE, LINE1, "01234567890123456789"
    It will work every time flawlessly.
    But if I use:
    LINE1 = $80
    X1 = 10
    X2 = 11
    X3 = 12
    X4 = 13
    X5 = 14
    LCDOUT $FE, LINE1, #X1, " ", #X2, " ", #X3, " ", #X4, " ", #X5
    The display will show
    10 11 12 garbage.....
    If I do this:
    LINE1 = $80
    X1 = 10
    X2 = 11
    X3 = 12
    X4 = 13
    X5 = 14
    LINE1 = LINE1 + 9
    GOSUB DELAY30    '30 msec delay
    LCDOUT $FE, LINE1, #X4, " ", #X5
    then everything is correct
    10 12 13 14 15
    I tried changing these parameters to no avail
    DEFINE LCD_COMMANDUS 1500 ; Set command delay time in us
    DEFINE LCD_DATAUS 44 ; Set data delay time in us
    Any suggestions?
    Jan 2013
    Texas USA
    Default Re: Lcdout multiple variables issue
    If you are trying to display the variable value as decimal, then try using this.
    [CODE]
    LINE1 = $80
    X1 = 10
    X2 = 11
    X3 = 12
    X4 = 13
    X5 = 14
    LCDOUT $FE, LINE1, Dec X1, " ", Dec X2, " ", Dec X3, " ", Dec X4, " ", Dec X5
    TABSoft
    Apr 2011
    Welches, Oregon
    This, from the manual: "If a pound sign (#) precedes an Item, the ASCII representation for each digit is sent to the LCD. LCDOUT (on all devices except 12-bit core)"
    Jan 2013
    Texas USA
    I use PBP v3 and the DEC output modifier with no issues.
    TABSoft
    Nov 2014
    Thank you all for the replies but
    also works exactly the same.
    The display will show 10 11 12 garbage.....
    I need to have a slight delay.
    Whether I use #X1 or DEC X1 the output is the same.
    I think I'll try creating a 20 byte array then output the array and see what happens
    Nov 2014
    OK here is what I did to solve my issue....
    LCDARRAY VAR BYTE[20]
    LCD VAR BYTE
    LCDHI VAR BYTE
    LCDLO VAR BYTE
    GOSUB CLEARLCDARRAY
    LCD = X1 : GOSUB VALUE2STRING
    LCDARRAY(0) = LCDHI : LCDARRAY(1) = LCDLO
    LCD = X2 : GOSUB VALUE2STRING
    LCDARRAY(3) = LCDHI : LCDARRAY(4) = LCDLO
    LCD = X3 : GOSUB VALUE2STRING
    LCDARRAY(6) = LCDHI : LCDARRAY(7) = LCDLO
    LCD = X4 : GOSUB VALUE2STRING
    LCDARRAY(9) = LCDHI : LCDARRAY(10) = LCDLO
    LCD = X5 : GOSUB VALUE2STRING
    LCDARRAY(12) = LCDHI : LCDARRAY(13) = LCDLO
    LCDOUT $FE, LINE4, STR LCDARRAY{\20}
    'take the value in LCD and convert it to a 2-character string in LCDHI and LCDLO (ONLY FOR 0 - 99)
    VALUE2STRING:
    LCDHI = 0
    WHILE LCD >= 10
    LCDHI = LCDHI + 1
    LCD = LCD - 10
    WEND
    LCDHI = LCDHI + $30
    LCDLO = LCD + $30
    CLEARLCDARRAY:
    FOR LCDCTR = 0 TO 19
    LCDARRAY(LCDCTR) = " "
    NEXT LCDCTR
    Last edited by MarkEngineer; - 23rd February 2015 at 14:52. Reason: correct variables
  1. DT Multiple Software PWM and 18F2321 issue
    By microuser in forum mel PIC BASIC Pro
    Last Post: - 20th December 2012, 08:23
  2. Reading/writing arrays from eeprom to variables to lcdout
    By DDDvvv in forum mel PIC BASIC Pro
    Last Post: - 29th August 2010, 18:51
  3. External Eeprom - trying to store multiple variables
    By bluesmoke in forum mel PIC BASIC Pro
    Last Post: - 6th April 2010, 02:07
  4. Multiple Variables - Pins
    By GatorGuy in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 01:08
  5. LCDOUT variables?
    By RUBiksCUbe in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2005, 01:25
