500 Year Calendar for DT Elapsed Timer
Results 1 to 9 of 9
    Aug 2003
    Default 500 Year Calendar for DT Elapsed Timer
    Hi Guys,
    Here’s my 500 year calendar that can be used with Darrel Taylor’s Elapsed Timer routines (when used as a clock).
    There’s a video demonstration coming up shortly
    This can save you a RTC/Calendar Chip such as Maxim/Dallas 1307/1302 when you are already using the clock routine.
    The DS1307 is only accurate to the year 2100, where I have checked accuracy against iOS in the range 1800-2300.
    Usage:
    Set your variables calday, calmonth, calyear with the input numbers and call setcal subroutine.
    If the date made sense, and the year was within range 1800-2300 the flag calbadentry will be zero.
    If the year was out of range or you used a number that was too high for day or months (i.e. entered 29th of Feb when it was not a leap year),
    the number for day or month will be set to 1, and the value for calbadentry will be 1
    for your program to throw an error.
    If the year is out of range it gets adjusted back to the upper or lower limit.
    The variable caldow will contain the day of the week where zero is Sunday through to 6 for Saturday.
    From there you can just check the value of DayChanged with he provided code waiting for the day to change,
    and the program routine will increment the date and weekday each day.
    The lookup table epochyears contains 12 years that begin on a Monday to make the calendar faster.
    The calendar routine only has to iterate from the closest year before the current year the user input.
    During testing the weekday and leap year routines were tested against the stock iPhone calendar App.
    Implementation:
    In the Elasped.bas file, add the DayChanged bit like so:
    TicksChanged var bit
    SecondsChanged var bit
    DayChanged var bit
    You will also need to make a small change to the sequence that increments the time variables
    to wrap around after 24 hours (if you haven’t done so for a clock already),
    and set the DayChanged status every 24 hours.
    Ticks = Ticks + 1
        if Ticks = 100 then
    Ticks = 0
    Seconds = Seconds + 1
           SecondsChanged = 1
           if Seconds = 60 then
    Seconds = 0
    Minutes = Minutes + 1
           if Minutes = 60 then
    Minutes = 0
    Hours = Hours + 1
           if Hours = 24 then <————
    Hours = 0
    	DayChanged = 1 ‘ <—————
    In your own main program file, declare some calendar variables:
    caldim var byte [12]		' calendar days in months
    calday var word			' calendar day
    calmonth var word		' calendar month
    calyear var word		' calendar year
    caldow var byte			' calendar day of the week
    calleap var bit			' current year leap status bit
    calbadentry var bit		' bad calendar input flag
    cacnt var word			' counter for calendar
    cwork var word			' work buffer for calendar
    xwork var word			' work buffer for calendar
    calleapx var bit		' leap year buffer for calendar
    reset some variables in a place that is only run once at startup,
    and set a default date (be sure the date is in range 1800-2300.
    calyear = 2015			' set default date to 01/01/2015
    calday = 0			' day is incremented to 1 at startup
    DayChanged = 1			' because this day changed flag is set
    calmonth = 1			' month defaults to January
    Now somewhere in your main program that cycles, check this code regularly:
    ‘ program initialisation
    ‘ tris something = something
    ‘ some flag = 0
    ‘ your main program..
    ' increment date if day changed over
    if DayChanged = 1 then
    calday = calday + 1
    if calday > caldim[calmonth-1] then
    calday = 1
    calmonth = calmonth + 1
    if calmonth > 12 then
    calmonth = 1
    calyear = calyear + 1
    DayChanged = 0
    gosub setcal
    endif ' DayChanged
    This is the calendar that is called as a subroutine called “setcal”:
    ‘   500 year calendar for pic (tested with 16F877A) by Brek Martin (Art) 2015.
    ‘ This is free software. Please credit the author if it’s reused or distributed.
    ' ******************* set calendar date and find day of week *******************
    setcal:						' find leap year status
    caldim[0] = 31				' set default days in month table
    caldim[1] = 28				' days in February is changed to 29 by the program
    caldim[2] = 31				'
    caldim[3] = 30				'
    caldim[4] = 31				'
    caldim[5] = 30				'
    caldim[6] = 31				'
    caldim[7] = 31				'
    caldim[8] = 30				'
    caldim[9] = 31				'
    caldim[10] = 30				'
    caldim[11] = 31				'
    calleap = 0					' clear leap year status
    if calyear // 4 = 0 then	'
    calleap = 1					' set leap year status
    if calyear // 100 = 0 then	'
    if calyear // 400 = 0 then	'
    endif						'
    endif						'
    endif						'
    if calleap = 1 then			'
    caldim[1] = 29				'
    endif						'
    calbadentry = 0				' reset calendar bad entry status
    if calmonth = 0 then		' check for invalid date input
    calbadentry = 1				'
    calmonth = 1				'
    endif						'
    if calmonth > 12 then		'
    calbadentry = 1				'
    calmonth = 1				'
    endif						'
    if calday = 0 then			'
    calbadentry = 1				'
    calday = 1					'
    endif						'
    calbadentry = 1				'
    calday = 1					'
    endif						'
    if calyear < 1800 then		' implement lower year range restriction
    calbadentry = 1				' prevent far away dates slowing program down
    calyear = 1800				'
    endif						'
    if calyear > 2300 then		' implement higher year range restriction
    calbadentry = 1				' in case of errors far into the future
    calyear = 2300				'
    endif						' the hardware probably won't last that long
    ' day of week
    xwork = 2310					' find best epoch year to iterate from
    cacnt = 12						'
    while xwork >= calyear			'
    gosub epochyears				'
    cacnt = cacnt - 1				'
    wend							'
    cwork = 0 ' working variable for days
    for cacnt = xwork to calyear - 1' iterate years from epoch year
    calleapx = 0					' clear leap year status
    if cacnt // 4 = 0 then			'
    calleapx = 1					' set leap year status
    if cacnt // 100 = 0 then		'
    if cacnt // 400 = 0 then		'
    endif							'
    endif							'
    endif							'
    if calleapx = 0 then			' add days over the years from epoch
    cwork = (cwork + 365)//7		'
    else							'
    cwork = (cwork + 366)//7		'
    endif							'
    next cacnt						'
    if calleap = 1 then				' fix day of month table for current year
    caldim[1] = 29					'
    else							'
    caldim[1] = 28					'
    endif							'
    cacnt = calmonth-1				' add days for elapsed months of current year
    while cacnt > 0					'
    xwork = caldim[cacnt-1]			'
    cwork = (cwork + xwork)//7		'
    cacnt = cacnt - 1				'
    wend							'
    cacnt = calday-1				' add days elapsed of current month
    xwork = 0						'
    while cacnt > 0					'
    xwork = xwork + 1				'
    cacnt = cacnt - 1				'
    wend							'
    caldow = cwork + 1				' shift range for display so 0=Sunday, 6=Saturday.
    if caldow = 7 then caldow = 0	'
    epochyears:
    lookup2 cacnt,[1798,1849,1900,1951,1990,2035,2052,2091,2125,2153,2198,2227,2244],xwork
    Cheers, Art.
    Default Re: 500 Year Calendar for DT Elapsed Timer
    Man, you must be planning to live a long time !!
    Aug 2003
    Not to mention I’ve accomodated those pioneering folk from the past who had to use mechanical clocks.
    Aug 2003
    Here’s the demo video What an unfortunate shot! :O
    Aug 2003
    Hi Guys,
    This came in handy for me today, so I just wanted to share the tip.
    If you are reading UTC time from GPS, and want to display your local time,
    there’s no other way but having a complete calendar to know what the date is going to be
    if your adjustment of the hours made a day change over.
    If you read 22:00 UTC time from the GPS, and in my location, have to add the offset +10,
    you would have the time 32:00, and would have watched for 24 hour overflow in an hours buffer,
    so the time would be displayed correctly as 08:00. The day could have been incremented on the
    overflow of the hours buffer as well, but it could have also been the last day of the month or year,
    and you need to know how many days are in the particular month for the current year.
    This all didn’t really occur to me until I next read the time from a GPS module,
    but the limitation has hit me before.
    Cheers, Art.
    Aug 2003
    Hi Guys
    This might be of use to someone familiar with PBP, but looking at Arduino or something like that.
    The exact same code ported to C, and demonstrated with a graphic GUI.
    Although the graphic GUI is freshly done in C, it’s using the same “setcal" subroutine above,
    as a C function, which at least demonstrates how to use lookup tables, arrays, loops, and some arithmetic.
    Very nice!
    And very quick LCD update! Like!
    Aug 2003
    Thanks Ioannis
    The graphics stuff is all new C started in 2016, but I think that part would be better in PBP or asm,
    just that it wouldn’t run on dspic, and it appears the dspic asm isn’t the familiar 8 bit RISC asm.
    Maybe if/when the PBP24 or PBP32 will be available, we will see dreams coming true!
    Until then, keep up the good work and let us see your achievements.
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. Compiling error on Elapsed timer
    By tacbanon in forum General
    Last Post: - 9th September 2012, 13:09
  3. Totally Baffled with Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 21:01
  4. SPWM and Elapsed Timer
    Last Post: - 8th May 2008, 03:16
  5. DT Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 23:17
