I2C LCD - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
Thread: I2C LCD
  1. #41
    Jan 2014
    Default Re: I2C LCD
    Nothing on LCD: I2CWRITE SDA, SCL,com,$40, x
    In ST7036 manual I not found how I can display a decimal number.
  2. #42
    Default Re: I2C LCD
    I2CWRITE SDA, SCL,com,$40,"hello"
    looks like incorrect syntax , should be like this
    I2CWRITE SDA, SCL,com,[$40,"hello"]
    to display x (assume pbp3)
    buff var byte[16]
    ARRAYWRITE buff,[dec3 x]
    I2CWRITE SDA, SCL,com,[$40,str buff"]
    [/CODE]
  3. #43
    Oct 2009
    Utah, USA
    Default Re: I2C LCD
    Now that I think about it you probably will need to include a "Modifer" before your variable.
    Otherwise your LCD display may think the number is some sort of control character or it may be a non displayable character.
    from the PBP manual...
    An assortment of string-formatting modifiers is available for use within the item list
    of this command. These modifiers can be used to format string output that includes
    numeric values converted from variables:
    Output Modifiers for Formatting Strings
    Modifier Operation
    {I}{S}DEC{1..10} Send decimal digits
    {I}{S}BIN{1..32} Send binary digits
    {I}{S}HEX{1..8} Send hexadecimal digits
    REP char\count Send character c repeated n
    times
    STR ArrayVar{\count} Send string of n characters
    See section 2.11 for details on string-formatting modifiers.
    Dwight
  4. #44
    Jan 2014
    Default Re: I2C LCD
    Now display the x value on LCD , like "hello 012" .
    In main loop, the text is scrolling from right to left on 2 lines.
    SCL   VAR PORTC.0
    SDA   var PORTC.1
    Reset var PORTC.2
    x     var byte   :x=12
    com   con $78
    buff  var byte[16]
    HIGH Reset
    goto StartProgram
    '=============Initializing LCD==========
    ST7036Init:
    I2CWRITE SDA,SCL,com,[$00,$38]'function set
    pause 1
    I2CWRITE SDA,SCL,com,[$00,$39]'function set
    pause 1
    I2CWRITE SDA,SCL,com,[$00,$14]'internal OSC
    pause 1
    I2CWRITE SDA,SCL,com,[$00,$6A]'follower control
    pause 1
    I2CWRITE SDA,SCL,com,[$00,$0C]'display on/off
    pause 1
    here:
    I2CWRITE SDA,SCL,com,[$00,$01]'clear display
    pause 1
    I2CWRITE SDA,SCL,com,[$00,$06]'entry mode set
    pause 1
    startProgram:
    gosub  ST7036Init
    I2CWRITE SDA, SCL,com,[$40,"hello  ",str buff\x]
    'I2CWRITE SDA, SCL,com,[$40,"hello  ",str buff\x]
    goto Main
    Thank you very much for your help!
  5. #45
    Default Re: I2C LCD
    is incorrect
    I2CWRITE SDA, SCL,com,[$40,"hello ",str buff]
    or
    I2CWRITE SDA, SCL,com,[$40,"hello ",str buff\3 ]
    is whats required.
    The "\x" ( length specifier) if used is the number or chr's in the the string {buff in this case } to send (12 {the value of x} is inappropriate), a null terminated string (as created by arraywrite ) needs no length parameter to be specified if you wish to send the entire string
  6. #46
    Jan 2014
    Default Re: I2C LCD
    Now I understand arrays variable. Thank you for your patience and explanation!
  7. #47
    Jan 2021
    Default Re: I2C LCD
    I am just curious. Did you manage to run LCD with the pinout from MIDAS? I mean the pinout you mentioned at beginning of this thread.
  1. I2C lcd ( arduino ) with PICBASIC, help
    Last Post: - 10th September 2014, 19:00
  2. I2C variable to LCD
    By pointjohn in forum Serial
    Last Post: - 19th October 2011, 09:53
  3. I2C to LCD display
    By Ron Marcus in forum Serial
    Last Post: - 29th December 2007, 15:53
  4. Need cheap i2c LCD for 16F877a
    By CodeShredder in forum mel PIC BASIC Pro
    Last Post: - 6th December 2006, 02:25
